LCD screen protector
Discussion in 'Gen 2 Prius Main Forum' started by _echo, Aug 8, 2005.
  1. _echo
    _echo Junior Member
    83
    Orange County
    After many months of compulsively checking my MPG/consumption bargraph, I have noticed that the lower left corner of my LCD has a nice little 'oil spot' on it. Do any of the priuschatters out there have any solutions for protecting the touchscreen? They make a whole variety of LCD protectors for PDA's and such, anyone make something like that specifically for the Prius?
    I currently use inkjet window decal material on my camera, although functional (and fairly cheap), I was wondering if there was a better solution out there. I am most annoyed by the 'moire' pattern that shows up on color LCDs.
    If you want to get REALLY fancy, you can make a CAD drawing (I use PCB software for this,) and print it 1:1 onto that material, that will allow you to cut holes irregular shapes, and most importantly multiple copies. After you do the scribing, strip the surface.
    BTW, if you go with the inkjet window decal stuff, you should soak it in water for a day and then gently rub the printable surface to get rid of the glue. If you don't do that, it's sticky when exposed to moisture.
    Woo hoo 51MPG!!!
  2. aaf709
    3,862
    2022 Prius Prime
    Yes, Sigma Automotive (one of the sponsors) sells one for $16. That sounds pretty good. You can see it here. Just scroll down until you get to Interior.
  3. Edward3
    Edward3 New Member
    Purcellville, VA
  4. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Did you guys get bubbles while applying this?
  5. Edward3
    Edward3 New Member
    Purcellville, VA
    Nope, I would suggest:
    1. clean the MFD very well
    2. Start from one of the sides verifying the film is stright
    3. use a credit card to apply the rest, and it will just stick to the MFD - look no hands :lol:
    Whatever you do, do not touch the inside part (that goes on the LCD) with your hand, this will leave your finger print there for ever. on the other hand it could be a good way to establish ownership if ever needed.
  6. silentak1
    893
    28
    LA
    Thanks,
    does it look pretty clear? I remember applying various film protectors to my PDA and it just didn't look right. Some were thick, others too glossy, and some even blurry.
  7. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    do you get finger prints on the protector when you keep touching it?
  8. aaf709
    3,862
    2022 Prius Prime
  9. Prius Noir
    Prius Noir New Member
    31
    Yes, you'll get fingerprints on the protector too. I doubt if there's any such miracle device that doesn't.
    A can of compressed air to blow off any micro pieces of lint helps. Apply as the instructions describes and there should be no bubbles.
    The look is near transparent. It's very thin. Can barely tell it's there. It has a anti-glare, matte finish. Had mine since April and no signs of wear or peeling.
    It's a near perfect fit so align it carefully.
  10. jamarimutt
    jamarimutt New Member
    985
    I don't see any advantage to this protector. You'll get the same fingerprints on it and you'll have to clean it just the same.
  11. maggieddd
    2,090
    Boston
    right, what's the point of having it then?
  12. GoldenGirl
    GoldenGirl New Member
    I use the flat of my fingernail on the screen....just the lightest touch is all you need.
  13. aaf709
    3,862
    2022 Prius Prime
    Ahh, but you can remove protector in order to clean it. You get a dirty fingerprint on the LCD screen itself and it'll be harder to clean.
    It's like having seat covers or a UV filter on a camera lens. Cheap protection.
