Most RELIABLE iPod/iPhone or AUX input for 2004 Prius JBL (no nav)?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Eug, May 25, 2010.
  1. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    I have a 2004 Prius (package B in Canada) with the upgraded JBL sound system with 6-CD changer, but no Nav.
    What is the most reliable method of introducing either an AUX input or an iPhone or iPod input into the car? I read success stories about DICE and Grom, but in the next thread there will be just as many stories about flakiness and other issues about these units.
    What is the most reliable method? I'm not really heavily concerned about iPod integration. I want the AUX support more than anything. I'm using a tape adapter right now and it sucks, even though though it is better than unwired FM. I read something about wired FM modulators but I don't understand how those work.
    P.S. If just an AUX, I can get it any time. However, if for an iPhone, I might wait, as I'll probably get a new iPhone within the year.
  2. sktn77a
    sktn77a Member
    303
    NC
    The GROM is a little newer than the DICE and doesn't appear to have all of the bugs worked out yet. I think most of the problems with the current DICE may be with the setup and/or firmware of the Ipod. You can get the DICE on Buy.com for $100. If you only want AUX, you can get them as low as $45 on e-bay. The most bulletproof Ipod/Iphone adapter appears to be the VAIS but it's also the most expensive.
  3. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    Hmmm... $45 on eBay is something I'd risk. Any specific models? Does Priuschat allow links to eBay for someone kind enough to provide a link?
    I'll look into the VAIS. However, I did a brief search they seem expensive, as you said.
  4. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    So, I found one unit on eBay. About $65 shipped (to Canada) and all they say is that it may or may not work, even if the plug fits.
    OK. I guess I'll have to look somewhere else. On eBay it seems most of the other units are Grom and Dice.
  5. sandia
    sandia New Member
    Colorado
    I have never found a satisfactory solution for my iPhone.
  6. JeffreyDV
    JeffreyDV New Member
    81
    New Milford, NJ
    I have the GROM aux adapter in my 2004 with JBL 6 disk changer and no NAV. I have only had it for a few weeks but it works well. Sometimes the stereo doesn't recognize it and it won't show up as an option (CD changer 2). Usually it comes back the next time I power up the car. Other than this, it works well and the sound is good. Very easy to install.
  7. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    if you have an Aux input jack somewhere, the least expensive,
    least intrusive, cleanest sound, cleanest install, most reliable way
    to get audio into the in-car audio system is this Belkin unit.
    You do not get any control of the music source with this unit.
    You control the volume with the in-car volume control.
    In addition to the Belkin unit, you will also need a short cable with
    mini-headphone jacks on both ends-- 12 inches is the shortest generally
    available -- to take the signal from the Belkin to the Aux-in jack. Radio
    Shack has one for a couple of bucks.
