Luggage cover
Discussion in 'Gen 2 Prius Main Forum' started by 72randy, May 30, 2010.
  1. 72randy
    72randy New Member
    27
    Sherando, VA
    The retractor assembly no longer works on our unit. Do you know if it is possible to fix this or will we have to buy a new one and how much would a new one cost? Many thanks.
    51,901
    it works like a window shade. do you think the spring is broken?
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    If you have to buy a new tonneau/cargo/luggage cover, a new one will cost over $300.
    But you should be able to get a used cover on eBay for around $100 including shipping. As with all used items on eBay, the number of cargo covers available at any one time will vary a lot. Also, when you search eBay, you need to be flexible with search terms, e.g., "Prius Cargo Cover", "Prius Tonneau Cover", "Prius Luggage Cover", "Prius Cargo Shade", etc.
    Here are the current results for "Prius Cargo Cover" which tends to be the search term that yields the most results:
    prius cargo cover items - Get great deals on eBay Motors items on eBay.com!
    Good luck with fixing your cargo cover or getting a replacement cover at a reasonable price.
