Math Help
Discussion in 'Gen 3 Prius Fuel Economy' started by LRKingII, Jun 11, 2010.
  1. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Here's the question.
    Reg E10 87 oct gas at $2.85 a gal right now.
    MPG on road trips with reg E10 gas = 48 calculated.
    Premium 91 oct straight gas "no ethanol" at $ 3.20 gal.
    What mpg would i need to get to make it worth trying a tank of the 91 oct no ethanol?
    Is it even possible to increase it?
  2. SureValla
    SureValla Member
    590
    Shelton, CT
    sorry man too many unknowns
  3. Dan bo
    Dan bo Prius Fan
    116
    34
    28
    Canada, London
    Well to get the same ratio you would need 53.89 mpg.
    Will you get than going to 91??? I have no idea and doubt it is worth it.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The price difference is 12%, so you'd need to see 54mpg or better to make it worthwhile. But does mileage increase with premium? I seem to recall that it doesn't, at least with the iconic version.
    If I'm wrong, I'm sure someone will correct me. ;)
  5. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Is premium gas 'ethanol free'? I didn't think so.
    You won't get better gas mileage from the premium chemistry, but if it is actually ethanol free, you might get 4-5% better mileage according to what I've read. Still not cost-effective.
  6. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    We have a local station the sells straight gas 91 oct NO ethanol in it.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I have been assuming that the Prius ECU treats ethanol as filler.
    For most cars 10% ethanol should result in 3% less mileage
    In the Prius it seems more like 10% less mileage
    To make Premium 'worth it' you need over 12% better mileage
    12% more than 48 MPG is 53.895 MPG
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    You'll probably get a bigger increase by inflating your tires to max. sidewall pressure and when it is cold blocking the grill.
  9. jdenenberg
    jdenenberg EE Professor
    3,954
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    First, Ethanol is not a filler. It just contains 30% less energy than gasoline so E10 loses about 3%.
    Second, you will actually get slightly poorer MPG with Premium assuming the same ethanol content.
    So using Ethanol-free 91 octane will not quite make up for it's cost differential.
    JeffD
