Regeneration specs?
Discussion in 'Nissan/Infiniti Hybrids and EVs' started by LakePrius, May 17, 2010.
  1. LakePrius
    LakePrius Special member
    99
    Nevada
    Has anyone seen the specifications on energy regeneration capabilities for the Leaf?
    I'm wondering if these are designed to regenerate as much power as the MG's on the Prius do since there is no ICE in the Leaf design. The Prius MG's are pretty impressive, IMHO. I don't think the Leaf is actually an motor/generator but rather just a generator of some sort.
    Specifically, do we know enough about the specs to be able to figure out how many kilowatts of power you can put back into the battery by, for example, going down a 6% grade at 50 MPH for 10 miles?
    Conversely - do we know enough to estimate how many kw it will take to drive up the same grade?
    It would be nice to be able to travel out of the mountains now and then. I suspect some experimentation will be needed once the car is around, but running out of battery could be a little inconvenient!
  2. Uh Clem
    Uh Clem New Member
    Bellingham
    I haven't seen specs for Leaf regenerative braking, but I expect that it should be quite effective on the Leaf.
    Electric motors, by their very nature, are also generators. Toyota emphasizes their dual nature by calling them MGs, but the Leaf's electric motor should do as well. On the Leaf though, it only acts like a generator for regerative braking.
    I think the Leaf will have an advantage with regenerative braking because of its large battery capacity. On long downgrades in the Prius, the battery fills within minutes. The Leaf's battery capacity should have more room to recover regerative energy.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I suspect the Leaf's superior power ratings will allow better regen than the Prius.
  4. daniel
    14,487
    1,519
    Spokane, WA
    I'm less concerned with kilowatt ratings than with how the regenerative braking is engaged: Is it like the Prius, where stepping on the brake pedal engages it and ALL braking is regen except for very hard (emergency) braking and braking at very slow speed; or is it like the Tesla, where you get SOME regen when you take your foot off the accelerator but the brake pedal engages friction brakes?
  5. mwalsh
    mwalsh Member
    124
    Orange County, CA
    It would be great if it were like the AC eBox, where there was a dial inside the car for adjusting regen. Dialed up all the way, you never had to touch the brake pedal. Dialed down, you got some regen without it slowing the car by much.
  6. daniel
    14,487
    1,519
    Spokane, WA
    I disagree. I'd like to see the brake pedal operate like the Prius: All regen and no friction braking unless the demand for braking was more than the regen could supply or the speed was too slow; and the accelerator pedal like my Xebra (and some other EVs) where taking your foot off the accelerator results in pure coasting.
    The idea of putting regen on the accelerator pedal is an atavistic attempt to make an EV (or a Prius) "feel" like a car with an automatic transmission, which slows the car down when you take your foot off the pedal.
    Putting a lot of regen on the accelerator pedal would make it more difficult to control the braking. The accelerator pedal should be for accelerating, and the brake pedal should be for slowing.
    Prius drivers have to find exactly the right pedal pressure to coast. With my Xebra, I take my foot off the pedal and I coast. This is much nicer, and is a more relaxed way to drive. An EV is not an automatic and should not pretend to be an automatic.
    Just my opinion.
  7. Uh Clem
    Uh Clem New Member
    Bellingham
    Exactly. That's how I'd want it to work on the Leaf.
    Even if it normally regens with foot off, I'd like a mode that lets it coast. My foot gets tired of keeping the pedal at the "sweet spot" on the Prius.
  8. hill
    8,784
    The battery temp management is WAY simpler than the Prius, so it may be safe to assume the regen will be equally simple. Even so, it'd be WAY impressive if regen was adjustable as it is with the RAV4-ev.
    http://avt.inel.gov/pdf/fsev/sce_rpt/rav4_ind_report.pdf
    But you don't get a cheep price if you have tons of fancy stuff.
  9. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Any software engineer will tell you it's a lot more successful to engineer the system to match the human than to try to engineer the human to match the system, even if it's much harder.
    The Prius has one brake pedal that operates two different systems and one power pedal that operates two different systems. It would have been so easy to engineer it with a regen brake pedal, a friction brake pedal, an ICE power pedal and an electric motor power pedal. You wouldn't have sold any. It's much more successful imitating what the owners were used to.
    Should we also get rid of creep, since that's faking an automatic car function? Actually, those of us who came from manual transmissions would quite like that!
  10. daniel
    14,487
    1,519
    Spokane, WA
    YES!!! Absolutely!
  11. mwalsh
    mwalsh Member
    124
    Orange County, CA
    I bet there would be sales in massive numbers to the organist community! :D
  12. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    This is one reason. I highly suspect that Toyota's user testing showed that it was a good way to ensure some regeneration of the traction battery, even with heavy footed drivers not adequately using the regenerative brake system while braking.
  13. Mike Dimmick
    963
    249
    Reading, UK
    Regen braking does nearly nothing useful. The battery is largely charged simply by the engine running. The car will run the engine harder - consuming more fuel - the further it gets away from the optimal charge point (six bars out of eight).
    You get useful energy from regen when descending a hill but you had to put more energy than that into it to climb the hill in the first place. (Or, you'll use more getting back up there, assuming a round trip.)
    It's better than throwing the energy away as heat (friction braking) but ultimately most of the drive force comes from the petrol/gasoline (hybrid) or from the plug (EV).
  14. Philosophe
    437
    72
    Agreed. I was simply saying that some drivers who brake late and hard may not get an interesting charge back from regen and that the simulated drag on the transmission may help.
  15. LakePrius
    99
    Nevada
    It would be great to be able to refill a substantial amount of the battery on a long down grade. As mentioned, it doesn't take very long for the Prius to top up going downhill.
    Some of the pictures posted show the Leaf shifter with a "B" indicator, so it looks like it has some type of "brake mode" to keep the speed in check going downhill and regen power. One difference - I believe the Prius spins the ICE to help control the speed going downhill. I wonder how this will work on the Leaf - will spinning the electric motor to generate power also supply enough drag to keep the speed in check? Will there be temperature monitoring of the battery during regen to be sure it doesn't overheat - presumably also with some type of automatic cutoff of regen if there is heat build up.
    Around here - if I could refill 20 or 30 miles worth of charge going downhill and use only 40-60 miles of charge going back up the hill, it would give me a substantial amount of increased range, or places I could go.
    Guess the test will be to drive uphill first and gauge how many battery charge miles per actual mile I'm using, then turn around at the crest and come back down and see how much is regenerated.
  16. daniel
    14,487
    1,519
    Spokane, WA
    In cars with an ICE, engine braking is a useful way to dissipate energy as heat without heating the brake pads. There is no analogous system in a pure EV. Regen captures energy, but once the battery is full the only way to dissipate that heat would be to have a large resistor (in effect a resistive heater) to dissipate the heat.
    Since an EV has a larger battery than the Prius, there is more room for energy capture. But there will be times when the battery is full. Perhaps EVs will have the ability to use the car's heater to dissipate "motor braking" energy by directing unwanted heat to the outside.
  17. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Those times would be very rare. Leaving fully charged and going down a long long hill right away is the only one I can think of. Most of the time going down a large hill is preceded by going up a long hill. As the car is not 100% efficient there should almost always be room in the battery for dumping power.
  18. daniel
    14,487
    1,519
    Spokane, WA
    I agree that it would be rare. However if you live on a higher spot than the surroundings, and there is a long steep downhill, and you charge fully before leaving home, you will encounter the situation of having no other way to slow your descent than your friction brakes, which will then be subject to overheating.
    Rare as it may be, a well-designed car should have some system analogous to engine compression braking to protect the friction brakes.
    Shunting regen power to the resistive heater and blowing that heat to the outside would accomplish this.
  19. LakePrius
    99
    Nevada
    You nailed my scenario pretty closely. I live at 6500 feet in a basin. To leave the basin I drive between 10 and 40 miles to get to the bottom of a pass, and then up to 7700-7900 feet. The cities on the other side of the passes are at about 4500 feet. So I'm not starting up the hill at completely full charge but somewhere between 60% and 80% of charge. It would be great to be again at full charge at the bottom of the hill, be able drive 20-30 miles, and then still have enough juice to go from 4500 feet, over 7900 feet and cruise downhill the last 20+ miles to 6500 feet. Since the downhill stretch is on the order of 10+ miles - it's always nice to be able to go down the hill without burning out your brakes (or to develop brake "shimmy" after a few years of travel) and it would be great to end up at the bottom with a full traction battery. In the Prius, "B" works incredibly well on long downhills as far as both charging and holding speed. In my ICE cars I end up downshifting - some it works well, others you still need lots of brake.
    As mentioned, I guess it will take some experimentation - it's just that the cost of failure is pretty high! Many of the roads here have a barrier down the middle so you can't just turn around and head downhill if you run short of juice.
  20. Philosophe
    437
    72
    This reminds me of the Hydro-Québec's Pierre Couture serial hybrid (some info in French here or do a Google search on "moteur-roue couture hydro-québec"): four linear "motor-wheels" with integrated DC-AC converters (97% efficiency, 70 kw each, 1200 N-m/885 lb-ft each, at the wheel), no drive train, shafts or transmission of any kind, no friction brakes, internally developed 200 kg battery pack, planned 25 kw gas generator.
    When the 4 motors stopped the car with their 4800 N-m total torque, energy that could not be "absorbed" by the battery was pushed to a big resistor to dissipate it as heat. So much motor torque was required to ensure adequate braking power (up to the limit the tires).
    Sadly, this research was ended by Hydro-Québec as they didn't feel they could easily go against the big three alone (neither wanted it as it would have meaned a revolution nobody was yet ready to deal with).
    All is left is TM4. Tata, Peugeot and Citroën are using the technology currently, but with a conventional hybrid design, with a central, unique motor. Any way, we still have lost 20 years.
