What does your "Next Fill" Odometer Read After Fill Up?
Discussion in 'Gen 3 Prius Main Forum' started by ajoyce, Jun 2, 2010.
  1. ajoyce
    ajoyce Junior Member
    PEI, Canada
    I just bought 2010 Prius 2 weeks ago and have filled the tank once. The "Next Fill" odometer is reading around 830 kms. Just curious what others are getting so I know what to expect after "break in " period is over.
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Do I have one? Is this a Canada/Europe only thing?
  3. ajoyce
    PEI, Canada
    Press "Display" until you see the little car by the fuel pump (bottom of display) . The mileage shown represents the miles you have until you are empty.
  4. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    When I first got the car, it showed about 600 miles on the very first tank. (Yeah -- ok.)
    Now, after a fill, I'm showing around 440-460.
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I think it looks at the amount of fuel in the tank and the mileage (consumption) you have been getting. But I don't know how far back it looks. It, of course, recalculates continuously as we drive using updated figures. I think the reason the number is high when our cars are new is because it has no consumption data and uses some (high) pre-programmed number for consumption until it gets real data.
    I can't provide a reference for that, it's just WAG based on watching mine. If I have been averaging 50 MPG mine will usually read around 500 miles, which makes sense because it hits 0 miles to go when I have about 2 gallons left in the tank, about the same time the last pip starts to blink.
  6. socratesthecabdriver
    283
    31
    greece
    i have to agree with you mine is down also from 830km .to 650km
    i think it has to do with the type of driving you do trafic speed a/c .
    it samples past perfomances and it adhusts to a more real calculation suited to your town and needs. i dont think it has anything to do with the car not being able to come close to the manufacturesrs numbers!
    i actualy average 5.5-5.0 km/lt yesterday there was a major strike in athens and acompanied by demonstrations that created major gridlocks alover and i got up to 5.9 at some point but by the end of a 200km day its average whent to 5.6/100km.
    when i refiled the car after that shift The "Next Fill" odometer reading was way down ..i cant remember of the top of my head but it didnt agree with my thoughts for the car so whell.hehehe. i think if the city gets back to normal after a few fill ups with normal trafic that next fill mark will raise its self.
    ps. i run the a/c most of my days to control the smog that i breathe.i dont get cheap with my health!
  7. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    Just filled up today - read 515 miles to empty.
    Lifetime average (since 07/08/09) is 47.39 mpg (odometer/gallons used).
  8. Anniee
    Anniee Junior Member
    Maryland
    I just got my car a few days ago. When I got it, I do not recall a little car by the fuel pump. I just recall seeing that it gave an amunt of miles to go before refueling. Well I got gas today and this little car now appears by the fuel pump. and then I believe there is a number. But this does not appear on all the displays. Is that normal?
    Thanks, Annieeee
  9. gbarry
    gbarry Junior Member
    79
    S. California
    Not sure what you're saying, but since you just got the car...each time you press "trip" you get another display. There are two trip counters, then the distance to empty, then the odometer, and one more that's blank. Just keep hitting "trip" until you see the car and the fuel pump.
  10. vday
    vday Member
    312
    Israel
    Mine usual shows 710-730 KLM:(
  11. icebrg
    icebrg New Member
    Israel
    Mine is usually shows 830Km to empty after the fuelup....
    I average 4.3L/100Km thought...
  12. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Filled up today, shows 691 miles to empty.
    Wayne
  13. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    Picture says it all.
  14. vday
    vday Member
    312
    Israel
    fantastic
    you really get even better as it zeroes out way before really being empty
  15. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Lately 525-575 miles.
  16. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Mine shows about 650km at each fill up. I think the computer calculates the "Distance to Empty" by using the last lowest consumption to get the estimation. For example, if you drove a very short distance prior to the fill up and the trip used battery power more than ICE, then the "Distance to Empty" may show a higer number before your next fill up. I've been driving mine over 6 months and never seen it showing as high as yours. My average is between 600km to 620km before I fill it up again.
  17. Fuel Miser
    86
    22
    Ontario, Canada
    The picture I posted was right after a fill that took me 700+km. So pretty accurate, no trickery here. I just have a very optimal travel route for going to and from work everyday. Part of the reason a Hybrid made sense to me.
  18. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I usually get 700km. I never really check because it is not that "reliable", meaning that when it gets to 0km, you have in fact 7-10 liters of fuel which is a *lot*, you can drive at least another 150-200km before you go dry (if you average 5L/100km).
    But I need to check again more in detail - I need to write down once I fuel the new value and see how many kms I am actually driving before I reach the last blinking bar. INcluding the reserve, then I can calculate on which fuel consumption is the autonomy calculated.
    As per Owner's Manual:
    "Displays the estimated maximum distance that can be driven with the quantity of fuel remaining.
    • This distance is computed based on your average fuel consumption. As a result, the actual distance that can be driven may differ from that displayed.
    • When only a small amount of fuel is added to the tank, the display may not be updated."
  19. socratesthecabdriver
    283
    31
    greece
    i averaged 4.5-4.6 liters to 100km 2 days in a row thats about 550 km and my [till empty whent up from 650 to 750 till next fill.. wow its alot more relaxing driving this car the way its ment to,than the way of a hecktik cabdrive way!
    I HAVE SEEN THE LIGHT MY FRIENDS!!!!!!!!!!!!!!!!!!!!!
  20. JaymzB0nd
    JaymzB0nd Junior Member
    68
    CA
    Mine usually says 525.
    I noticed the last time my tank was low, it said I had 20 miles worth of gas left in the tank but when I filled up, it filled 8.7 gallons, meaning there was at least 3 gallons of gas in the tank yet showing I could only drive 20 more miles. Anyone experience something like this? Doesn't make sense to me.
