Does anyone else drive with side mirrors out?
Discussion in 'Gen 3 Prius Main Forum' started by OldArmy94, Jun 17, 2010.
  1. OldArmy94
    OldArmy94 Crazy Prius Man
    Arkansas
    I've been driving vehicles with the side mirrors turned out for about a year now. I read online (don't remember where, sorry) that it is better to use your rearview mirror for the views directly behind, and that it is better to use side mirrors to cover your blind spot. I have to admit that I really have felt like a safer, more competent driver by doing this. The only drawback is that it makes it a little more difficult to back into a tighter spot, but that is a very minor inconvenience for me. Does anyone else do this?
    (To make this Prius-related, I have noticed that it is a little more tricky to do on my new 2010 Gen3)
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    There was an article on the car talk website about this. I turn my LH mirror out to cover blind spot and leave my RH mirror in for backing up. Works pretty well so far. :)
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, I do. I like it much better. Drive the wife's vehicle which does not and I feel it has more blind spots.
    I have always had problems parking the Prius. Can't get it in straight for the life of me (backwards). I think it is the high doors (loss of reference).
  4. OldArmy94
    Arkansas
    Yeah, I just went to cartalk.com and found that article. Thanks!
  5. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I have them aimed far enough out that I can still see the side of the car if I move my head over a ways, but from my normal sitting position I can't see the side of the car.
    The standard position allows you to see the same car behind you in all 3 mirrors but leaves big blind spots, what good is that?
    No problems with backing up, but I do that everyday to put the car in the garage, so I'm used to it now. (Generally park in the same spot, plus or minus a couple inches in all 4 directions).
    When changing drivers, my wife and I have to readjust mirrors anyway.
  6. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    Once Click and Clack explain it, it makes perfect sense.
    But get used to the extra demagnification in the 2010 Prius right side mirror. Objects are a LOT closer than they appear.
  7. Thai
    Thai Prius Neophyte
    1,197
    89
    I use large 3" or 3.5" (forgot exact size) round convex mirrors on BOTH rearview mirrors to cover my blind spot...and to help me avoid the curb when parallel parking. I love the convex mirrors...and is on all my cars. This way, i can have my side mirrors in their "normal" positions yet have my blind spots covered. BTW, you need big ones to really be effective.
    [​IMG][​IMG]
    I stick on my upper inside corner of my side mirrors.
  8. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I have the same problem judging straightness, and I attribute it to the fact that the top of the doors (the window line) is more angled with respect to the ground than other cars, so if you park so that your window line is parallel to the parking space your car is at a distinct angle.
  9. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    what blindspot? Those also rotate 360 degrees for positioning.
  10. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I've always had the mirrors pointed out. If I can see a car in my rear view mirror, I don't need to see it in the other two to be reminded that it's there. I have my mirrors aimed such that when a car leaves one mirror, it's picked up in another. When it leaves the side mirror, it's in my peripheral vision. I rarely need to turn my head very much to know exactly where all cars are around me.
  11. OldArmy94
    Arkansas
    I am pleased to hear that I'm not the only. I'm really surprised that this isn't taught in driver's ed.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I can't say that I've noticed any blind spots on the Prius, unless you can't turn your neck. I have my door mirrors adjusted so that I can just see the side of the car in the inner edge of the mirror, I turn my head if I want to see any further out than the other edge of the mirror. Most cars in the UK didn't have door mirrors when I started driving in 1973 so they were a luxury to me when I first got a car with them on.
  13. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I tried it a bit awhile back and didn't like it. My specific problem with it was when pulling into the HOV lane with a large vehicle behind me my rearview becomes useless and my left side mirror was showing me the center divider. I need the left side mirror to show me the lane for a good distance so I can tell when there's enough room to jump in there.
    Jeff
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I have been driving with mine adjusted outward the "new way" for about a year now. Seems to work but I look over my shoulder anyway.
    I took an AARP driving course for geezers recently, gets you an insurance discount in this state, and they did teach it pretty much the same way Click and Clack describe on their web site.
  15. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    You are correct, it is safer. Recently tho I changed my mirrors to align with side of my Prius. This is because I have added wide view mirrors attached to the side mirrors, an especially wide one on the left side. Now I have the best of both worlds. :)
  16. fuzzy1
    10,548
    I adopted the same method Tony uses (mumble-mumble) decades ago, just a few weeks after moving to a new place that had multilane highways. This was partly to see cars in those new-fangled lanes along side me, and partly to minimize their blasted headlights in my side mirror (only one at that time, not two) at night.
  17. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Since I was 18! That was a long time ago. On the passenger side, I have it all the way out to make sure I get the blind spot. Another benefit is that you usually don't get glare from the car behind you, so there is no reason for autodimming side view mirrors.
  18. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I actually started doing this when I got my Prius last August (read about it on this board I think). I will never have them adjusted any other way. It just works and makes sense.
  19. andino
    andino Senior Member
    746
    551
    San Jose, CA
    I've been driving with my mirrors that way ever since I learned to drive. Not sure why everyone insists on having the side of the car viewable in the mirror.
  20. Thai
    Thai Prius Neophyte
    1,197
    89
    Because with the 3-3.5" convex mirrors, you accomplish the same task while allowing you to see the traffic behind you better. Instead of relying on one mirror to see traffic that is coming up and/or in your car's rear corners, i have both the rearview mirror and the side mirrors. And with the convex mirrors, you can also see where the curb is in relation to your tires when you parallel park.
    And if you mount the convex mirrors in the INNER UPPER corner of the sideview mirrors, it works great. The top half of the side mirrors are useless anyways (unless you're being chase by a helicopter)...so, the convex mirrors are in locations that you don't use.
