Caller ID display for Non-NAV BLUlogic Bluetooth 2010 Prius II
Discussion in 'Gen 3 Prius Audio and Electronics' started by samhoust, May 7, 2010.
  1. samhoust
    samhoust New Member
    How to make the caller id display for the Blulogic Bluetooth on 2010 Prius II for Non-Nav dashboard. The Blulogic manual does not explain in detail. One of the dealer person says its not available in all the models. Does anyone have this problem or figured out the process to get the caller id display
  2. miogps
    miogps Junior Member
    PA
    I do not think that is possible with blulogic.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have the III with Nav and Bluetooth and on the Nav, it will only display the name that you have in the address book. If you do not have a contact name in the address book, it only displays the number.
    I do not believe there is a way to pass Caller ID from the phone to the car.
