Problem SOC levels on 2002 Prius
Discussion in 'Generation 1 Prius Discussion' started by hybridtwins, Jun 13, 2010.
  1. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    All,
    My 2002 Prius recently had an episode where the SOC went down to 25%, and then went all the way to 100%. This seemed to be triggered by being stuck in traffic in about 80º F weather with the A/C on. When SOC was at 25%, there was no response for about a 1/2 second or so when hitting the accelerator, and then the ICE would kick in, lurching the car forward. This seems to indicate that there wasn't enough juice to turn over the electric motor, yet there was never any turtle or any other warning light. The low SOC lasted until I was moving steadily, at which point it went up to 100% It stayed there for maybe another 40-50 miles of driving and finally settled back down to the normal fluctuations of 50% and 75%.
    I've also noticed that in about the last month, there have been some odd clicking sounds coming from the dashboard, more or less in the area in front of the steering wheel. This again seems to occur mostly when I'm stopped in traffic. Could this be related to the SOC issue? the car has about 76k.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Are these percentages the actual battery SOC, or percentage of the bars on the MFD?
  3. bwilson4web
    16,554
    I think Patrick Wong has had to deal with traction battery problems in the past. If I remember correctly, rapidly changing SOC was one symptom and consistent with a weak traction battery.
  4. Patrick Wong
    18,214
    6,531
    Since the OP is talking about 25%, 50%, 75% and 100%, I assume he is referring to the presence or absence of the four bars on the SOC gauge. This does sound like the traction battery is about to give out.
    Is the car still covered under the 8 year / 100K mile warranty? If so you might encourage the battery to die sooner vs. later, by stressing the powertrain over mountainous terrain (like driving north on I-5 to Tejon Pass at a rapid pace, or taking a trip to Lake Arrowhead, etc.)
    I don't know about the clicking sounds, might that be coming from the braking system? Try repeatedly pumping the brake pedal while the car is READY and stopped, to see if the clicks happen then.
  5. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    Thanks all for the responses.
    Yes, I am referring to the battery symbol in the MFD, and your answers bring up more questions.
    I'm in a CARB state, so I believe the power train warranty is 10 years/150,000 miles. But must I wait for the battery to completely die before Toyota will replace it? Are any error codes logged due to the degradation in performance? Would it do any good to get a picture of the MFD when the battery is acting up so I can show this to the local Toyota service center?
  6. bwilson4web
    16,554
    I'm 99% sure that warranty applied to the 2004 and later Prius. Patrick Wong would be the expert. However, we have seen Toyota 'do the right thing' and honor battery warranties in the past.
    It makes sense to 'get it on the record' at your local dealer. You might ask them to:
    Perform the P3011-3029, "Battery Block # Malfunction," which entails a controlled discharge and charge monitored by the TechStream.
    Unlike earlier years, there are options including Re-InVolt and owners who have rebuilt their traction battery packs. I helped on one traction battery replacement: two people, 4 hours and the owner paid $1,700 for the swap.
  7. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Try A quick check before anything else -measure your 12v battery with a volt meter while in ready mode it should be 13.8v or so, if it's lower than that many things can cause this including the inverter, the traction battery, even the 12v battery itself if it has shorted cell(s). If the 12v system voltage drops too low, it'll cause all kinds of weird readings and false warnings from the electronics ref levels changing. The latter is of course if the 12v drops below say about 11.8v and lower. Just 2c..
  8. Patrick Wong
    18,214
    6,531
    The 10 year / 150K mile traction battery warranty (for CA and other states adopting CA regs) started in the 2004 model year because that Prius model is rated AT-PZEV. Earlier Prius do not have that rating.
    If your car does not show any warning lights, then no one at your dealer will care (for warranty purposes) whether your SOC gauge shows 0%, 25%, or 100%. If there are no warning lights then no DTC will be logged; and if no traction battery-related DTC are present then no warranty action will be taken with your traction battery.
    If you wish to pay for the diagnostic test that Bob mentioned, it's up to you. However even if the test shows a marginal result, as long as no DTC is logged the dealer won't take any warranty action. Hence I don't see the point of paying for the test.
    Rather, it might be better to see if you can drive the car hard enough to get the hybrid vehicle or traction battery warning icon in the MFD to appear.
  9. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    The 12v battery was just replaced last November.
  10. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    Actually, this SOC behavior first occurred under similar conditions with the exact same symptoms (including no warning lights or messages) when arriving a San Francisco at the end of a road trip in January 2007.
    There have been perhaps 4 such identical incidents of this type since then, including the current one. And during this period there was at least one road trip to Vegas, but the SOC behavior didn't occur on that trip IIRC. So I have my doubts that I can drive the car hard enough to force any warning messages or lights that have not shown up on previous occasions.
    I'd almost be willing to write this issue off as a quirk, but the last incident left me in a somewhat dangerous traffic situation: I was in a transition lane on the 405 freeway in stopped traffic with a need to change into another lane where traffic was moving at highway speed, and with badly-crippled acceleration. So I must find a solution to this issue.
  11. Patrick Wong
    18,214
    6,531
    Since you've noticed this happen intermittently over the last 3-1/2 years, I doubt that the traction battery is the problem. However since no warning lights have appeared, your car probably doesn't have any logged DTC to help you figure out what is the problem.
    Maybe the traction battery ECU or hybrid vehicle ECU has a random glitch that appears infrequently?
  12. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    Sometime back before this time period, there was an incident where the car was parked in the garage and simply would not start, and gave a christmas tree of warning lights. Turned out there was a TSB for the condition, and an ECU was replaced. I can't find the records that would indicate which one it was, although the dealer probably knows. Sorry I can't be more specific.
  13. bwilson4web
    16,554
    "Big Hand"?
    There is a known weakness in the NHW11 accelerator that dirty contacts can lead to a loss of acceleration. I understand it can be a brief event although most have described it as lasting longer. Usually it throws a code but some have claimed it can occur without a code.
    The stock accelerator from Toyota is ~$500. You can refurbish it yourself following Doug's excellent instructions. I do it by swapping out my accelerator, your replacement, and then I test and rebuild the part you return.
  14. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    I don't think so. The lag in throttle response has been consistent with the 25% SOC episodes. When SOC is behaving as it should, acceleration from a stop is smooth as silk.
  15. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Good. But does that mean the battery is at peak reading?
  16. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    UPDATE:
    The car is currently at the local Toyota dealer. My service person says that a full diagnostic was run on the hybrid system and no codes or other anomalies of any kind showed up. He stated at one point in our conversation that it would be natural for the battery level to decrease to 25% if the car was stopped in traffic for a long enough time without the ICE running(!) I corrected him on how the hybrid system works and otherwise told him that this is not good enough, being that this condition can create a safety hazard. I'm letting them keep the car overnight so they can look into it further tomorrow, but they don't seem to know what else they can do.
    Where can I go from here?
  17. Patrick Wong
    18,214
    6,531
    If no DTC was logged then it's going to be tough to diagnose your car's problem, especially since the problem happens so infrequently.
    You could:
    1) sell the car if you feel it is unsafe when the problem happens
    2) buy a salvage traction battery ECU and hybrid vehicle ECU, and install both (in essence, throwing parts at the problem.) No assurance that will help, though.
  18. bwilson4web
    16,554
    I agree with Patrick. Could you give us an idea of how frequently this occurs?
  19. Patrick Wong
    18,214
    6,531
    Hi Bob,
    4 or 5 incidents, over 3-1/2 years.
  20. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    Just to clarify: are you suggesting buying just the ECU's, or the traction battery as well?
