A/C Power Source
Discussion in 'Gen 2 Prius Main Forum' started by maggieddd, Aug 9, 2005.
  1. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    Anyone know of A/C Power Source for Prius? Sigma Automative has it only for Japanese appliances
  2. kirbinster
    kirbinster Member
    602
    Morris County - New Jersey
    What do you mean by the source? In the current prius it is electric in the classic it is shaft driven off the ICE, is that what you are asking or is there something more detailed you are looking for?
  3. maggieddd
    2,090
    Boston
  4. kirbinster
    kirbinster Member
    602
    Oops. thought you were talking about air conditioning when you said A/C - sorry :(
  5. popoff
    popoff New Member
    560
    western NC mountains
    The closest you will come to a 110 volt AC power source in your Prius will be through the use of an inverter. You can buy them at Radio Shack, auto stores, e-bay, and other on-line vendors. Just make sure the inverter is capable of handling the sustained wattage requirement of whatever you plan to plug into it.
