EV Mode
Discussion in 'Gen 3 Prius Fuel Economy' started by krzysiu, May 16, 2010.
  1. krzysiu
    krzysiu Will knock you out...
    Chicago
    Hey all,
    New to the boards. Thanks for having me. I am having a tough time finding a good explanation of EV mode. I am aware that it is when the vehicle is utilizing electric power only. However, I have seen some information that the vehicle must be up to temperature etc. Also, with a "full charge" how long would you be able to last in EV mode? I know there are probably tons of variables, but let's just say in gridlock on a flat expressway of Chicago. Thanks again, your input is greatly appreciated.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Here is the latest thread on use of the EV mode... there are plenty others. Use the search function.
    Welcome aboard!
  3. krzysiu
    Chicago
    Thanks a lot spiderman, getting my feet wet with the layout. I'm going to check out the link for sure!
  4. bisco
    51,855
    generally a mile or so on flat land at low speeds. the engine won't come on until the battery gets low or you press too hard on the accellerator or reach too high a speed. then it will go into warm up mode. all the best!
  5. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Don't worry about the EV mode, the way it's currently configured makes it pretty useless IMHO. The Prius automatically uses the electric motors when your speed is under 45mph and acceleration is light, as long as the battery has juice.
  6. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    EV is very good when, in town, you know the road ahead, and do not want to bring ICE to work, or want deliberately to use batt because you are approaching a hill descent.
