04 05 06 07 08 Toyota Prius Traction Battery cells
Discussion in 'Private Sales' started by wenter, May 11, 2010.
  1. wenter
    wenter New Member
    California, USA
    2001 Prius
    I
    Good working cells pulled from 07 Prius Traction Battery. Can be used in 04 through 08 batteries. Or if you are rebuilding 01-03 battery and need more cells (01-03 batteries are using 38 cells vs 04-08 are 28 cells) you can use this ones. All are tested and have more than 7.2 V Price is $17 per cell + shipping. If you buy more than 1 I will combine shipping. Will ship to continental USA only.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    How do you suggest we the amature installer goes about removing, safely, the old cells? How about age and voltage matching and cell balancing issues.
    Finally, this sounds like a commercial ad to me which is generally not allowed here...gonna let this slide for a little while assuming it's the only one you post b/c you simply aren't gonna sell these to anyone.:cool:
  3. wenter
    wenter New Member
    California, USA
    2001 Prius
    I
    I rebuilt the battery myself and I selected cells from 2 batteries that matched or were pretty close on voltage. Both batteries were same year.
    It's not a commercial - I'm private party.
  4. jk450
    jk450 New Member
    55
    Such issues are discussed regularly in the forums.
    There is nothing in the post to suggest that it is a commercial advertisement. In fact, if you read the OP's other posts, you'll probably figure out why he or she is selling the cells.
