Phone Calls by Voice Activation
Discussion in 'Gen 3 Prius Audio and Electronics' started by jpyslc, Jun 22, 2010.
  1. jpyslc
    jpyslc New Member
    Denver
    Is there a way to shortcut all the prompts when dialing by voice? It is a 5 or 6 step process before you get to say 'Dial'.
    Also, what do Voice Tags do? I can't figure out what they are for.
  2. Tideland Prius
    16,621
    "dial by name"
    "mike"
    "mobile"
    Press the offhook switch.
    it's a 4 step process..... 3 steps if the name only has one number stored.
    Not sure.. never used voice tags since voice recognition of the phonebook works well.
  3. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    1) press voice
    2) phone
    3) dial by name
    4) name
    5) mobile or something else if more than one phone number is in memory
    6) dial
    that's 5-6 steps
    if there's a shortcut please let us know and how to do it.
  4. Thai
    Thai Prius Neophyte
    1,197
    89
    For me, i just set up the speed dial...it is far easier to do...and a lot quicker!
  5. jpyslc
    jpyslc New Member
    Denver
    Do you mean using a speed dial capability on the cell phone and then talking through the BT link or is there a speed dial capability in the car system?
  6. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    I'm looking to find out if there is a way to bypass the first 2 steps as mentioned above? those steps take about 5 sec which to me is a lot.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The Prius w/ nav (not sure about non-nav) has 3 screens of speed dials, each with 6 or 8, so there's 18 - 24 speed dials. You press the unhook button, then speed dial (this step can be skipped if it was the last phone screen you selected), then press the speed dial button.
    The nav owners manual has more info. ;)
  8. jpyslc
    jpyslc New Member
    Denver
    Thanks Stream. Missed the Speed Dial section in the manual somehow. All set now with Speed Dial set up.
  9. Tideland Prius
    16,621
    Did you not see my post above yours? You don't need to say Phone. Just go straight to "Dial by name"
    You also don't have to say "Dial". Just press the offhook switch once your telephone number is selected.
  10. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    Ok I'll try that in the morning. :)
  11. Tideland Prius
    16,621
    It's too bad Toyota doesn't explicitly state the shortcuts. It would make operating the nav and bluetooth a lot easier (I've had to read the nav manual a few times over to just make sure I caught everything).
    Plus, some shortcut/alternate commands aren't listed... like "Voice" in lieu of "repeat guidance"
  12. Thai
    Thai Prius Neophyte
    1,197
    89
    Speed dial (via NAVI) is the way to go...in fact, i don't use Voice thingy at all in the car.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    too bad it does not work like my BT headset;
    "call (name) mobile" or "call (10 digit number)" or "call (name) home"
    all commands in one.
  14. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I use the Speed Dial for my most called numbers. For numbers at work I use the voice commands. After getting used to the commands, it really is very easy. It is also much less distracting than even the Speed Dial.
    The only problem that I have is that sometimes Betty has trouble with my Southern English :eek:
  15. kimkap
    kimkap New Member
    North Carolina
    I'm stumped. My Prius does not give me access to my phone book when I'm driving. What's the use of putting in voice tags if I can't use voice activation to make calls when driving?
