Transmission/Transaxle Fluid Replacement ?
Discussion in 'Generation 1 Prius Discussion' started by TexomaEV, Jun 3, 2010.
  1. jk450
    jk450 New Member
    55
    Some time after production ended, as a replacement part. The old version is no longer available.
    No. The pump is not readily accessible, so a distinguishing mark wouldn't be of much help anyway.
    No.
  2. bwilson4web
    16,111
    Actually pumps are available from salvage yards. This is why it is important to know the distinguishing markings that might show the change. For example, there was an NHW20 change:
    Luscious Garage | Blog | Prius Code P0A93: Inverter Water Pump Failure
    However, Lucious doesn't mention an NHW11 pump change:
    Luscious Garage | Blog | Gen 1 Prius code P3130: Inverter System Cooling Malfunction
    Hobbit has some good hints on the NHW20 pump:
    Inverter Pump
    Everyone else, next time you're in TIS, see if you can find anything about a change in the NHW11 inverter pump between 2001-03. In particular, look for a part number or other identifier.
    I checked the usual sources and the only thing interesting:
    Yahoo! Groups
  3. jk450
    jk450 New Member
    55
    Again, the pump is not easily accessed. Salvage yards typically require do-it-yourselfers to remove the part themselves. This requires removal of either the inverter, or the front bumper and one headlight.
    TIS is not a parts catalog.
  4. Patrick Wong
    18,200
    6,497
    Would you care to share with us the info source that you used to determine that the inverter pump design changed, if not TIS?
  5. jk450
    jk450 New Member
    55
    I didn't say the source wasn't TIS. I said that TIS is not a parts catalog.
    You cannot depend on running parts number changes to be disclosed in TIS. Nor will a local dealer's parts database always be able to access the old numbers, particularly if the number change has taken place some time ago. In this case, the source is my own experience; I remember the redesign taking place a few years back.
    If you do search TIS for the part number, don't search the RM. You'll only find a parts number change in a TSB, and only then if one is associated with the redesign. At any rate, the redesigned pump is the only one available, and has been for some time. You don't have to worry about buying the wrong pump.
  6. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    Took the Prius into a quick change shop, and had them to replace the transmission fluid. Took awhile to get the fluid/gasket from local dealer, but in the end, it was a good idea to get it changed. Here's a photo of the pan, before cleaning it. Notice all the debris in the pan. I hope it's not the beginning of the end for the transmission. The screen in the pickup was clean.
  7. bwilson4web
    16,111
    Not too bad for a first oil change. You can see the magnet looks like a 'slug' and that is the magnetic material. Past oil analysis suggest 3x of nonmagnetic material in the oil.
    The pale bits are transmission case sealant. It bleaches over time, losing the iron oxide pigmentation into ... the transaxle oil. Were you able to save an oil sample?
    The reason I ask is you may want to treat this as an initial flush and change it again in the Fall. Two samples at a fixed distance and we can do a partial fractions analysis to figure out how much is carry-forward. I've done it once and have no problem with independent metrics.
  8. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    The shop didn't have a bottle for collection, but I do feel the need to change it again after XXX miles, for good measure. It's got 139K on the vehicle, and I want to get another 139K+ out of it..... lol
    Thanks for explaining the gunk/debris, as I was very worried something had started to breakup in the transmission somewhere.
  9. jk450
    jk450 New Member
    55
    Your fluid has quite likely been changed before. 45K fluid from a healthy transaxle can look worse. The amount of ferrous material on the magnet and debris in the pan is lower than normal.
    Yours looks fine. Fluid plays a factor in transaxle failure when it is significantly degraded. Gen 1 transaxle failures are rapid and cannot be reliably predicted by fluid analysis.
    Just change your fluid every 60K, and you'll be doing all that you can do. You don't need to drop the pan unless you want to, now that you know that it's relatively clean, and the screen is clear.
  10. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    I agree with the part about cleaning the input screen. I've seen some that are so clogged up when you wipe them fluid drop out of the tube which means tranny had reduced oil flow and all kinds of potential damage can occur.
    You must drop the pan on Gen1's to properly clean things.
    Gen1 Prius Transaxle Service
    For those of you complaining about $6-$9 per quart fluid just relax and pay the dealer....it's still a thousands of $$ cheaper and easier than replacing your entire transaxle....
    I've replaced about a dozen Gen1 transaxles so far....some of which I'm sure could have been avoided with proper servicing every 30k miles.
    Lastly, the dealer DOES NOT normally drop the pan when changing Gen1 fluid. Insist they drop the pan and clean everything if you have them do the job.
  11. bwilson4web
    16,111
    Excellent link!
    I suspect the 'crud' is from case sealant. Have you or your customers done any oil analysis?
    Stator coil shorts? Any mechanical failures?
    I always have to order my gasket from the parts department. They never have them in-stock.
    Well you've reminded me that this weekend is transaxle and engine oil change. I've been running Type WS instead of Type T-IV for ~33k miles and will send a sample for analysis.
    Have any of your customers considered running Type WS instead of Type T-IV?
    Thanks, great posting,
  12. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    This was very helpful, since I had not changed the transmission fluid myself before, but I'm curious, this article says you should replace 4.9 quarts atf, while other sources (including the dealership) say 4 quarts even.
    Is there a consensus? Or is it safe to do it the old fashioned way and fill it with the car level, until a little drips from the fill hole?
  13. bwilson4web
    16,111
    It is 4.8-4.9 quarts and that is exactly the procedure I used last weekend. I had 5 quarts and it started dripping just at the end of the last quart. I had already emptied my catch pan and replaced it to catch the drips.
    I had a dry, water bottle and used it capture an oil sample for testing. I should have the results this week. Experimentally, I'm using Type WS but that is based upon a couple of years of oil analysis.
  14. Patrick Wong
    18,200
    6,497
    The 2G requires 4 US quarts of Toyota ATF WS. The Classic requires ~5 US quarts of Toyota ATF T-IV. It is fine to fill the case until you start to see the new fluid ooze out of the fill hole.
  15. atikovi
    atikovi Junior Member
    68
    Great write up but I have a few questions.
    1) I assume it's better to have the fluid fully warmed up?
    2) When filling, does the car have to be level? I would drive the front up on ramps so it would be 8 inches higher.
    3) The picture shows you filling from the top. I thought the fill plug was just above the pan and reached from under the car?
    4) To clean the pickup screen can you just spray it with brake cleaner? There is no mention as to how specifically it's cleaned.
  16. bwilson4web
    16,111
    There is one place that continues to irk and that is the area under the differential gear. I have no doubt that debris there is picked up and cycled through the gears to make the 'liquid smoked.' Sad to say, I've never figured out how to suction out that basin.
    If you find the oil especially bad, you might want to run say 5-7,000 miles, say a nice day in Spring, and do it again. Treat the first change as a 'flush' and the second one is for real.
  17. atikovi
    68
    Thanks, I'll be using this filler to make it easier though.
  18. 3prongpaul
    956
    730
  19. w2co
    w2co Member
    366
    81
    Longmont, CO.
    What does anyone think about just adding the whole 5qts while it's jacked up?
    That way there will be no spillage, and no wasted new oil, and it will definitely be full (slightly over full) when you let it down. At .1qt over full I doubt it will harm anything and probably even better, as long as all seals are good.
    It's been my experience that when it comes to tranny gears etc., too little is much worse than slightly too much, but way too much is also bad (as the dealer does to the ICE!) I wouldn't be surprised if one let the dealer do the tranny oil that they just dump the whole 5qts in as well.
    With no dipstick to check it who would?
  20. Patrick Wong
    18,200
    6,497
    I agree that 0.1 qt is not enough to worry about.
    The dealer tech will typically raise up the car on the lift and fill until fluid starts to ooze out of the fill hole. That is the correct amount to add.
    A DIYer can do the same by raising the car on 4 jackstands so that the car is level. If that is too much trouble for you, then raise the front on 2 jackstands and fill with 5 US quarts.
