Ice pattern on windsheild matches swirl pattern on dashboard
Discussion in 'Gen 3 Prius Main Forum' started by flbntz, Dec 27, 2009.
  1. flbntz
    flbntz My First Toyota
    48
    Elizabethtown, PA
    Woke up this morning to see my car ice-covered, and the windshield had a beautiful swirl pattern to the ice. Almost hated to melt it. Realised later the swirl pattern matched the swirl pattern of the dashboard. How could this be? The black dashboard should absorb light, not relfect it. Any ideas, similar sightings?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I think you've hit it, the black dashboard is absorbing light, absorbing light and heat through the opaqueness of the forming ice, and the variations in the pattern are being mirrored as the ice forms. Try leaving a picture of Jesus on your dashboard next time....you might be able to make something that you can sell on e-Bay for a lot of money.
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    Pics next time would be nice. Esp if you try the Jesus thing. :madgrin:
  4. DanielRoss
    DanielRoss New Member
    San Jose
    Actually, that is probably not the cause. The initial sunlight passing through the windshield would be uniform. It would hit the dashboard and some of it would be reflected. The reflections would not be even, because of the swirl pattern of the dashboard. However, the reflected light would not necessarily have the same pattern as the dashboard when it bounced back and hit the windshield. To test this, put a white sheet of paper on the inside of the windshield and look at the light pattern. It is entirely diffuse if the dashboard and the windshield are separated by more than an inch.
    I thought a comment would be worthwhile because when I first got my Prius a few weeks ago, I noticed that looking out the windshield, the other cars and street appear to be wavy. I assumed this was just due to the reflection of the dashboard I was seeing in the windshield, but when I put paper on the dashboard so that I could look through a part of the windshield that had no reflections from the dashboard, the waviness is still there. It is either a defect of my eyes or brain, or the glass of the windshield is actually not smooth.
    That would also explain the waviness of the ice patterns.
    Is everyone else's windshield wavy?
  5. bearames
    bearames New Member
    beverly hills
    That swirl pattern is horrible. My dash got armoraled shiny at the dealer and now I can barely see out the windshield because of the reflecting SWIRLY GLARE during the day. I don't know what to do except apply a cloth dash cover if I could find one. Any suggestions ?
  6. bearames
    bearames New Member
    beverly hills
    BTW, I think maybe the swirl pattern on the dash is actually an imitation of a naturally occurring design of nature, especially in ice crystals. You may have only recognized the similarity.
  7. jsharpe
    jsharpe Member
    111
    26
    Although our dash hasn't had any gunk applied to it I regularly marvel how dark it looks through polarized sunglasses. Take them off or tilt your head and it looks like a normal (dark but shiny) dash material. Put them on and it turns to black velvet.
  8. The Electric Me
    9,083
    5,801
    How could I be wrong? The Ice Image of Jesus and Rosie O' Donnell on my windshield told me I was right...
  9. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Have the dealer un-armor-all your dash. That's the stupidest
    thing they could have done -- yes, I realize it's common practice
    but now you see the results. If that means they buy you a new
    dash top, aka big piece of plastic, so be it to get back your
    AS-DESIGNED MATTE FINISH. Tell them it's a safety issue and
    your next call is to bring the corporate smackdown on 'em.
    _H*
  10. bearames
    bearames New Member
    beverly hills
    I'd be delighted with wavy. As it is I hafta' stick my head out the driver's side window to see in front of me. Problem is, the windshield lies so flatly across the dash to reduce wind resistance that we're trying to see through much more glass than if it was on a more verticle plane. That probably causes some waviness and it most certainly increases the amount of reflection coming off the shiny dash.
  11. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    This is a safety issue and must be dealt with. Going from best to worst, the options I see are:
    * Make appointment to have dealer restore dash to correct finish
    * Find out exact product used on dash, call manufacturer to find out what chemical will remove it, obtain and use chemical.
    * Have dealer buy Matte dash cover.
    * Have dealer replace dash.
    * Do nothing, wreck car, spend number of years in court arguing about who should buy next car.
  12. bearames
    bearames New Member
    beverly hills
    That's good advice sir and I thank you for it. The Toyota Dealership in Santa Monica will do everything to avoid doing anything if past experience is any gauge. I'll never buy a new car again, expecially from them. In the meantime, never smear armorall on your dash !
  13. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I think you are making this up. I have never seen any such thing in Miami.:glare:
