Axle Schmaxle
Discussion in 'Gen 2 Prius Main Forum' started by ion, May 27, 2010.
  1. ion
    ion New Member
    Opps. This isn't supposed to happen to one owner in the space of a week. I just found out in addition to my MDF problem I am now the dealing with either a transaxle or transmission problem. About a year ago I detected a dry crunching noise coming from the left front wheel area of my 2004 Prius, when I turned right at a stop sign. I took it to my dealership and they said it was a case of 'dry boot', which they lubricated. Still, the problem persisted. This week I took it in for an oil change and asked that they look again. They assessed it as a defective left transaxle. They ordered a new one and installed it. Still the noise persisted. They removed it. They then talked to Toyota super techs and decided it must be the right axle. Ordered and instlaled that and nope, still the noise. Now they are looking at the transmission. Very frustrating. There goes the gas savings for the next 700 years, unless it's a warranty issue.
  2. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Ion,
    How many miles on that 2004? A more common problem to those symptoms is a wheel bearing. Do you drive over unpaved roads allot, that a boot would get torn up?
  3. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    I would find another "Toyota super tech" if their way of diagnosing a problem is throwing parts at it until the problem goes away. You should also ask for reimbursement for the parts that they replaced that were unneeded.
  4. qbee42
    3,079
  5. ion
    ion New Member
    Brief update: Car is still sitting in the dealership lot, waiting for word from above re the possible need for a new tranny. Toyota Canada is taking their time in dealing with it. I suppose they have their hands full these days. To answer an earlier post in the thread, the dealership is not, to their credit, trying to put any costs on me regarding their earlier misjudgements. New transmission is a $7000 job, so I sit and wait to hear what they plan to do or not.
  6. ion
    ion New Member
    130,000km, no rough roads, no torn boots.
  7. Mr.Vanvandenburg
    1,357
    580
    2020 Prius Prime
    My experience with worn CV joints is once the sound appears,(when turning and under acceleration, not straight ahead), it is very close to failure. It is a knocking sound. This happened on a Honda Accord, twice, and VW Vanagon, once. If there is such a thing as "dry boot" they didn't fix the problem undrying it. Just what in a transmission could fail that only is bad when turning?
    Cars can need repairs, all of them, the Prius still saves the money, the way I see it.
  8. justin time
    justin time Junior Member
    58
    Sounds like a CV joint. Had a Honda Civic Wagon that started making horrible noises and acting strange about two years ago. My first FWD car(other than an '68 Saab 96 for about 6 mos.), wasn't sure what it was but though it might be a CV(noise only coming from L front). After an emergency trip to a dealer and two to a local independent shop no one could find the problem, though they managed to find plenty of others. As it kept getting worse, took it one last time to the local and had them go over the front with a fine tooth comb. After replacing the L front axel, looking at the old one showed me how lucky I'd been. One of the CVs was at the point of catastrophic failure.
  9. ion
    ion New Member
    Anyone who followed my thread on axle problems should know that there is no happy ending. In spite of not fixing the problem I was charged $356 for labour. In the end the dealership removed and replaced both axles, only to find out that wasn't the problem. They of course had to then reinstall the originals. After consulting with Toyota Canada, the Dealership came to the decision that it might be a front bearing and assembly, although they wouldn't know until they replaced it. Which by the way was a suggestion made on this chat forum by a member at a cost of 0$. Today, I am struggling to get the Dealership GM on the phone to get him to explain his company's policy of 'a day's pay for a day of no gain'. And apparently, he's having trouble accepting my point of view, nothing gained, nothing lost...$$. Now the pain has gone from my wallet to that part of me that sits on it. Amen to this sorry event. Thanks to all with suggestions.
  10. northwichita
    481
    102
    29
    Wichita KS
    Are you up for opinions on this problem? I would be surprised that a wheel bearing would have the same 'problem' for over a year.
    Possibly.... the wheel strut mount .... actually I'd suggest taking the car to a good front end shop for diagnosis and repair. In the worse case scenario that the transmission is causing the problem, and you choose to replace it, there are tranny shops that will install used transaxles . Since the problem only occurs during turns, this seems very unlikely to me however.
    link about strut mounts I just found from kyb with video
    http://www.kyb.com/technical/what.php
