Sticker in door seal question
Discussion in 'Gen 2 Prius Main Forum' started by TyAtkinson, May 31, 2010.
  1. TyAtkinson
    TyAtkinson Junior Member
    Enid
    Sticker on drivers side door seal says,
    Caution, Load Carrying Capacity Reduced
    Modifications to this vehicle have reduced the load carrying capacity by 63 lbs.
    I can picture it if i need.
  2. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    And your question is???
  3. qbee42
    3,079
    Someone installed 63 pounds of stuff. The next question: What sort of stuff?
  4. Patrick Wong
    18,200
    6,500
    My questions are:
    1) what modification was made that requires such a sticker?
    2) 63 lb is a tiny number. Who would care about this slightly reduced load-carrying capacity?
  5. TyAtkinson
    Enid
    Both posts above pretty much sum it up, Is this a normal sticker from the factory, what should i look into to verify what modifications were made, etc.
  6. qbee42
    3,079
    I have never heard of a sticker like this from the factory. Does your model have any special features? Did you buy it new or used?
  7. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Where was the point of entry from Japan?
  8. TyAtkinson
    Enid
    I bought it used, 09 with 9k miles on it.
    ill get a better picture but here it is.
  9. qbee42
    3,079
    Almost certainly the previous owner had some piece of equipment installed. It's very unlikely that any of us can guess what it was without a lot more information.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Really Secret Compartment for border crossings?
  11. bisco
    51,621
    ejection seat.:D
  12. TyAtkinson
    Enid
    If anyone wants to do said above ill document/post any pictures that could help identify this mystery item.
  13. Patrick Wong
    18,200
    6,500
    I recommend that you inspect the following:
    1) What is the tire size installed on the car?
    2) Look at the suspension, especially the coil springs. Does any part look like it is aftermarket?
    3) Do you see anything installed in the vehicle that looks aftermarket or amateurish, just like the label that you took a photo of earlier? If so, take some sharp photos and post.
  14. TyAtkinson
    Enid
    Ill post some photos later, but i received 5 letters from toyota today in the mail each with a sticker exactly like the one on my car, but stated in a long explanation that its car modifications that did not equate with the original capacity tire sticker on the cars as in package difference vrs stock weight.
    Ill copy the letter tommorow from the corollas at my work, with the long explanation and the sticker saying the load capacity has been reduced a whopping 10 pounds.
  15. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    A lot of our PDI's come from the factory with these stickers, why I am unsure. I even seen them with as low as "1lb" on the sticker.
  16. davidj08
    davidj08 Junior Member
    79
    northern CA
    Josh, What's PDI mean? I can't find it anywhere in acronyms & abbreviations.
  17. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Pre Delivery Inspection?
  18. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    A 63 lb sticker. ;)
  19. TyAtkinson
    Enid
    The sad thing was i searched all over the car and found these phantom footprints tracking stickers on the car so i figured i had some sort of gps unit hid away or something cool, felt a bit retarded when i found out they are nothing but super stickers that do nothing!
  20. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Two possibilities for the 63 lbs:
    1. Full size spare -- although it would require a larger "pan."
    2. Roof mounted light bar.
    Either/both might have been part of an factory "police package."
    :confused:
