Pet Barrier
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Inthewind1962, May 22, 2010.
  1. Inthewind1962
    Spring Branch, TX
    Just trying to see if anyone has a tried and true pet barrier for the back of the Gen III and/or is there one for the Gen II that will work? I've been looking at an angled pet barrier made by Trec Pet to accomodate for the back seat being somewhat in the way of a true vertical "up and down" from floor to ceiling. It would also have to be modified for length, but a hacksaw would handle that.
    If anyone has found a solution, chime in!
    Thanks
  2. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I'm thinking that the only thing out there that might work is a headrest-mounted pet barrier like this one (available here Doggie Blocker - Headrest-Mounted Pet Barrier, among other places):
    [IMGLINK]http://www.discountramps.com/petImages/doggie-blocker-1.jpg[/IMGLINK]
    [IMGLINK]http://www.discountramps.com/petImages/doggie-blocker-2.jpg[/IMGLINK]
  3. Inthewind1962
    Spring Branch, TX
    Thanks. Not a bad idea but its discontinued.
  4. Boo
    5,051
    488
    97
    Flushing, NY
    That's unfortunate.
    I think there are other rigid bar models (e.g., Walky Guard, which unfortunately is too tall). But this was one that sounded like it might fit height wise -- on the Gen II Prius there's only about 10 inches between the top of the rear seats and the headliner/roof.
    There are also models made out of netting.
  5. ajoyce
    ajoyce Junior Member
    PEI, Canada
    I have a large cage/kennel that fits (barely). Has a big cushion in it. My two small dogs love it.
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I've tried a couple of things, without much success. At first, I raised the rear headrests up as far as they'd go, and that kept her back there for a couple of short trips, until she figured out how to squeeze through. Then I attached her leash to her chest harness and tied it to one of the tie-down rings. That worked, but she really wants to be with the humans and howls so much it's painful. Next long trip, she's going to daycare. :)
  7. Inthewind1962
    Spring Branch, TX
    Well, after much research and driving around San Antonio to several pet stores that have the name "Pet" in it...(All of which had absolutely nothing even remotely resembling a pet barrier), I wound up walking down the pet isle in Target and lucked upon a collapsible kennel that fits in the back. $27!!! What a find!! I tried it out and he (Neo my black lab) has no issues with it! It's well ventilated, he can turn around, etc... I added a few pictures from my iPhone in case anyone needs a reference.
    It folds back up to about the size of a frisbee and has it's own vinyl carrying case.
    No more hair on the headliner, no drool on the seats or my daughters head (That one was kind of amusing... :rockon:)!! :D
    I guess I'll find out for sure when we go somewhere with significant miles involved.
    Thanks to everyone who responded.
      File size:
      47.9 KB
      1,453
      File size:
      47.6 KB
      1,405
      File size:
      35.7 KB
      1,490
  8. Crazy Canuck
    Crazy Canuck Junior Member
    60
    Calgary, AB
    2025 Prius
    XLE AWD-e
    That looks like a nice kennel, but it looks like it kills all your visibility out of the rear window...
    We were having this same problem, and the only solution we found was to clip a short dual-leash to one of the D-rings, and keep our two little guys back there in their harnesses. Was a lot of trial and error on finding the right "short" leash. Our older dog, who is used to riding in the passenger seat kept jumping over the seat back and hanging himself (in his harness, not by the throat)!
  9. Inthewind1962
    Spring Branch, TX
    CC,
    You're correct...it kills visibility but that's the only option right now. The amount of traveling we do on a regular basis is such that I'm willing to live with limited visibility.
    He just sheds soooo much! If I could have found a pet barrier in time that would fit and not kill my pocketbook, that would have been optimal. Alas, time has run out!
  10. LRKingII
    LRKingII New Member
    679
    132
    Idaho
  11. Crazy Canuck
    60
    Calgary, AB
    2025 Prius
    XLE AWD-e
    Now I have to show that link to the wife.... :)
  12. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Do you know what brand this is? seems to fit well in yours
  13. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The things that dogs have to go through just to get a ride. :(
  14. riceroni87
    360
    598
    Oxnard, CA
    Ive had my dog chew threw plastic trim in my ford edge. Ever since that happened ive been putting a wire crate in the back. A crate is just too big in the prius unless you have a v. Last thing I need is for my dog to chew up the prius.
    SCH-I605 ? 2
