Headlamp sun damage.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Carl Petersen, May 10, 2010.
  1. Carl Petersen
    Carl Petersen New Member
    Quartzsite, AZ
    Living in the desert the plastic head light covers are starting to show damage from UV exposure. Can the outer covers be replaced or do I have replace the entire headlamp?
    Thanks,
    Carl
  2. Patrick Wong
    18,210
    6,511
    Hi Carl,
    I suggest that you go to your local discount auto parts store and buy a small bottle of plastic polish. That may help to remove the haze on your plastic headlamp lenses.
  3. richard schumacher
    7,664
    1,046
    United States
    Agreed. Much cheaper than replacing anything and almost as good with a little effort, even without using a polishing machine.
  4. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    To answer you question: No the lenses are not available separately
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I have tried the headlight polish and it usually works very well. Most of the kits have a special buffing wheel
    I haven't tried this one, but a Google had it pop up
    Headlight Restoration Kit | System
    Hope this helps
  6. Carl Petersen
    Quartzsite, AZ
    Thanks everyone. I'll pick up one of those kits and give it a try.
