Can I Leave it "ON" While I Get My Mail?
Discussion in 'Gen 3 Prius Main Forum' started by Downrange, May 24, 2010.
  1. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    Quick question which I haven't been able to find the answer to:
    If I leave the Prius in PARK, and take the key with me into the post office to get my mail, then:
    1. can someone get in and drive it away?
    2. will the car turn itself off when I get more than a few feet away from it?
    3. will I be able to continue my drive without going thru another "warm-up cycle?"
    Also, if I can leave it in Park while I'm outside it, can I also lock/secure it, using the remote? Or will that turn the car OFF (necessitating another warm-up cycle.)
    Guess you can tell, I don't like the warm-up cycle. It seems to cycle back to that, even when the car's only been turned off a minute or two.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    yes, no, yes
    no... the car stays on
    while inside turn your radio, screen, and A/C off or else you might as well just warm up again.
    you can lock the car by rolling the driver window down.. getting out.. locking it by hand, then auto up on the window.. use your mechanical key to get back in, as the remote is disabled
  3. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    very good question
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    What year Prius re your tips for?
  5. Tideland Prius
    16,623
    Depends on how warm your Prius engine is. If it's fully warmed (S4), there will be no warm-up cycle, even if it's been off for a minute or two.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    1. Yes, if they break the window. Lock the door manually.
    2. No.
    3. Yes, this is the whole point of not powering down.
    Even with the coolant temp at 106F the ICE won't turn on to warm anything up in the few minutes you are gone. I turn off the CC, headlights & audio. Sometimes I forget the headlights.
  7. zonie911
    zonie911 Member
    585
    Nashville, Tennessee
    I'm sorry, but you guys have more time than I do.
