Does the 2010 cvt transmission have a oil pump?
Discussion in 'Gen 3 Prius Technical Discussion' started by kevindeschamp, Jun 4, 2010.
  1. kevindeschamp
    kevindeschamp Junior Member
    Colorado
    Gen III Generation III
    Thank you
  2. bwilson4web
    16,122
    Yes.
  3. kevindeschamp
    Colorado
    The gen III has a transmission oil pump need what does it cool?
  4. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    ARRG. The Prius doesn't have a CVT!! It has a planetary gear set that interfaces two electric motors and the ICE with the front wheels.
    It does put on a very, very good illusion that it has a CVT.
    /rant off
  5. bwilson4web
    16,122
    It has:
    • gears - they need lubrication, not cooling, lubrication
    • stators - oil mist cooling
  6. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Are you sure? I thought that the G3 also had a planetary CVT like the G2.
    According to the official Toyota website, it states "Electronically controlled continuously variable transmission (ECVT)"
  7. qbee42
    3,079
    The G2 and G3 both have the same basic system, and in neither is it really a CVT in any mechanical sense of the word. Toyota calls it that because they need to use some term that normal people can easily understand. If they said "Fixed mechanical gearing with electronically controlled electrical power split" very few would understand that they were talking about a transmission. The "E" in "ECVT" hides all of the details.
    sadhu and silentak1 like this.
  8. silentak1
    893
    28
    LA
    Ah, thank you for the insight Tom...and I've been on PC for 5 years now...geez. Truly shame on me.
  9. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    So, does the FMGECEPS have an oil pump on it? :D
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Gen1 had a tiny oil pump for eCVT.
    Gen3 seem to have an oil pump too (not sure if it is for eCVT) and it is gear driven.
    Source
  11. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    I thought we had a long thread about this CVT thing. Besdes the OP is asking about Oil pump.
    Lets just drop the CVT or NON CVT issue. To the OP it is CVT so lets just not confuse him.
    And yes it does have a Oil Pump.
