"Regular" unleaded (without ethonal) no longer available here. :(
Discussion in 'Gen 2 Prius Fuel Economy' started by uart, May 24, 2010.
  1. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Here in NSW Australia they've just phased out regular unleaded (without ethanol), so now the choice is premium (without ethanol) or E10.
    The regular unleaded that I previously used was just the 87 octane stuff (actually it's called "91 RON" here, but same thing as "87 AKI" in the US see : [ame="http://en.wikipedia.org/wiki/Octane_rating"]Octane rating - Wikipedia, the free encyclopedia[/ame]).
    Now I'm trying to figure out if I should just use the E10 or whether to switch to the preimum 91 octane stuff (actualy 95 RON = 91 AKI). The premium stuff cost approx 11% more so it's probably a waste of money, but I've never been much of a fan of ethanol blends. Which one to choose ???
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If it was not a Prius, you would take about a 3% 'hit' for E10. Ethanol has 70% of the energy as gasoline.
    Sadly the Prius seems to be tuned so that ethanol and the butane in 'winter' gas are treated as filler. So expect a 10% hit on E10.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah I did try a few tanks of E10 once a long time back and it seemed to get fewer MPG. Since then I've just used regular unleaded. The E10 used to be 2% cheaper but it actually cost more when you factored in the fewer MPG.
    Now there is no other choice for regular (as E10 is the regular unleaded now). What about the octane rating. I read somewhere here that the higher octane fuel is not good for the prius. Is premium 91 (95 RON) ok to use?
  4. richard schumacher
    7,666
    1,047
    United States
    E10 burns cleaner, cleans the engine, and costs less than premium. Use it and be happy.
  5. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Whoa! What's that like? Using 100% gas, I mean.
    Sorry, but all we've had available here since the late 90's has been E10.
    That has meant suffering with an average of only 50 MPG.
  6. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok, good to know I'm not alone in suffering with this grrr E10 suff. :D
  7. sw08
    sw08 New Member
    Daphne, AL
    I would say about 1/3 of the stations around here still offer 100% gasoline and I use these whenever possible. Given the option between premium and e10 for the Prius, I would use e10 and not stress over it.
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Since I first posted this I've found out that I can still get petrol without ethanol (for now). Several of the larger companies have gone to selling only E10 already, but there's still some independent operators selling it without ethanol.
    I was given some misinformation at one petrol station about when the "mandate" was to start. Unfortunately though it has been mandated (by our state government) that by July next year that all regular grade petrol (gas) has to contain 10% ethanol.
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    It's hard to believe a modern engine would waste available fuel as just "filler". Is there any documentation on this claim?
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The important word in that quote is 'seems'. Every winter we get winter gas and reported Prius gas mileage plummets, many owners have reported E10 as having 10% less range than E0 gas.
    Many cars do well on E10, taking about a 2% to 3% hit on MPG, as they should. Prius owners see more of a hit. One of the major changes in 'winter' gas is more butane, so it starts easier.
    The Oil Drum | Refining 101: Winter Gasoline
  11. 2009Prius
    2,705
    512
    63
    Thanks! I would contribute the main effect to the temperature difference then.
