Map light covers
Discussion in 'Gen 3 Prius Main Forum' started by Mistresspage, Jun 9, 2010.
  1. Mistresspage
    Mistresspage New Member
    Sonora, Ca
    I have a 2010 Hybrid Prius. On two separate occasions, I have gotten into my car only to find first one map light cover, and then the second just broken and lying on the seat. My car is under warranty and they are fixing without any problem, but has this happened to anyone else? I am feeling a little weird about it. Thanks for the help in advance.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Wow! that is weird. I'll take a wild guess. Maybe they had a bad batch of plastic and they were already cracked in a way it didn't show, when the temperature changed in the parked car they cracked clear through and fell out. Either that or you have been sleep walking and went out and broke them with a hammer. ;)
    Glad they are fixing them and didn't try to blame you for it anyway.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Wow that is strange, the only thing I can see breaking on them are the tabs when trying to remove them to replace the bulbs inside with something like LED bulbs. Glad they are replacing them for free seeing as how each one can cost somewhere near $18-$20.
  4. Tideland Prius
    16,558
    Never heard of that happening (sure there isn't mice or other rodents that got in? They can climb through the vents if they're small enough). There are 4 clips IIRC and you need a flatblade screwdriver to take them out.
  5. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
    :cool: Speaking of mice, we have been having this unplesant smell in the car recently so looking around inside I found mouse droppings! Took everything apart, discovering droppings and urine in the lower glove compartment. Even found a nest of chewed up insulation in the lower engine compartment. Set a mouse trap and caught a nice fat one! Now the question is how to get that smell out of the car? Living in rural NE Oregon comes w/ pack rats, etc. so may resort to leaving the hood open to lessen cozy dark places to hide/nest. By the way, how would a mouse get up to the map lights?
  6. compac
    compac PSU, Metallic Blue Ribbon
    52
    VA, Blue Ridge mtns
    For the smell... "Click & Clack" recommend an open bag of ground coffee. Could help absorb the smell.
  7. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
    Obviously I've cleaned up any messes found but there may be hidden mouse stuff on or around engine. Can one steam clean the 2010 Prius engine? Will give the coffee idea a go as we head off on a 3,000 + vacation. Thanks!
  8. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    wow really weird. I can't even take it off let alone falling off by iteself.
  9. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    There were a lot of posts regarding mouse problems when the GII came out. The problem becomes severe when they start eating wiring harness for nesting materials.
    One of the posts showed a method for mouse proofing a Prius.
    A search on mouse or mice will show 3 pages of threads on the subject including how to get rid of the smell.
    PriusChat Forums - Search Results
  10. dondia
    dondia New Member
    Miami
    Just wanted to let you know that in the year and a half that I have had my 2010 Prius, the map light covers have broken twice--first the left one and now the right one. The first time, like you, I opened the door to find the cover lying on the floor. Today the right one broke when I pressed it to turn it on. If you look at the cover, you can see it is held on by two very small plastic hinges, really just flimsy extensions of the cover. You were lucky that your dealership replaced them for free. Mine not only charged me, they made me make two 15-mile trips--once to order and once to pick up. I have a feeling this will be an ongoing problem. Toyota does not sell the covers online. Does anyone know who does?
  11. ETC(SS)
    7,159
    :welcome:
    Greetings to both you and the OP.
    Sorry 'bout the map light covers!
    I haven't heard of this being a common problem----and I haven't detected it in my '10.
    If your car is still under warranty, and they charged you for the repair, then I'd send Toyotya some 'nasty-grams' about it.
    Toyota Customer Service (1-800-331-4331)
    If your car is not under warranty---I'd call them anyway and tell them that a $25-30K car should not have self-ejecting map
    light covers.
    It couldn't hurt!
  12. BrettS
    BrettS Active Member
    290
    137
    Orlando
    I agree that they probably should have been repaired under warranty, but you should be able to get them from parts.com. I don't have much experience with them... I've placed two orders with them recently, but the parts are still being shipped to me. I've seen good reviews online, though.
    It's much easier to order from them if you have the toyota part number as I've found searching on keyword to be pretty much useless. If you can't find the part number then your best bet is to manually go through the parts catalog, but it can be difficult to figure out what catagory the parts would be in.
  13. Billnpa
    Billnpa New Member
    PA
    Yes, it happened to me too, both map light covers fell down while pushing them on. I am calling dealer today and we'll see what they say. I think the tabs holding them on are too weak to withstand normal use. In fact, I really haven't used them that much. My Prius is 15 months old...
  14. gearguy
    gearguy New Member
    MA
    My right map light cover broke from the impact of chunks of snow falling on the roof. One side of the molded C clip broke. It seems to be a fairly week design.
    Anyone have the part number?
    EDIT: parts.com has them as 8126547060 then select right or left for about $6.
    kimb0S1ice and DanMode like this.
  15. kimb0S1ice
    kimb0S1ice Junior Member
    Mine broke when I was replacing with LEDs. Thanks for the part number gearguy! I wonder if one can fix the broken c tab?
  16. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    When the mice find they can get their Java fix without leaving your Prius, you may never get them out.
  17. Wthermans
    Wthermans New Member
    Alcoa, Tennessee
    Reminds me of the mummified rat I found in my old STi's engine bay.
  18. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    OMG. How did you find or know it's there? Bad small?
  19. Wthermans
    Alcoa, Tennessee
    Actually had no smell at all. The car had ~7k miles on it and was garage kept. I found it when I was at a Rallycross event and was looking in my engine bay with a flashlight.
  20. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Oh I see. Glad you found the mummy. It's teeth were scary.
