Check engine light?????
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Watermom, Jun 5, 2010.
  1. Watermom
    Watermom Junior Member
    Ca
    I have a 2007 prius that has 112000 miles on it has had no major work done on it just oil changes and air filter now all of the sudden the check engine light is on manual says to take to dealer asap can someone help me trouble shoot this?? Is it serious ??? Can I still drive?? Do you think it is the in cab air filter never have changed that one?? I really don't have the $$$$$ to take it to the dealer.
    Please help thanks.
  2. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Have someone scan the vehicles and pull the DTC's. Write them down and report back here.
  3. northwichita
    481
    102
    29
    Wichita KS
    Some auto parts stores will scan for free, call around first if you haven't done this.
    Driving the car with the engine check light on is risky, I wouldn't drive the car for any long length of time, try to avoid dangerous traffic spots, and suggest leaving the a/c off until you find the source of the problem ; morning driving would also be safer, in case the problem is heat related .
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Is your gas cap on properly?
  5. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    Since only the CEL came on, your hybrid system should be OK. The problem is mostly with the ICE (gas engine). If the car seems to run OK besides the CEL being on, it can be something simple, like a loose gas cap, or having overfilled the gas tank. I wouldn't be paranoid about getting the codes, but you should drive as little as possible, and get the codes. Autozone and other stores will read it for you. You can Google the OBDII code, and check with us. I would guess, since you didn't mention any drivability issues, that it is not a very serious problem. If any other lights came on, or there are drivability issues, then the problem may be more serious.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Welcome to Priuschat! Your best bet is to to limp it to an auto store as most will hook up a scanner and pull the codes for free.
    Call around first and see if they can. Then write ALL those codes down and post them verbatim back here on this forum.
    And no cabin filter is not an issue. But be aware unlike alot of other modern cars that can be driven around with a check engine light on a CEL on a Prius is usually a little more serious and should not be driven alot till you can figure out whats wrong with it.
    Good Luck!
  7. richard schumacher
    7,663
    1,038
    United States
    You can even less afford to destroy the car. Take it to a dealer for diagnosis and repair.
  8. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I think it would also be a good idea to pull the engine intake air filter
    cover and see how dirty or torn it may be.
    If you don't feel comfortable doing this -- it's really simple -- when you
    go to the auto parts store to pull the codes, there's a good chance that if
    you ask nicely, they would do it or you...
    And if they don't appear to be bothered much at this point, you might
    ask them, "How does the MAF sensor look?" It's right under the filter. If
    it's all gunked up, it could need good acleaning. But DON'T DO IT YET...
    Get the codes and post them first thing.
  9. MichelleH
    MichelleH New Member
    Tucson
    Hello. The check engine light comes on for my car when the car has gone about 5K without an oil change. The dealership restets the sensor when they change the oil, and some non-dealerships know how to find it. It flashes at around 4500 and stays steady at 5000. Take it into a dealer to have them reset the light.
    At least that is what it means for my 2008. Hope this helps.
    EDIT: just realized I am refering to the Maint Reqd light...SORRY!!
