What's your GenIII Obsession?
Discussion in 'Gen 3 Prius Main Forum' started by drsbm3, Jun 4, 2010.
  1. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Each and every tenth of an MPG...
  2. Luis138
    Luis138 Angel Rat
    68
    Downey, CA
    I am obsessed with washing it, waxing it and polishing it to a mirror like surface; a little hard to do on a blizzard pearl.
    Luis
  3. drsbm3
    drsbm3 Junior Member
    34
    manassas
    Luis, I am sure you are very proud of your perfectly polished prius as I am with Max Wax. It's a great car and deserves a fine finish.
  4. Luis138
    Luis138 Angel Rat
    68
    Downey, CA
    Indeed I am. I have yet to try Zaino which from I gather is the best out there.
    Luis
  5. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I'm also obessed with keeping the power display running on ECO. It's almost like a video game.
    But like many here, I do let it go into the "PWR" range if necessary as to not be like the driver mentioned on the first post. Also obsessed in keeping the black clean and into waxing it often.
    And worse obsession is getting rid of all the rattles. Daily battle.
    Luis138, I'm in Downey too!
  6. drsbm3
    34
    manassas
    I'm am obsessed with getting a 60 mpg tank and have come close several times, but have not broken thru. My weekend trips are killing my mpg as they are usually shorter length, so its difficult to make up for the initial ICE start up. I could leave it home on weekends and get to the vaulted 60 mpg level but this seems like cheating. I feel like I have to do it given my own day-to-day circumstances. Any advice is appreciated.--S
  7. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I definitely am more careful driving when someone is in the car with me and when someone is behind me. Other wise I stay in eco mode as much as possible. Also try to get up to speed and then come off gass and get into electric mode.
    I'm at 52mpg on 2nd tank, including a 200 mile trip with highway (over 65mph) and also using air most of the way...
