Anyone changed the parking light bulb?
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Jan 25, 2008.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It is the yellow smallest and top most bulb in the front head lamp unit. I know John1701a changed it because I saw it in his expense log. He did not explain how to do it.
    I went and bought a pair of replacement bulbs for $3 and found that it is W5W when I got home. Then I remember plenty of them at home from replacing the interior and door lights with the LED bulbs. I can use one of them for sure. Now, I gotta go and return it.
    I am also thinking of upgrading this parking bulbs to LEDs. Any hint how to change the bulb or idea against using LEDs for it?
  2. Tripod137
    Tripod137 New Member
    145
    Long Island
    I had to replace one of mine. Hard to find the bulb, but finally located one. $0.79. Anyway, I think it is best to remove the light NEXT to it (turn signal) to give you more room. If I remember correctly, you need to twist the holder to get the bulb out (both the turn signal AND the parking light). It is one of those 1/4 twist deals. After the turn signal, do the same thing to the parking light. To replace the bulb, just pull it out and push the new one in. Then reverse the process.
    I learned how to do it from the manual that comes with the car.
  3. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Thanks for the tips. The manual is in the car and I'll take a look in there too.
  4. Tideland Prius
    16,597
    I believe it's a twist and pull but double check with the manual.
    I wanted to replace it with the free bulbs that PowerBulbs gave us but I couldn't twist or pull the darn thing out so I gave up and used those bulbs in my map light lol.
  5. Flying White Dutchman
    4,376
    313
    i am working on fully led prius:D
    inside almost done now! pics soon
    only need to now what kind of light bulp you peolpe use to replace this parking light
    link?
  6. Tideland Prius
    16,597
    194/168 bulbs will fit.
    usb, any updates? were you able to get the parking light out?
  7. Flying White Dutchman
    4,376
    313
    194/168 that like T3 ot T5?
    edit add picture!
    is this the light? because this is a T10
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Nope. Been busy. Probably this weekend.
  9. Tideland Prius
    16,597
    That looks like it
  10. Flying White Dutchman
    4,376
    313
    ok
    because my replacement 1 LED light is surely not strong anough for the job
    need to find a more powerful led
  11. Flying White Dutchman
    4,376
    313
    you can clearly see not up for the job
    600mcd only with 1 led inside
    i am now going for the 8000mcd 6 led bulb
    next week more info!
  12. Tideland Prius
    16,597
    yeah that's is quite dim
  13. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    Or get some of those side firing LEDs. Mine is like that and output is good. It is able to use the car's conical reflector housing.
  14. Flying White Dutchman
    4,376
    313
    mcd's?
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I just changed mine with one of the bulb from upgrading my interior LEDs. I just replaced with the exact one. If anyone is interested, the bulb is W5W 12V5W.
    Just pull out the wire and turn counter clockwise. Very simple.
  16. Tideland Prius
    16,597
    I wish haha. Seems like every bulb has been superglued in on my car.
    I'll remember to pull the wire and twist anti-clockwise. Thanks!
  17. KTPhil
    KTPhil Active Member
    1,379
    22
    Twist first, THEN pull.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I meant to say pull out the wire harness and then twist. Last step is to pull it out.
  19. FCBarca
    FCBarca Junior Member
    La Côte
    Trying to scour ebay etc. for an amber bulb for this parking light (My front passenger side went out) as well as an explanation/guide on how to replace it...Searched around but can't seem to find it
