Inverter temp valve
Discussion in 'Gen 2 Prius Technical Discussion' started by Dispie, May 4, 2010.
  1. Dispie
    Dispie New Member
    West Texas
    During the past month I had 2 times the "check engine" light on (just comes up in the morning, stays on until evening and then disappears next morning). Today I went to Toyota dealer to check what's going on and they told me that I have a problem with "inverter coolant valve" which does not function the right way and makes the inverter overheated. The pointed that it is not the pump, but a valve which is a part of inverter. And they asked $440 for the part+labor. To me the price sounded too high and I tried to research what kind of valve it is and the only thing comes to my mind is the temp control switch (which costs less than $100).
    Has anyone experience similar issue? If it's the temp switch, how difficult is it to change it manually?
    p.s. 2 month ago I went to the same Toyota dealer to do a maintenance and they charged me $700+ for various operations. Later I discovered that for my 90k miles they did not do what was recommended by Toyota for Prius but did other things which were not in the list of recommendations. So I cannot say that I trust them...
  2. Patrick Wong
    18,200
    6,497
    If the inverter is overheated, that should not cause the "check engine" light to come on. Instead, the hybrid vehicle icon in the MFD, and the ABS/VSC warning lights will appear as the inverter overheats and the DC/DC converter shuts down. Further, I'm not aware of a valve regulating inverter coolant flow.
    Typically, when the check engine light appears, there is a problem with the engine. There is a valve that regulates engine coolant flow between the cabin heater core and the coolant heat recovery system canister. That valve is known to fail from time to time. Perhaps that is the problem with your car.
    We might have more to comment if you can obtain the DTC logged by your car.
  3. Dispie
    Dispie New Member
    West Texas
    Maybe they were talking about this engine coolant valve. Actually they pointed out that it is a problem with a valve of the inverter not the engine. So far I could not find anything myself about a "valve" on the inverter side.
    I'll try to find out the codes.
  4. Dispie
    Dispie New Member
    West Texas
    Ok, finally I got the report. Apparently it is P1121 - Coolant Flow Control Valve failure (as described in TSB EG001-08).
    As long as my car is about to reach 100k miles I was going to replace the coolant. Thus it's going to be just a small additional work to replace the control valve with the coolant change.
    P.S. this time they offered $350 for the service.. Kind of surprised with this Toyota dealer.
  5. dddrrr
    dddrrr New Member
    Valdosta, GA
    I just had my HV cooling system pump valve changed on 6/8/10. And the coolant was changed , and a diagnostic report on all systems. The price was $360.47.
    My master waring light came on and the check engine light.
    My Auxillary Battery went bad a few week ago and the same lights came on plus acouple of others the VSC and I don't remember the other. There is a test you can do to check your Aux battery.
  6. locknload
    locknload Junior Member
    Northeast
    The 'check engine light' activated on my '05 Prius. It had 118K miles when this happened last week. Toyota service diagnosed it and said it was the 'control flow valve for the inverter,' looks like P/N 33 CPR6 4.00. The repair included this as well as P/N 16670-21010 Valve Assy; and P/N 00272-SLLC2 Super Long Life Cool. They said if I was to drive the car without repairing it, I would damage the engine. Is this exactly what you had? Or has anhyone else had this problem also? I never had any problems with the cas prior to this. The cabin air filter and the engine air filter were also replaced. I need some help on this.
    Thank you.
  7. locknload
    Northeast
    Also, the Toyota mechanic who serviced my car said my car's problem is v ery rare. in fact only one other Prius had the same problem as mine.
  8. Patrick Wong
    18,200
    6,497
    This is the same problem as discusssed earlier in this string: the failed valve switches engine coolant between the cabin heater core and the coolant heat recovery canister. The implication of the failure is that 1) your cabin heater might be impaired and 2) the engine may emit more emissions upon warmup. Engine damage would not be an issue.
    The valve has nothing to do with the inverter and has a misleading name.
  9. locknload
    Northeast
    Thank you very much Patrick. You have been extremely helpful, and I certainly appreciate it!
