Questions about a G3 Prius purchase
Discussion in 'Newbie Forum' started by Surak, Jun 6, 2010.
  1. Surak
    Surak New Member
    Kentucky
    Hello, I have lurked for a while but I am getting closer to purchasing a car to replace a 12 year old toyota w/200k
    I have read a lot and want to go with the prius but here are some questions i still have
    1. what to get fixed before i leave the dealer: a) reverse beep, B)adjusting position of auto-dim rear view mirror, C)on a V, get the dealer to tilt LED headlights up a little more, what else
    2. I read that braking in prius on wet roads is not good. I cant believe a car would be so popular that didnt brake adequately in rain, so what is that about? And what about snow? Taking it slow in snow should be ok, or is it just not driven in snow
    3. Is NAV system good enough, or am I better off just getting a V with no NAV and buying it aftermarket with rear view camera?
    thank you in advance
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    1. I think that would be good.
    2. The brakes are fine on the prius. But you need to know that it has regen braking. So it will only use the front wheels to drive the motors to generate electricity, so if your tires drop of a uneven surface, or hit something slick, the car will stop the regen(I think to prevent wheel lock up so you don't lose control) then it applys the normal friction brakes. There is a slight delay that may make you feel worried. It's normal and only has happened 2 times to me over 20,000. But it you want the brakes to be just like a normal car and will have a fit, and be posting on here every day about how unsafe the prius is you should by another car that doesn't have regen brakes.
    3. I don't know.
  3. silentak1
    silentak1 Since 2005
    893
    28
    LA
    1. You've done well on your research. Make sure that they don't charge you for those items...
    2. It's more, this is more related to the tires you get and tire pressure (people say OEM tire pressure gives good braking "feeling" vs. high pressure and worse brake performance). Also the traction control is touchy on bumps, but no fix for that really.
    3. I don't know if you can even get a V with no nav, at least not in California as far as I know. The nav is okay, the $150 Garmin and TomTom ones have more "features" but to each his own. It's good enough for directions but not exactly worth $2000, but you get a touch-screen too for your radio and other audio channels.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Yes you should get them to agree to set the reverse beeper to one beep and turn off the extra seat belt beeps, if you wish. You might want to wait until you drive the car at night to see if the headlights need to be adjusted or not. Some have been OK as delivered, some, such as mine, were aimed so low you would overdrive them at 30 or 35 MPH. I would get them to agree to re-aim them if needed however, unless you wish to do it yourself (it's easy to do). It's always a good idea to get them to agree to such things before you sign anything. I do not have the optional port/dealer installed security system but from posts here I don't think you should get one, same for wheel locks and cargo net.
    They will try to sell you and extended warranty and a maintenance contract, don't buy either one. You have 3 years/36K miles to decide if you want an extended warranty or not and if you do you can get the Toyota Platinum version through this site for about $1055. Maintenance contracts are not a good idea because they tie you to one dealer for maintenance and usually don't save you anything anyway. Those things are only a good deal for the dealer, if they weren't they wouldn't sell them.
    Prius brakes are fine. The car does pretty good in the snow as long as it isn't to deep just like most cars, 3 or 4 inches should be no problem.
    The main advantage to built in nav systems is that they are built in. I get by with the Toyota system because I bought it but my Garmin is a lot better. As stated above the audio and phone interface with the nav system are nice to have and it does have a good back up camera display. If you are going to buy a Prius V I would recommend spending the extra money and getting the ATP, the DRCC works great.
  5. Eoin
    Eoin Active Member
    593
    116
    Long Island
    What do mean by adjusting the position of the auto dim mirror? Mine is fine.
  6. Surak
    Surak New Member
    Kentucky
    looked but couldnt find thread that for some the mirror does not auto-dim, apparently there is issue with spoiler blocking some sensor. For some, because of the position of the mirror then, the mirror does not work and headlights behind you are quite strong. The mirror itself works, it is the position that is the problem.
  7. forty2
    forty2 Junior Member
    Seattle, WA
    You can make the mirror adjustment on your own without any tools. You outstretch your right arm(left for RHD models), grasp the mirror firmly, and move to desired location. Repeat as needed.
  8. Surak
    Surak New Member
    Kentucky
    What happens if you are following someone in distance and maintaining that distance and someone else comes between? Does the DRCC respond appropriately?
  9. tumbleweed
    4,067
    692
    Eastern Oregon
    Yes it does. If they are going about the same speed you are it will just drop you back gradually, it they move in front of you and slow down it will brake as needed. Another thing the owner's doesn't make clear, you have a choice of 3 following distances 1, 2, or 3 seconds back.
  10. blase
    blase New Member
    NE Ohio
    I just went through a pretty snowy winter in NE Ohio and my Gen 3 IV did just fine. I did put Bridgestone Blizzak snow tires on it but had no trouble with traction or skidding. Remember you have the gas and electric engines up front so plenty of weight for the front wheel drive traction. I traded in a four wheel drive SUV for the Prius and I really think the Prius did just as well as the SUV in snow.
  11. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    1. Get the beeps addressed if you can, you'll appreciate it. If not, well, after living with them for awhile, you'll really, really appreciate it when they are off. I'd say that you should at least drive with the headlights first to get an idea if they are too low or not. Give the techs something to work with.
    2. No idea on snow. Got mine at the end of March, but haven't driven through too much rain. Performance was fine.
    3. The NAV is built in. No losing it. No stealing it. It provides a nice big screen for the back-up camera (which is very nice because it gives yet another "view" out of the back of the car). I've not had a GPS unit before, but this one seems to work fine. Most people feel that the cost is prohibitive. I like that it is fully integrated and I don't have to worry about it.
  12. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    1. I believe you should live with the car for a bit so you can determine which customizable settings annoy. Get the dealer's position about free changes up front. No charge changes a couple of times is reasonable.
    2. Braking isn't a problem if you know how to drive. For better performance on wet pavement inflate the tires to max sidewall pressure. I bought the V-AT toward the end of December between snow storms. No handling problems. Snow & ice accumulated on the nose blocked the radar.
    3. If you want the backup camera you're buying the NAV. Toyota's NAV lady & Garmin's are about equally retarded. Toyota's doesn't have all the features of a current Garmin. I miss the speed limits.
    Go to www.aaa.com to build a car & get dealer quotes. Tonight's AAA price for a base V around here is $26783. Invoice is $27383.
    Stay away from all the PIO. The paint scratches easily. Your first trip should be to install VentureShield or 3M film.
  13. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    A tip to try: I negotiated with the dealer to give me the next upgrade to the NAV DVD for free when it comes out (probably in 2011). It was easy for them to say yes because they didn't have to pay or give me anything at the time of sale.
  14. Tideland Prius
    16,621
    2. Depends on the tyres. Given that you're going with the V, you're getting a much wider contact patch and better tyres (the 15" alloy models come with eco tyres) You should be going slow in any car in the snow (even if you have AWD/4WD). A good set of snow tyres will get you there and home.
    3. I would test it out yourself. Given the hugely varied opinions here on PC, it's definitely one of those things that's subjective and a personal preference. I like the large screen (used to it on the old Prius) and the camera is easy to see on a large screen (In Canada, models without nav have the backup camera shown in the rearview mirror). I have both the built-in and a TomTom ONE. I do like the built-in because it has a large screen, more POIs and I don't have to lug my TomTom around. If I need to get somewhere and I forgot to bring my TomTom, I have a nav unit built into the car. It also comes with XMNavTraffic.
    If you do a lot of highway driving, I would suggest the AT Package. The DRCC is a fantastic feature and makes for an even more relaxing drive. LKA helps (esp. if you have long hours. It could potentially save your life by not letting the car smash into the cliffside or cross the median into oncoming traffic... though you shouldn't be driving if you're that tired but it's a good safety feature).
  15. lvjbird
    lvjbird New Member
    nevada
    I just bought a new 2010 myself and took it on a long trip the next day.
    The NAV system is the only thing I'm not thrilled with. I have a Garmin and much prefer it over the new one.
    One of the biggest issues is that you can't do much with it while driving. In fact I was hoping to find out if this feature can be over-ridden. (anyone know?)
    If you want to search for a rest area while driving - forget it! You have to pull over and be in park first. (and this is with the passenger doing the searching!
    Everything else about my new Prius I love!
  16. Tideland Prius
    16,621
    It used to be hackable... then Toyota found out haha.
  17. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    There's a 3rd party hardware hack for that:
    http://priuschat.com/forums/gen-iii...-prestigious-society-navi-hack-installed.html
    and also a homemade version:
    http://priuschat.com/forums/gen-iii...-override-speed-sensor-bypass.html#post904356
  18. Surak
    Surak New Member
    Kentucky
    thank you all. I ordered the V with NAV today. I pick up the car next week. decided to not get AT, rather use limited funds for something else.
  19. Surak
    Surak New Member
    Kentucky
    sounds like some common sense is the main thing needed. still it was disturbing to read about "problems in snow" but otoh, the car continues to sell just fine, so i thought they were exaggerated.
  20. Tideland Prius
    16,621
    http://priuschat.com/forums/gen-iii...33-prius-in-deep-15cm-loose-snow-results.html
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/73006-traction-in-deep-snow.html
    http://priuschat.com/forums/gen-iii...-modifications/71626-got-snow.html#post998252
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/70557-tested-out-trac-vsc-abs-tonight.html
    Videos embedded in post #10 and #11
