2001 Prius, rebuilt battery but shuts down still
Discussion in 'Generation 1 Prius Discussion' started by Brettinmaine, Jun 16, 2010.
  1. Brettinmaine
    Brettinmaine New Member
    26
    Portland, Maine
    2001 Prius
    Hi everyone,
    I'm new to the forums. I have a 2002 Prius that works well and I love it, but that isn't why I'm writing.
    I purchased for a low price a 2001 Prius from someone who had been told by the dealer that it needed a new HV battery. It is a "project" car and I figured it may be fun.
    Anyways, I got the car towed to my house. It wouldn't start, but that made sense because the 12v battery was very dead. I took it to the local auto shop to be charged and borrowed the 12 v from my working prius and plopped it into the 2001. It started up with the triangle of death, the check engine light, and the battery icon.
    I drove it around some side streets just to see what would happen. It seemed to behave in the textbook "bad battery" manner. It went from 25% to 100% on the battery meter very quickly. When reading low, the car sometimes lagged in acceleration.
    I bought a battery from a salvage yard. It came from a prius had been in an accident. I put it into my 2001, and unfortunately the problems continued to just like before. For this test I had put the newly recharged 12 v battery back into the car.
    So, I read some threads around here and became inspired. I took apart both batteries, charged them, and picked the modules that held the most mAh. I also discarded several modules from the salvage battery that read an incorrect voltage when charged.
    I put the "combined" battery back into the car, and to my great enjoyment it started up without a battery symbol (although there was still the triangle of death and the check engine light). I did find that the 12 v battery was dead again, despite it having been driven very little, so i once again stole the 12 v from my good prius. The triangle and check engine warnings did not necessarily worry me because my 2002 occasionally showed those warnings after the 12 v battery was removed and replaced, but it always "went away" after a day.
    I drove the car around some more and the HV battery appeared to behave normally. It stayed within the 50-75 range and there was no lag in accelerating. This is where things get interesting.
    After about 15 miles the battery icon came on, but the car continued to behave normally. At around 20 miles I was at a red light with the battery meter in the dash reading 75% when I noticed the dashboard lights/ speedometer were dimming. The car was sitting with the ICE off waiting for the signal to change and everything seemed otherwise ok. Then, suddenly, the dash screen flickered, went totally white, and turned off. The car would not move. I turned the key to off and tried to restart, but it behaved as if the 12 v was low- the dash was dim and the dash screen would not get to the "Toyota" icon but would go white and then shut off.
    I got the car towed home (getting the most out of my AAA membership) and pulled the 12 v battery to put it back in my good prius. It was low enough that I had to jump it to start the good car.
    So here is my theory and I'd like some feedback: I have read that Priuses don't have an alternator, but instead use the HV battery running through a converter to power the dash, accessories, and recharge the 12 v. I'm wondering if my car's symptoms point to a problem somewhere in that converter system. The dead 12 v batteries, the way the car seemed fine for about 20 minutes of driving... It seems logical to me that if there were a problem with the flow of power from the HV battery to the car's accessories, the car might still run for as long as the 12 v had enough juice to make up the difference. Does this make sense?
    Might this also lead to false battery warnings, which would explain why the battery light did not come on immediately as in the past but only after 15 miles, as the 12 v was drained?
    I welcome your thoughts. I'm sorry I don't have any codes to report- if anyone knows a way to get a code reader I'd like to hear it! Since this is only a project car I'd like to avoid taking it to a dealer unless absolutely necessary, although when I bought the car the price was good enough that, as a last resort, I could buy a new HV battery and still feel I've gotten a good deal. Right now I'm just wondering whether I should investigate this converter idea further or whether it is more likely that the HV battery is just bad.
    Thanks, Brett
  2. Patrick Wong
    18,200
    6,500
    Hi Brett,
    It does sound like the DC/DC converter is not working. You can verify this by making the car READY, then measuring voltage across the 12V battery. A correct reading would be ~13.8VDC. If much lower, than the DC/DC is inoperative and you may need to replace the inverter.
    If you find that the DC/DC operates when the car is cold, then stops operating after it warms up, first check the inverter coolant pump to see whether 1) you can hear it <sounds like an aquarium pump, you should not hear air bubbles> and 2) you can see turbulence in the coolant reservoir. It's a lot easier and cheaper to replace the pump, if that turns out to be the problem.
    Since you own two Classic Prius, if you decide the inverter is the problem, you might decide to swap the good inverter into the newly acquired vehicle to confirm your diagnosis.
    Bob Wilson has been renting out the Ecrostech miniscanner which can read Classic engine, hybrid vehicle and traction battery ECU DTC. If you send him a PM he may be able to help you with that.
  3. bwilson4web
    16,179
    Hi Brett,
    If you have a Windows compatible laptop, you could go with the Auto Enginuity and the adapter documented in the sticky thread. It reads all but the immobilizer and with the adapter, you can also get the vehicle to flash the two-digit codes. At ~$300 with your own laptop, it provides more capabilities although there are some areas I'm still looking at.
    I've sent a PM with the terms and conditions but either approach works. Certainly the Graham miniscanner is the more established product and provides excellent data. The Auto Enginuity has more codes and most of the data values have been verified. Just some of the more obscure ones, MG1 torque, remain in question. The error codes and most ordinary engineering data appears to be solid.
    I agree with Patrick that it sounds as if the DC-DC converter in the inverter has failed. However, there is a fusible link that might be bad. I'll try to post more details on testing it later this evening.
  4. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    Hello everyone,
    Here is an update on the car.
    First, the inverter coolant pump has failed. No bubbles, no pump gurgling noise.
    Second, the battery voltage drops about 0.25 volts when the car is on. It continues to go down over time. I let the car run for 10 minutes and the voltage slid down about half a volt.
    Third, by some act of god there is a salvage inverter on sale only 10 miles from where I live.
    So my plan at this point is to get a replacement inverter assembly and pump. I feel comfortable enough in this diagnosis to make the investment without renting a scanner from Bob. Should I think twice about that?
    I'm also trying to think about what to do with my extra battery cells. I'm thinking of putting an electrical assist on my bike. With 3/4ths of a hybrid battery I could really go ;)
    Thank you all for the advice so far. I'll wait to see if anyone thinks I should stop and check for anything else before I go pick up the inverter, but notwithstanding any surprises I may go pick it up tomorrow.
    Brett
  5. Patrick Wong
    18,200
    6,500
    If the battery voltage is not maintained at ~13.8VDC when the car is READY, and you are checking this when the inverter is cold, then I think it is reasonable to assume the DC/DC converter within the inverter is dead and will not revive even after you install a new pump.
  6. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    Yes, the inverter was cold. I was indeed hoping it would work until hot but no such luck.
    Brett
  7. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    Update: ordered a coolant pump. The Toyota dealership said there were only 10 pumps in it's system on a ship from Japan, all of which were spoken for. I ordered one online from ebay (it is new, not used). The person on the other end of the phone said that if the pump had died then the transmission would need to be replaced too. He did not sound particularly knowledgeable, but is there some truth to this?
    If I ever get this thing working I'm going to call it the Frankenstein prius- stitched together from parts of the dead.
    Brett
  8. bwilson4web
    16,179
    It sounds like you're good. Plus, you can always try the Tc/Ts jumper trick and read out the flashes. It is a lot cheaper than any scanner even though it will be an SOB to hit the right pins. Check the sticky for details. <GRINS>
    I've added my diagnostic to the diagnostic interface to my jumper and should start analyzing more of the Data Link Connector signals tonight. For grins, I'll try the Tc by inducing known problems and seeing how well the flashes work. <GRINS>
  9. Patrick Wong
    18,200
    6,500
    Based upon your OP describing the car's symptoms, I think the transaxle is OK.
    As the Classic population continues to age, more & more of those vehicles will fit into the Frankenstein category, because it makes more sense to buy a salvage inverter for ~$400 than to buy a new part costing $3K.
  10. jk450
    jk450 New Member
    55
    Given that your vehicle has multiple problems, it's important to have a focused plan of action. To begin with, your battery ECU is reseting every time the 12V battery is drained and then recharged. This can really confuse the diagnostic process. I would recommend that you install an OEM 12V battery that you can leave in the vehicle, and make sure that (a) you don't run the vehicle long enough to deplete it below 12V, and (b) you recharge the battery after testing the vehicle.
    You could have other issues. Replace the 12V battery and retest.
    Again, replace the 12V battery and retest. I wouldn't normally recommend this as a first step when a failed 12V charging system is indicated, but again, you have multiple problems.
    Yes, you should. You haven't checked out the system from the inverter to the 12V battery. For all you know, the 12V output of the inverter could be disconnected. The system needs to be checked out before you start throwing parts at the car. Otherwise, you're just guessing.
    You may guess correctly, but if you don't, you'll have wasted your money, and I'd rather not see that.
  11. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    The 12 volt battery is not the issue because the problem is the same whether I use the battery from either of my two Priuses.
    There may be a problem between the inverter and the battery, but the non-functioning coolant pump seems to make a bad inverter very likely? The pump must be replaced either way, and even if this doesn't fix the problem I'll have replaced an inverter that was running who knows how long without a cooling system with a salvage unit with only 64k miles.
    If this doesn't work I'll be checking codes. Right now the investment is in line with the risk.
    When this doesn't work I look forward to your "told you so." :)
  12. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    And yes, I am done running the car to drain the 12v. She's charged up and has been running only 20 minutes since then. Right now everything is disconnected; I'm going to take out the inverter and have a look at it. Maybe I'll find a little lump of scortched plastic and metal where the dc dc converter should be? That would be handy.
  13. jk450
    jk450 New Member
    55
    The constant disconnecting and re-connecting of the 12V system can, as I had mentioned, make the diagnosis of your vehicle more difficult.
    I don't follow your reasoning. Why?
    The pump may be faulty, but you don't have enough information to determine that yet.
    Checking the codes should be the first step. Folks don't always want to do this because of the cost, but without codes, one can only guess.
  14. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    My reasoning is that the pump not pumping nicely explains everything that is happening. It's like I found a body with a man standing over it with a knife. Sure, maybe he was framed, but it seems pretty likely that he did it.
    Plus the time and expense of getting the scanner just isn't much lower than an inverter and pump (this may have been different if the inverter wasn't sitting at an LKQ 10 miles from my home). So I'm going to take the inverter out and go from there, at the very least I'm having a bit of fun and learning about these very neat cars.
    I fully admit this is guesswork but it is at least reasonably educated guesswork.
    Thanks,
    Brett
  15. bwilson4web
    16,179
    Excellent!
    Hobbit disassembled I believe an NHW20 inverter. I don't remember anyone doing the same with the NHW11.
    Also, I would be interested in when you flush the coolant if you can capture it in a large pan, like a turkey roaster. In particular, look for any 'lumpy' stuff or 'jells'. I would like samples for chemical analysis. <grins>
    On the pump, it would be great if you could measure the DC resistance and see if you can possibly flush and get any pump operation. Several things can fail a pump and taking one apart (with lots of photos) would be a great help.
    FYI, I would be happy to pay shipping of the inverter, coolant sample, and pump to Huntsville for failure analysis. <GRINS>
    Thanks,
  16. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    Bob, I am happy to ship any and all things to you at the end. If you want some of my leftover battery modules you're welcome to that too.
    I'll take pictures as I go.
    I probably won't start on any of this until next week, so don't expect updates soon :)
  17. Patrick Wong
    18,200
    6,500
    Hi Brett,
    I'm with you on this. Further, if you felt that the cost of the salvage inverter was high enough so that you wanted to minimize the risk of unnecessarily buying it, then you could move the inverter from your functional Prius into the other Prius, to see what happens.
    I agree with jk that it would be wise to keep a fully-charged 12V battery installed in the non-working Prius, to eliminate a marginal battery as an issue causing the ECUs to act in strange and weird ways.
    In any event, good luck with your repair and pls let us know the outcome next week.
  18. jk450
    jk450 New Member
    55
    You may first wish to determine whether or not the pump is running. A pump that is not making noise, and a coolant reservoir that does not have any flow, do not necessarily indicate a failed pump. Some pumps run pretty quietly, and a lack of flow in the coolant reservoir is most commonly caused by air in the system. With the ignition key turned to ON, you'll need to put your hand on the pump to determine whether or not it is running.
    If it is not running, you've learned something. However, you won't know whether or not it has failed until you check to see if it's getting power and ground. If not, you have a circuit or control issue.
    You don't need a scanner; you just need to know your codes. While I don't know how much you are paying for your parts, inverters are usually $300 to $400; a new pump is usually $100+ on top of that. You'll also need to buy some coolant. A data scan, however, should run you about $75 to $100, tops.
    Might want to check the gray plugs at the back of the inverter before you do anything. Sometimes folks forget to re-connect them. And as Patrick Wong, noted, you already have a functioning inverter with which you can test your theory. But who knows - you may get lucky. Have fun.
  19. Brettinmaine
    26
    Portland, Maine
    2001 Prius
    Hello everyone,
    I installed a new inverter and a new pump. The voltage on the 12 v battery now reads correctly. So the dc converter seems to have been the problem.
    I am having another issue however. The new pump is running (I can feel it and hear it) but i cant get coolant to come out of the right bleed screw. The left bleed screw bubbled and bled coolant after only a few minutes, but the right one just doesn't show anything.
    The coolant is reading full but I've only put in slightly less than 2 qts, which is not quite correct either. The right bleed screw seems to come from a hose out of the transaxle area, while the left comes out of the inverter area.
    Thus my best theory is that for some reason the transaxle area has a blockage and that if i could get past that I'd have a bleeding screw and be able to add a little more coolant. The pump also cycles between quiet and loud, which I imagine is caused by air bubbles.
    Any tricks to get rid of the air? Does it seem that there might be another problem? I think the pump is probably good; it vibrates and is a new toyota part.
    A mechanic friend suggested that i may need to drive the car to heat it up and trigger a thermostat that will draw coolant. However, reading about other pump replacements on this forum does not show this to be necessary. He admitted he knows nothing about the prius and that it was just a "general" solution he might try. Does anyone know if heating the car is necessary in the prius? Should I give it a spin around the block and try bleeding it again?
  20. bwilson4web
    16,179
    Blow it out with air?
