How accurate is the gas mileage as reported by the computer?
Discussion in 'Gen 2 Prius Fuel Economy' started by jhoff, May 8, 2010.
  1. jhoff
    jhoff New Member
    Seattle
    I've recently purchased a 2007 Prius and have been tracking my gas mileage. I've been comparing what the computer says and what I get by dividing the miles since last fill w/ the number of gallons to fill. I always reset the computer and have always let the tank get almost empty (flashing fuel gauge). I consistantly calculate 2-4 MPG LESS than the computer reports. I talked with a friend who has a (I think) 2006 Prius and he does the same but his calculations and the computer usually within a few tenths of a MPG. I took my car into the dealer today for the accelerator pedal recall and asked them to look at the MPG. They could find nothing wrong and said that was "normal" I'm not convinced... What do the rest of you see?
    Btw, the computer typically says 44-45 MPG and I calculate 40-42 MPG.
  2. qbee42
    3,079
    This very question has been addressed numerous times in other threads, but in short, here is your answer:
    The MFD fuel calculations are fairly accurate. Long term testing usually shows the computer calculated mileage to be optimistic by 1% to 3%.
    Manually calculated mileage is almost always off over a limited number of tank-fulls. This is because the Gen II Prius contains a fuel bladder (NA models), and the fuel bladder introduces volumetric uncertainty. You never really know how much fuel is burned for each tank. The only way to have meaningful manual manual calculations of mileage is to total the mileage over a large number of tanks. This takes the volumetric uncertainty and spreads it out.
  3. jhoff
    jhoff New Member
    Seattle
    ok - so 4-5 tanks isn't a "large number" :) I'll track it for a longer time and report back. Thanks for the quick response! And after I asked, I found a bunch of other threads...
  4. qbee42
    3,079
    No, not really. I consider 10 a fairly good starting number. However, if you correctly stated your calculating procedure in the OP, it won't matter how many tanks you use, since you are doing the calculation on a tank by tank basis. You need to total up the gallons and miles from all of the tanks collectively, and then divide it out.
  5. jhoff
    jhoff New Member
    Seattle
    or assuming I always let it nearly run dry (approx same size fillup) I can just average the gas mileage results. And that's what concerned me - so far they've always been 2-4 MPG LESS than the MFD...
  6. jhoff
    jhoff New Member
    Seattle
    Oh and one other question - seems not all Priuses (is that the correct plural?) have bladder type gas tanks - some are ridgid plastic. How can one know which type they have? Does it vary by year?
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    What is your typical MPG? For example 3 MPG of 55 MPG is only about 5% so it's not too far off.
  8. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    The Gen I and II -- all models up to and including 2009 --
    have the fuel tank bladder, the 2010 Gen III does not.
    Far more than you ever wanted to know about the Gen I/II fuel system
    here.
  9. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    For the most part, this is not a good idea. Because the bladder has a
    variable volume, apparently it gets stiffer in colder temps, you can
    never tell exactly how much fuel is in the tank. Likewise and more
    importantly, you can't estimate with reliable accuracy how much
    fuel/miles remaining that you have at the bottom of the "tank." The
    "guess gauge," gas gauge is little help.
    FWIW, it is recommended that you refuel the Gen II at two pips.
    Running out of gas in the Gen II is a real no-no.
    Lots of threads on the possible downward spiral of connected issues
    can be found with the search function.
  10. qbee42
    3,079
    This will mostly work, but not as well as totaling. Because of the variation in tank sizes, the tanks that you average will not be the same size, so by averaging you are compounding the error component by giving equal weighting to unequal parts.
    All Gen I and Gen II Prius for the North American market have the fuel tank bladder. Gen II for other parts of the world do not. The Gen III models do not have it.
  11. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    can my gen II be converted to a bladder-less tank?
  12. qbee42
    3,079
    Practically speaking, no. Since it is tied into the emission control system, there is a lot more to it than simply switching the old tank for a new one. I'm sure it could be done, but not for a reasonable amount of money.
  13. jhoff
    jhoff New Member
    Seattle
    Thanks everyone...
    I asked the service guy at my dealer yesterday about the running out of gas / letting the tank run low issue and he knew nothing...
    Interesting about the bladder - my friend w/ a 2006 says his calculated and MFD mileage agree within a few tenths just about every time.
    And yes, averaging the calculated mileage isn't as accurate as doing a running total calculation but if I always put approx the same amt of fuel in the tank, it will be close enough at least for me....
  14. Edgez
    Edgez New Member
    Wisconsin
    My MFD mpg vs. Calculated (Just did them tonight)
    Actual Lifetime 46.2
    MFD Lifetime 47.1
    Readout error 1.9%
    ...............ODO...Trip....Gals........Actual MPG........ MFD MPG
    03/25/10..60016..358....7.39............48.4 ...................48.7
    04/02/10..60387..371....7.98............46.5 ...................48.6
    04/06/10..60746..359....7.77............46.2 ...................47.1
    04/09/10..61072..326....6.20............52.6 ...................48.6
    04/13/10..61384..312....7.17............43.5 ...................48.8
    04/15/10..61728..344....8.06............42.7 ...................47.8
    04/18/10..62119..391....8.14............48.1 ...................45.1
    04/20/10..62476..357....7.34............48.6 ...................49.1
    04/23/10..62864..388....8.37............46.4 ...................47.5
    04/26/10..63228..364....8.28............44.0 ...................44.8
    04/29/10..63586..358....7.76............46.2 ...................47.7
    05/02/10..63976..390....8.29............47.0 ...................46.4
    05/05/10..64375..399....8.47............47.1 ...................49.2
    05/09/10..64749..374....8.70............43.0 ...................44.1
    05/13/10..65093..344....7.00............49.1 ...................45.0
    05/15/10..65466..373....7.85............47.5 ...................46.5
    05/18/10..65788..322....7.85............41.0 ...................45.8
    Info about my drive.
    90% Highway 10% City
    120 Miles Per Day
    Avg Highway speed 65-70
    Avg City Speed 25-30
    Was hoping for higher than 46 mpg, but it's a LOT better than low 20's I was getting with my last vehicle.
    Thanks!
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I find that doubtful. My averages of MFD vs. calculated are pretty close but I am definitely NOT seeing your friend's behavior on my 06.
    On relatively large fills (7+ gallons), they could be anywhere from within 0.1 or 0.2 to ~3 mpg off. On really short fills, say <2.2 gallons, where the margin of error is huge, I see one that's 16 mpg off. Hence, I almost never do short fills.
