Slightly dissatisfied with my Mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by Jamebarron88, May 21, 2010.
  1. Jamebarron88
    Jamebarron88 Pripubescent
    Houston
    I was kind of happy to see my mpg average slowly creep up to 41.5mpg until I see so many people on here getting 55mpg average and up. I know my commute is fairly short and am guessing that may be the reason for my mpg, but am hoping it is something else.
    What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations) 41 mpg avg from the MFD. Just recently creeping up to that number, was getting 38/39 average the first couple weeks (tire pressure was lower by about 2-3psi per tire).
    - What fuel economy are you expecting and why? 50 mpg because that seems average from what I've seen on the boards for my weather and tire pressure. I'm ok with 41mpg but feel that I should be getting slightly better.
    - What are the approximate outside air temps? 95 F
    - How long are your trips? 15 miles, takes about 20 minutes
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving? I stay between 45 and 64 mph the majority of the drive (11 mi.) Only need to accelerate from 0-45 2 to 3 times, occasionally 4 times.
    - What region/state are you in? (if you haven't set your location in your profile) Just north of Houston, Texas. Very warm and humid this time of year.
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.) Mostly flat with a few gentle hills.
    - Is your oil overfilled? (i.e. above the full mark on the dipstick) Yes by about 3/8" I don't know how to drain any, and cannot find a hose small enough to siphon any out.
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here) I performed this test after my car had been sitting for 3 or 4 hours after a 20 minute drive, and everything seemed right on according to the test in the thread linked above.
    Have you had your alignment checked? Any pulling or abnormal tire wear? I have not had my alignment checked but just purchased the prius 3 weeks ago as a certified pre-owned. I would hope they checked the alignment, but cannot say that I am certain they did.
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15). Pirelli Cintauro P5 P205/55 R16 Tires that came with the car (purchased certified pre owned) it has toyota wheels (looks like covers over the actual wheels) I'm interested in taking off the covers, but am not sure how. I believe I had read somewhere that it may help slightly with mpg.
    - What are your tire pressures? Driver Front:41.1 Driver Rear: 40.2 Passenger Front:42.4 Passenger Rear: 40.2
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.) Acura Integra Ls 1998 4cylinder automatic. Roughly 30mpg all freeway (75mph)
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    I drive as conseratively as I know how. Accelerating slowly, using electric as long as possible. I glide as long as possible, anticipate red lights far in advance (there's only two on my commute) and gently brake from about 25mph down.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    No
    - Are you driving using D or B mode?
    D only
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    I generally use just the vent with the a/c off. Although today it was 93 degrees so I did use the a/c intermittently (mostly when cruising at 55-48mph) temp set to 70-73
    Also my current tank is the best so far, but is also the only tank I have used premium gas in. I hadn't realized it is advised to not use premium.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Between 44 and 52 depending on driving and terrain. (I live on a mountain and have a couple thousand foot vertical drop between the main city and my house). Determined by looking at the MFD. You cannot count on "at-the-pump" calculations because that assumes the tank is the same size each time. Our cars have flexible bladders and it varies by ALOT! So the MFD is your best bet other than averaging over many many fills.
    That is a big cause of MPG loss. Go to Petsmart, get aquarium tubing. $1.99 for 8ft of clear tubing and it fits like a glove. I just did this today actually. I still need to do more since it takes a couple hours at this rate. Alternatively you could buy a true oil siphon or drain it and refill properly.
    My newsed car's alignment was off (slightly, but still off).
    The covers wont effect mileage noticeably at all.
    BINGO... This is just flat out the wrong way to drive a Prius. It is very counterintuitive, but you should accelerate aggressively (not to the floor, but with oomph) which is called "pulsing" and then you want to take your foot off the accelerator completely and then press down just a little bit (like with your big toe only or something) so that there are no arrows at all on the MFD energy screen which is called gliding. So Pulse to speed limit + 5, glide back down to speed limit or a bit below, then pulse back up, and glide back down. You should try to never use regen when just driving down the road. Meaning dont accelerate and then take your foot off completely then accelerate again. That's just wasted energy. Using electric only is a very poor idea as well. It almost always hurts your MPG. One difference is with the EV mode accelerating briskly in electric up to something in the teens and then using the engine to keep accelerating. This can help the fuel economy in certain situations.
    Just turn it off and use the windows unless you go over 55mph or so.
    I used premium for the first couple thousand as it always gave me really good FE in my Honda Civic, Lexus RX, and Toyota Rav4. However the Prius for some reason likes 85 quite a bit and it does help. So cheaper gas actually makes the Prius happy. :)
    So basically, you can drive the Prius like any other car and get 40's which is still far better than anything else on the road. Or you can drive with a little adjustment and get much much better. If you are really interested in fuel economy, then you can become a hypermiller elite!
    And :welcome:
    2 people like this.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Thanks for answering my questions! It's refreshing to see that vs. random low post count folks people griping about their mileage, providing scant or no details (leaving us guessing), sometimes to never return...
    Your mileage does sound a little a bit low for the speeds and trip lengths you're describing.
    Agreed w/2k1 about NOT trying to accelerate so slowly that you're in electric only and on draining out the excess oil.
    As mentioned in the 1st PDF at http://priuschat.com/forums/gen-ii-...angauge-best-threads-mileage-improvement.html
    Hopefully someone can chime in about those tires as I don't know how badly (if all) those tires hurt mileage vs. the stock ones. I don't recall seeing anyone here on PC installing those.
    As for turning off AC... uhh, even though I used to live in California, I don't think I'd be able to tolerate 93 F w/no AC for long on an AC equipped car. But yes, using it will hurt your mileage a bit.
  4. Marvinh
    Marvinh Marvin
    189
    NY - Long Island
    I only use regular fuel.
  5. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I would echo what Cwerdna and and 2k1 said, although I would disagree about A/C usage (good god, 93F and Humidity! Use your A/C, there will be a MPG hit, but there is a MPG hit for all cars using their A/C).
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Another reason for the A/C besides creature comfort, that has been mentioned in other posts, is to keep the HV batteries cool.
  7. Jamebarron88
    Houston
    Thank you! I'm hoping this is my biggest mistake. I will try to fix it on my way to work today. I was almost afraid to push the accelerator much. It almost hurts to see the display showing 11.5 mpg while accelerating!
    Thank you for your response. I will do my best to address these issues, and hopefully joing the 55mpg club :)
    Thank you all. I'm glad to be here. This is a most informative forum.
    P.S. The temp is 89F at noon here today with 51% humidity (that's actually low humidity for us)
  8. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Great work on posting all the info Jamebarron, it makes it so much easier for people here to quickly find your trouble spots.
    I can see at least 5 things that are bringing your MPG down there.
    1. Oversize tires. Though I assume that you have the "touring edition" prius with uses these as standard so perhaps not much you can do about that.
    Deduct 2MPG.
    2. Not using LRR (low rolling resistance) tires.
    Deduct a further 3 to 6 MPG.
    3. Driving habit. Trying to accelerate on battery only is an inefficient use of the battery power.
    Deduct another 2 to 4 MPG
    4. Lots of A/C use.
    Deduct 2MPG.
    5. Overfilled oil. Personally I've never noticed much of a hit on MPG when I've had mine overfilled by a smaller amount (about 1/8") but various others here swear they measured a 1 or 2 MPG hit there. I'll ignore a 1/8" overfill (some here wont) but I wouldn't be comfortable going 3/8" over. Make sure you're using a really good quality 5W30 oil and don’t overfill. Deduct 1 or 2 MPG.
    OK let me add straight away that I'm just reporting what I see as the factors that would make you fare worse than the guys getting 55MPH, I'm not saying that you necessarily can or should "fix" every issue. Take the A/C use for example, I'm not telling you not to use it, you need it. I'm just pointing out the factors.
    Adding the median of the above 5 issues (all just wild guestimates of course) buys you about another 13 MPG. Adding this would bring you up to about 53 or 54 MPG right.
    2 people like this.
  9. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi Jamebarron. Here's a bit of extra info re my last post.
    I searched for the rolling resistance of your tires but I couldn't find much. I found this on a Honda Civic hybid MPG forum. Interesting read.
    Re driving style. I wrote this a few days ago for another thread. Let me just copy and paste it here.
  10. Jamebarron88
    Houston
    I changed my driving style today for my commute to work (15miles)
    and my commute back to a nephew's graduation (20 miles) then back home (5miles)
    My mpg creeped up to 41.8 from 41 avg. I did notice however that my instant fuel economy was consistently significantly higher just from trying to change my driving habits a little. I think with practice and time (and maybe a few of the other fixes:tires, oil level, air pressure, etc.) that my mpg will continue to rise.
    I looked at it kind of like accelerating the way I used to in my automatic integra. I'm getting better at the gliding, but I don't exactly understand the pulse part. Perhaps, you all could shed some more light on the technique.
    Thank you all for your help
  11. Jamebarron88
    Houston
    I do have a touring edition.
    I'm assuming I can change these for more fuel efficient tires when my set need replacement? Or does the touring edition need the bigger size tires?
    What moderately priced tires do you recommend? I'd like to purchase them at discount tire if possible.
    Thanks again!
  12. uart
    uart Senior Member
    4,215
    1,201
    Australia
    The touring has bigger rims so it takes different tires. I don't own a touring edition so I don't know for sure whats best in that size, but if you ask around here I'm sure you'll get some suggestions for a LRR replacement.
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep, touring's got bigger tires. When I asked for tire recommendation for my non-touring at http://priuschat.com/forums/gen-ii-...-another-help-me-decide-tire-thread-06-a.html, I got a couple recommendations and was also sent to another thread.
  14. Ophbalance
    Ophbalance Member
    205
    North Carolina
    I'm not sure I would agree with this amount. I've set my A/C to auto, usually above 76F on the MFD (and the hotter it gets, the higher I go. 90F external usually has me at 81F internal on the MFD). I've not seen a hit using this method. Heat, however, is a much bigger drag on MPG for me.
    Caveat >> I drive below the posted limits, live in a fairly flat state, drive mostly highway milage, and have a very long commute. However, even when my wife drives the car (and the Scanguage captures much higher speed runs for her than it does me ;) ), it's very rare that even she doesn't return in the low 50's for a trip average over several hundred miles using the same A/C settings.
  15. richard schumacher
    7,663
    1,038
    United States
    Watch the Energy display. You want to use the battery as *little* as possible because charging and discharging a battery is inherently inefficient. That is why pulse-and-glide is the best strategy.
  16. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Accelerate briskly from a stop, then ease off.
    Watch ahead, and when you see the traffic lights going against you, ease off sooner than you are used to. Anticipate traffic patterns, and already be coasting slower when you have to stop. If a stop light will be changing momentarily, see if you can avoid coming to a dead stop (slowly coast to it)... starting up from a dead stop takes just a bit more power than speeding back up from a crawl.
    Using cruise control in hilly areas doesn't work well. You want to ease off the gas just as you come to the crest of the hill, and let that inertia work for you - on the way down, and then again on the way up the next rise. Unless traffic is intolerant, let the speed vary a bit as you go up and down the hills.
  17. cpm
    cpm Junior Member
    WV
    Interesting.
    Are there numbers to back this up?
    Years ago, when a friend's wife bought an '04, and we were all interested, I read something online, (probably by Hobbit) concerning drag coefficients that pretty strongly implied that above 22 to 25 mph (apparent wind) the additional drag would overcome the loss from running the air control. Assuming of course, folks
    are being reasonable with the A/C.
    I can 'feel' the windows at about 40mph, regardless of how I have them open.
    crack this one, and the diagonal one, and so on. In some cases, the 'thumping' I get from the air pressure of having the windows open in some configuration or another gets severe enough to make me think a window is going to pop out.
    the drag at 55 is crazy. Feels like carrying a parachute or something.
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I have no idea. It is second hand info, and I believe there is some truth to it. Obviously every car will be different depending on its shape and AC efficiency as well as how hard you are running the AC. But the two versions I have heard many times over for many years are "above 55" and "at highway speeds" which from the Eisenhower days were 55 I believe. So the cutoff is probably around there +/- some margin.
    I never really paid attention ayways as I prefer to have my windows cracked at 80mph than the AC. I like the noise of the road/traffic/wind to keep the drive interesting. :D
  19. Jamebarron88
    Houston
    I decided to reset my average mpg on the mfd. I'm now averaging 49.8 mpg after about one hundred miles. This is with my a/c on about 78F (outside temps are 95). I'm assuming the previous average being displayed was for the lifetime of the vehicle. So my improved driving style (Thanks in part to all of your tips!) didn't make much of a difference when being averaged into the previous 50,000 miles the one previous owner drove. Anyway I appreciate all of the feedback from you all and am satisfied with my 49 mpg.
  20. cwerdna
    12,544
    2,123
    SF Bay Area, CA
