Nav system thinks it's in another part of US
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dsgii, May 29, 2010.
  1. dsgii
    dsgii New Member
    Calif
    Our 2005 Prius nav system has decided we're nowhere or on a different coast when we try to get directions. The GPS shows the correct current location, but when we input a street address it can't find any nearby cities, and the last time it found a city it was Philadelphia (we're in San Francisco).
    Any clue what might be going on? We had to jump start it recently after accidentally leaving the back hatch slightly ajar for several days. The 50k-mile servicing was a week ago, meanwhile.
  2. qbee42
    3,081
    You need to set your current region. It's in the Nav setup section.
  3. dsgii
    dsgii New Member
    Calif
    Thanks -- I didn't see that setting when I looked around the Setup screens.
    Dan
  4. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    You also have to think about that (changing regions) when you travel. On my recent road trip I passed through 3 different regions. It isn't a problem until you want to input a destination and wonder why you can't find your city!
  5. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    ? If there's any system in the car that should be able to figure out where on earth it is, it should be the gps. Why should this be necessary? I can see it taking a bit to catch up when crossing from one region to another if it has to read a new bit of data into memory or something, but getting lost is silly for a gps system.
  6. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Well at least I wasn't the only one that had this problem recently! The button to change the region took me awhile to find. I don't recall ever having a GPS that you had to change region, though. In fact, I need to go look and see if I need to change it back or not!
    I'm waiting for the day that you can get a Google based GPS, including street views. I'm probably wishing to way too much, as I can only imagine how much data they've compiled with all that stuff!
  7. BAllanJ
    667
    78
    Kingston Ontario
    The one I use is in my Nokia N95 and it can overlay sattelite photos easily enough, but no street views yet...
  8. qbee42
    3,081
    It knows where it is, but it doesn't know where you are going. It isn't a mind reader.
    Setting the region controls the search area for destinations. It wouldn't be correct to automatically assume that a destination is in your current region.
