Weird sound from the engine bay
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JohnRobinson, May 21, 2010.
  1. JohnRobinson
    JohnRobinson Junior Member
    99
    29
    Norway
    Hi all. Was just sat in my car with the petrol engine off and heard a weird sound coming from the engine bay. The aircon was on but surely it cant be so loud?
    (Turn your volume up ) :D
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Is the radiator fan on? What was the outside temp?
  3. JohnRobinson
    99
    29
    Norway
    Nope the radiator fan was off. Outside temp is 60 f.
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Any more details? Was the car ON or READY? Dose the noise continue indefinitely?
  5. Patrick Wong
    18,210
    6,514
    Sounds like the air conditioner compressor to me. To verify, turn off the AC switch and see if the noise goes away.
    If the AC is providing cool air, then no worries.
  6. JohnRobinson
    99
    29
    Norway
    The car was on and ready to drive. The AC was on. Providing cold air. So you think its ok then even though it was so noisey?
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    was there pink in your inverter coolant tank?... i've heard a similar sound when air was caught in the lines/pump.
    i was going to recommend coolant pump (ice.. non inverter) but that tends to make a chirping noise (from my experiance... unless it's WAY past dying then it could make that noise)
    take a tube about 3 or 4 feet long and listen to different spots in your engine bay. (like a child "telephone")
    the only other thing i could think of would be a bearing somewhere.... (one of the two or three attached to your "fan belt" (water pump really...)
  8. 2009Prius
    2,705
    512
    63
    It's really hard to tell just by the recording. Was the noise changing during the recording or it's just that the recorded noise changes because the camera was moved around?
    Here is a recording of my AC compressor and other noises:
    I would do what Patrick and V8Cobrakid suggested: determine where the sound comes from by either turning things on and off or trying to locate the source of the sound.
  9. JohnRobinson
    99
    29
    Norway
    Ah that sounds pretty similiar. I will check it once again but Im pretty sure you guys are right. Thanks alot for calming my worries.
    Cheers! :)
