iPhone Questions
Discussion in 'Gen 3 Prius Audio and Electronics' started by stream, Jun 4, 2010.
  1. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I’m considering getting an iPhone 4G (or HD, or whatever it’ll be called) when it’s released (next week?), and have a few questions for those with the iPhone 3GS.
    I have a Prius V with nav (took delivery a year ago this week, so no USB, just aux input).
    If I pair for BT phone & BT music streaming:
    --when listening to a track, what info (track, artist, etc.), if any, will appear on nav screen?
    --if a call is received & answered while listening to music, will it pause the music, allow me to answer call, and after I hang up, continue the track?
    --can I control anything (other than volume) using the car’s controls (for example, skip to next track)?
    --after initial pairing, will it connect automatically when I turn the car on?
    Overall, what is your level of satisfaction with the BT streaming (sound quality, ease of use, etc.)? Any other specific comments/likes/dislikes also appreciated.
    TIA
  2. dpaul
    dpaul New Member
    Toronto
    ARTIST, TRACK
    YES
    START, STOP, VOLUME, SKIP
    YES
    I'm very picky about sound quality - didn't really expect much from the streaming functionality. In fact I am very impressed. Even have my iPhone Sling media sound going through my car sound system. It works great!
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I have to disagree, unless I'm doing something wrong. When I BT stream my iPhone 3G to the car, I get no artist or track info, no track control via the car, only the phone itself.
    When a call comes it, it does pause.
    The sound quality is fine, better than the AUX port. But, the volume is lower (I've tried to increase the volume via the iPhone) than the SAT.
    If I'm doing something wrong, let me know, as I'd love to have some control via the steering wheel when streaming from the iPhone.
  4. noah82
    noah82 New Member
    The iPhone does not support the latest version of the AVRCP profile, which includes track, artist, and next/previous track control. Once Apple includes this, you will be able to change the track from your steering wheel.
    Keep in mind that as of the latest 4.0 beta, this is NOT included, so we might have a long wait until Apple adds this.
  5. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    noah82 is correct.
    As of now (iPhone 3.1.3) with BT Audio Streaming:
    1. No info on nav screen (none, zip, zero).
    2. Since the call is actually being handled by the phone it functions the same as if you were listening to your music outside of the car on your headphones.
    3. Only volume works from steering wheel.
    4. It connects and starts playing as soon as the BT connection is established as long as the input on the Nav is left on BT.
    I am hoping iOS4 will change this and implement AVRCP 1.3+ but from what I'm reading it doesn't look like it.
  6. stream
    2,977
    452
    Long Island, NY
    Another question on contacts. I have ~500 contacts in Outlook, that I'll sync with the iPhone. Will they all upload to the car, and will it happen automatically every time I start the car (as I add/delete contacts)?
  7. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    You can upload your contacts manually but not automatically. It's a quick and easy upload when you want to update the contacts.
  8. davidtx
    davidtx New Member
    Dripping Springs, TX
    When I was test driving, I uploaded several hundred contacts to the car and then found it EXTREMELY cumbersome to use the car's interface to find one. When I was pairing with my new Prius this afternoon, I noticed that you can restrict the contacts that the iPhone syncs by selecting one or more groups, as well as a couple of other criteria. I'm going to restructure my contact groups so that far fewer contacts end up in the car. I also noticed that the Prius will only hold 1,000 contacts...
  9. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I use speed dial to access my most often dialed because it can be use while the car is moving. Otherwise I use the steering wheel "dial by name" command.
  10. mitcheli
    mitcheli Junior Member
    39
    2018 Prius Prime
    Pairing my contacts from my Palm Pre to my car was simple. Once I authorized it on the phone it took about 30 seconds to transfer all of them. Now when I hit the talk button on the steering wheel, I can say, "dial by name", then the name, then dial, and the car will control the phone for me. Very nice indeed...
  11. stream
    2,977
    452
    Long Island, NY
    I thought that to dial by name you have to first assign a voice tag to the contact, and there' a limit of 20 voice tags.
    From the nav manual:
    DIALING BY NAME
    You can call by giving a voice tag registered
    in the phonebook.
    Is this not the case?
  12. dogllama
    dogllama New Member
    118
    Los Angeles
    Nope, not the case. I can dial anyone in my synced iPhone address book with the voice feature.
  13. stream
    2,977
    452
    Long Island, NY
    Let's say you have a bunch of Bobs in your address book, and you want to call Bob Smith on his cell phone (and you have his cell, home and office numbers). How do you do that?
    Would it be different if you only had 1 Bob?
  14. Prius42
    Prius42 New Member
    139
    Maryland
    I would say:
    me: Dial by name
    car: Dial by name
    me: Bob Smith
    car: Bob Smith
    me: Mobile
    car: Mobile
    me: Dial
    car: Dial
    and then it will dial. Sometimes if it doesn't parse correctly it will give you a list of approximate matches to the name and you have to pick them from a list by saying 1, 2, 3, etc, but usually it works perfectly for me. There are about 100 contacts in my iphone address book that were transferred. I've never assigned a "voice tag" to any of them.
  15. Tideland Prius
    16,623
    That's very odd. I can control the track (up/down) with the steering wheel buttons when my netbook is BT streaming audio using Windows Media Player. No track/artist info though. Are you sure the iPhone can't skip tracks with the steering wheel buttons? I would assume it's more advanced than a simple netbook with basic BT.
    stream, Prius42's got it right. You can dial anybody in your contact list via name. You also choose which of Bob's number you wanna call (just replace where Prius42 has mobile with home or office if you want to dial Bob's alternative numbers)
    Just out of curiosity. Those with the 3GS have voice-activation, right? Can you do that while the phone is paired? Presumably you have to press the button on the iPhone to tell it a command, rather than a button in the car.
  16. brostephen
    brostephen New Member
    I synced my iPhone 3GS and it does show track and artist. The phone works great too!
  17. cmezriczky
    cmezriczky Junior Member
    34
    Austria
    I can skip songs with the steering wheel switches on my iPhone 3G.
    Dialling everybody by name is not available via voice commands on european versions!
  18. dianafish
    dianafish New Member
    Abilene TX
    I have had my 2007 Prius for 2 weeks now. I'm trying to figure out how to sync my iphone to Bluetooth in the car. I don't know about the grouping thing on my phone. Can anyone help me?
    Thanks!
  19. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    Very sure. Only volume controls from the steering wheel:(.
    Are you sure you are talking about BT STREAMING AUDIO? It is well documented that the current version of the iPhone OS (3.1.3) does not support NEXT/BACK or track info ( iOS version history - Wikipedia, the free encyclopedia under the heading Bluetooth). Unfortunately it doesn't look like it will be implemented in the release of iOS4 either as the current build (the GM candidate) doesn't support it.
  20. austingreen
    austingreen Senior Member
    13,703
    4,229
    Austin, TX, USA
    friend with a toyota nav (non-prius) uses iphone 3gs voice dial then uses bluetooth to use the phone. He prefers the voice dialing from the phone.
    My iphone 3gs can do pause and next song on my parrot bluetooth. Volume works as its simply the head unit not the device. I'm sure the toyota nav bt streaming is similar. Other bluetooth device likely have the other better support.
