DON'T Get a Flat Tire at Night !
Discussion in 'Gen 3 Prius Main Forum' started by New_Yorker, May 9, 2010.
  1. New_Yorker
    New_Yorker New Member
    517
    69
    If you open the rear hatch of your spanking New 2010 Prius and click on the trunk light you will discover that it is woefully inadequate to locating the tire replacement items you'll need to locate in the dark. It is a shame that Toyota does not offer a light of some significance mounted above, say on the inside of the Hatch Lid shining down on the contents of the cargo space. Emptying whatever you have on a dark, maybe even rainy night, to get to the spare tire, and jack is rendered so much more difficult by having only a tiny yellowish glow from an inadequate trunk light.
    So make sure you carry along a good light source of your own as a part of your Emergency Equipment, " Just In Case !":mod:
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Since a light inside the car won't illuminate the tire attached to the car, having a flashlight is a necessity anyway. I have one in the glovebox and another on my keychain.
    The keychain light (for example) is very handy to have. I'm surprised how often I take advantage of it.
  3. New_Yorker
    517
    69
    I agree, and yet have you ever seen a car with a flashlight included for that purpose, and a mounting location to hold it ?
    The trunk light has another purpose, because most people will need to remove the contents of the trunk to access the spare tire. Not too easy to do while having to hold the flashlight while you do it. Oh, and God Forbid you drop something into the open trunk with the cargo tray removed and it rolls or slips out of sight. I added two LED lights good for 100 hours powered by 3 AAA batteries, one to each side of the cargo space, and angled down. They are considerably brighter than the bulb Toyota installed. The best mounting location would have been the inside of the open hatch, sadly I have no light suitable. I will continue to look for one.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It also can't hurt to find all that stuff in the *daylight*
    in a safe setting and actually practice using it a couple of
    times, right down to swapping on the spare. That way you've
    got it in "muscle memory" for when you really need it...
    _H*
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Every BMW I've owned had a rechargeable flashlight in the glove box, plugged into a charging port.
  6. New_Yorker
    517
    69
    An enlightened idea to be sure. I would suggest a flat bottomed light that can stand on its own in the wind, and yet light the tire needing replacement, as one is apt to be doing this task alone. All the more reason the trunk space should not require the same flashlight for accessing the items one needs to remove. Run flat tires for those of us less physically capable, like elderly people, women, and those handicapped by something, would seem a better idea.
  7. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Yes, it's true, my BMW had a glove box mounted, rechargeable flashlight, and a cool little toolbox mounted to the trunklid. For only $25,000 more! :)
  8. qbee42
    3,079
    Most cars I have owned each contained a flashlight and one set of dead batteries. The old tubular flashlights are especially good for storing dead batteries. ;)
  9. fuzzy1
    10,558
    That is why I kept two dead battery storage tubes in my cars. That increased the odds of one failing and actually producing some light.
    Battery shelf lives have greatly improved, and LEDs are much friendlier to nearly-dead batteries than were old-fashioned incandescent lamps.
  10. qbee42
    3,079
    That is certainly true. I like the new LED flashlights and headlamps, although I do miss the excitement of opening up an old flashlight and pouring out a couple of rust colored D cells and some suspicious looking chemical waste.
  11. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Love the description of the contents that you'd pour out of the flashlight!
    Don't they make those flashlights you can shake and get light? Something like 20 minutes of shaking it for 20 seconds of light, right?
    I have a small, LED flashlight that uses AAA batteries sitting in my center console. Needless to say, regular check ups of the flashlight is probably a good idea to make sure the batteries are relatively fresh/charged so that when you need it. On another alternate option, they do sell battery chargers (AA/AAA/etc) that come with cigarette lighter plugs so you can charge them from the car. Of course, you'd either have to keep it plugged in all the time, or hope it's a fast charger and you can get just enough to get the task at hand completed.
  12. fuzzy1
    10,558
    You must have used more capacious storage tubes than I did. My household has lost more than one Maglite because the leaky cells would not slide out. Not slide-hammer out. Nor let go of a cell with a lag screw bored in and trying to yank it out.
  13. fuzzy1
    10,558
    This option also has the problem that the calendar lifetime of most rechargeable batteries is shorter than the shelf life of modern alkaline batteries.
  14. GWhizzer
    GWhizzer not so Senior Member
    120
    24
    Winnipeg, Manitoba
    Me too, so I took to keeping one of those LED flashlights you crank to charge. A couple of minutes of cranking can give several minutes of light. They can be bought for about $10 and you NEVER have to worry about dead batteries. And while the light from these can be a little anemic, they have saved my bacon on more than 1 occasion.
  15. Comrad_Durandal
    Comrad_Durandal New Member
    170
    Minneapolis, MN USA
    That Superledlight place seems to sell a LED light that will charge in a 12V Aux power socket - which is pretty close to the BMW flashlight idea - though perhaps Toyota might have to look into nabbing the rechargable LED flashlight idea - even as a 'the port is free, buy the flashlight' type option.
  16. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
  17. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Use one of the flashlight apps on iPhone.
  18. GWhizzer
    120
    24
    Winnipeg, Manitoba
    buying a $400 iphone to use as a flashlight strikes me as a pretty expensive solution to the problem...:)
  19. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    I live in NY and called AAA when I got a flat. I sat in the car playing games on my iPhone until the truck arrived.
  20. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Lots of us here already have an iPhone, no need to stock a separate flashlight if you already have the device.
