The Bladder "suques"!!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Devil's Advocate, Aug 2, 2005.
  1. Devil's Advocate
    922
    Las Vegas, Nevada
    Alright here are the facts:
    Highway driving, approximately 80 MPH
    mountains surrounding Las vegas
    9 of 10 bars showing on fuel gauge
    108 degrees F
    Check Engine light comes on
    Dealer reads as "lean fuel mixture"
    WHY?
    Altitude and temperature? maybe, but then the damn light stays on!
    further complaint about the damnable bladder. Even when I drive for 30 miles on a blinking last bar I have only rarely been able to put more than 10 gallons in and then when I was able to put in over 10 gallons it was like 13 gallons. This only happened twice and that was months ago. Last four months the most I have been able to put in is 10.7 and that was when I ran out of fuel, so I know the tank was empty.
    The bladder SUCKS!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Feel better now?
    It is a pain, but one I'm willing to live with and work around for the sake of reduced emissions. I strongly suspect the 3G Prius will have a better system.
  3. c4
    c4 Active Member
    607
    51
    How are the emissions on the European Prius (without bladder) compared to the North American model?? I'm betting that they're not significantly different, and they're still better than just about anything else on the road today..
    I think it's a reasonably expectation that when I go to fill up my car, that I do get it filled: on a 45L tank, I would expect that a fill would be in the 43-44L (11.3 Gal) range, or in other words, a 95% fill.. The typical 80-85% achieved with the bladder is just not acceptable.. Even less acceptable are the cases where some form of vapor lock occurs and the filler stops after dispensing barely a gallon of fuel into an "empty" tank or the cases where the filler appears to stop normally and then gas gushes out a few seconds later- again, probably due to trapped vapor in the bladder.. Then there's the linkage of the bladder to the fuel gauge inaccuracy problem.. This all points to a fundamental design flaw in the fuel tank system.
    If fuel system emissions are an issue, I'd vote for a bladderless pressurized fuel system such as used in other vehicles.. You still get the low emissions, but filling works normally and the fuel gauge is accurate..
  4. kirbinster
    kirbinster Member
    602
    Morris County - New Jersey
    Is this a problem only with the newer cars, or only on certain individual cars. When I fill my '02 it generally takes just about or slightly more than what I calculate from taking the MFD miles divided by the MFD mpg. Never had a short fill like discussed here.
  5. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    My car always clicks off early. I generally get 2 gal more in by just clicking and clicking,
    with like 0.05 gal going in each time. Every so often I removed the nozzle to make
    sure it wouldn't spill, but it never got to full most of the time.
    Last time I changed techinque to just puttiing in the very tip of the nozzle, so the fume holes
    just suck air. They really aren't serving any purpose with bladder! So that made the
    clicking stop almost entirely and I could fill slow to the gurgle point.
    Also makes it irrelevent whether the fume side is clogged or not.
  6. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I have also found that this technique works well. I refuel with one or two bars remaining and consistently fill to 9 - 10 gallons. Only once has the gurgling actually resulted in a minor overflow. There was perhaps a teaspoon of gas that spilled over the filler neck before the gurgle stopped.
  7. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Why is there such an obsession with getting the most miles out of a tank? Is getting 60 MPG from 11 gallons resulting in 660 miles per tank really any better than getting 60 MPG from 9 gallons resulting in 540 miles per tank?
    Come on people, 60 MPG is 60 MPG regardless as to whether you go for 7, 9, or 11 gallons between fill-ups.
    What does it really prove to foolishly drive until you run out of gas in order to brag that you got the most miles on a tank? Does that really make you a better driver than someone who got the exact same MPG as you, but didn't feel like running out of gas on the highway?
    Just fill it up when you get down to 1 or 2 bars and be done with it. It's the miles per gallon that matters, not the miles per tank.
  8. kirbinster
    kirbinster Member
    602
    Well said Marlin!!!
  9. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Please, all that have an issue with their Prius, sell it. Period. There are others who would love to enjoy this car. It seems silly to complain about gas capacity.
    No, really just sell/trade the damn car if all you have are complaints. Sheesh, get over it and get on with life. Get something you enjoy, don't be 'stuck' with such a device that causes so much anguish. Don't be the person who's in therapy because 10.5 gallons (or even 9.3) is not 11.9.
  10. KathyY
    KathyY Member
    109
    Maryland
    Once I had the fuel tank fix done mine seemed to perform lots better. I usually pump the amount of gas that I figured I would need based on the gauge and mileage. A couple of times I have had the last bar flash and once got the add fuel notice. I usually try to fill at two bars but sometimes it does drop from two to one very fast. I did notice that it takes a lot longer to get to half a tank than it takes to drop the remaining bars. Before the fix I was putting in around 6 gallons and now put in 9 or more every time.
  11. tomdeimos
    995
    Lexington, MA
    Did you see the note in here somewhere to put the cap on quick once you hear the gurgle?
    I think it was in one of Ray's posts?
  12. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
    No, I hadn't seen that suggestion.
  13. Devil's Advocate
    922
    Las Vegas, Nevada
    First: No matter how I click or pull the filler nozzle in or out of the filler neck I RARELY get over 10 gallons in the tank, and I always wait till about 30 miles after the last bar starts to blink, ALWAYS. (Oks easy in LA there's a gas station every four blocks)
    Second: I drive A LOT, that's why I got the Prius. I average over 100 miles a day. With the tank only holding an average of 9-gallons I am losing between 2and 3 gallons of fuel. Subsequently I am loosing 100 to 150 miles in cruising range. I think that is significant.
    Third: I believe the sytem is responsible for my frequent error codes relating to "lean fuel mixture" which occur when whether there is 1 or 9 bars showing on the fuel gauge.
    fourth: A car professing that it is the next evolution in transpotation should NOT suffer from such a defect!!!!
    Fifth: This doesn't mean thaI wouldn't recommend the car to anyone, but it requires what I consider an uneccessary caveat when I do recommend the car since as an Attorney I've got full disclosure on the brain.
  14. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    Sorry, but the fuel tank itself has nothing to do with this. If it did, you would get misfires, not lean burn. The lean fuel mixture is most likely caused by a fuel delivery problem associated with the fuel pump, fuel pressure regulator, oxygen sensor, EGR valve, fuel injector(s), or the engine computer (either bad electronics or poor software calibration for the lean mixture diagnostic). Based on your stated fuel economy I have ruled out a vacuum leak or other potential cylinder problems. Bottom line is the engine controller is not able to adjust the fuel injection flow (not enough fuel is being provided) to properly mix the gas with air. Or so the computer thinks based on sensor readings.
  15. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Actually, I had it start gurgling when I tried to pull the nozzle back out. I had forgotten to pull the nozzle out every 1/4 gal. after first clickoff.
    I was able to put the NOZZLE back in and slowly bleed the air out a bit at a time by moving the nozzle.
    9 gallons versus 12 gallons at 60MPG is 180 miles!
  16. ReneGS
    ReneGS New Member
    San Diego, California
    <div class='quotetop'>QUOTE(DanMan32\";p=\"115712)</div>
    Ive never averaged that high (51.1 is my best to date) but a few gallons does make a difference. Especially for those of us that have long commutes.
    One or two extra gallons can make the difference between making it all the way home (or to work) or having to fill up before I leave. Where I live Gas is a lot more expensive than near my work. Its because of that I'd rather wait until Im getting off of work to put gas than before I go to work.
  17. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    I have noted, in my short time here, that there is an obsesive like deal with how many miles you can squeeze out of a tankful.
    I come from the land of VW, where gas mileage sucks. If I got more then 25 MPG in my nB, I was happy. And, at the end of my time with my SCION (rollin' on 18' rims), I was barely getting 22-25 MPG. First fill up with the PRIUS? I got 60 MPG. I almost danced right there.
    I have said to friends, that I would have been just happy to have more then 30 MPG.
    I drive in the city almost all the time. So gas stations are very close. I am not going to drive my tank to the minium for bragging rights.
    That is my ¢.02 on it.
