ABS/Brakes issue after recall done?
Discussion in 'Gen 3 Prius Technical Discussion' started by wiluspyder, May 25, 2010.
  1. wiluspyder
    wiluspyder New Member
    Hi
    I had my 2010 prius at a dealership today for the ABS brake actuator ECU reprogramming.
    After I picked it up, I wanted to get the feeling for braking to see if I notice anything different.
    Everything was fine until a point where I was stopped at a red light and I stepped on the brake pedal all the way. Suddenly the traction control light was on and the brakes locked up for about 2 seconds.
    I can reproduce this each time I'm stationary and push on the brake real hard.
    Now, I don't know if this is a normal behavior as I've never tried to step hard on the brakes all the way before.
    Can someone who has a 2010 model confirm if this is normal?
    It seems a bit suspicious but I don't want to go back and leave my car at a dealership if this is not an issue.
    Thanks in advance for any help.
  2. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    It's called "hill holder" and it's normal. It's for when stoped on a hill and gives you time to move your foot from the brake to the gas pedal.
  3. wiluspyder
    ah, awesome, thanks for a very quick reply.
