Prius Chat Virus Warning
Discussion in 'PriusChat Website Questions' started by Judgeless, Jun 22, 2010.
  1. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Norton reported virus e.exe is infected by bbbinvestigation,org, which also try to open a media player window. I think the moderators should ask the web site provider to remove the bbbinvestigation.org's script.
  2. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Guys, if you are still having problems, try clearing your browser's cache and cookies and then come back to PriusChat to see if you are still having troubles. My server admin are 99% sure that the exploit has been taken care of, so at this point it might just be problems with your local machine caching files.
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I've cleared cache, cookies, and restarted Firefox. I have adblocker active. It's still happening to me.
  4. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Thankfully, I don't see any problems. Is it restricted to firefox users?
  5. Mark57
    2,945
    2,737
    OK
    No, IE 6 and above plus Firefox. It tried it on several different test machines.
  6. edmcohen
    edmcohen Member
    133
    25
    Newark DE
    Another user having the kind of problems described, including a false attempt to run some kind of Java media. I'm a Firefox user and I have Norton.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I get the warning too, even on other machines. I configure my browser to automatically clear the cache/cookies upon exit
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    This only appears to target Windows machines. Running Ubuntu, FireFox, and NoScript, everything is fine
  9. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I just tested on a Windows machine and am not getting attacked. Tested IE 8 so far. Testing FF next.
  10. qbee42
    3,074
    I think Honda put it here. You heard it from me first.
  11. mbartley
    mbartley Junior Member
    47
    LA County, CA
    I had it crash a computer running Opera and Vista. It locked up so badly I ended up power-cycling.
  12. drees
    drees Senior Member
    1,782
    247
    So how was PC hacked? Bug in vBulletin that was not patched? PC database broken into? Server that PC is hosted on broken into?
  13. Jeremy Harris
    Jeremy Harris New Member
    221
    39
    Salisbury UK
    It's still there. Like others I've cleared everything, re-booted and Avast is still reporting the rogue java script. I'm getting trojan warnings randomly from pretty much every page on Priuschat.
    Jeremy
    PS: I'm running a windows machine with Firefox. On my other machine (also windows/firefox, but with noscript and adblock) Avast doesn't seem to see any problems. My guess is that its coming from the adverts.
  14. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Jeremy, it's actually probably because noscript is blocking the javascript from bbb-whatever from running. Still looking into this...
  15. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Update: I got the php script to pop-up in Windows under FireFox. I forgot to clear the cache system that PC.com uses and now I can't get the php file download to pop-up in Firefox anymore. Please let me know if it still happens to you guys.
  16. Pteryxx
    Pteryxx New Member
    TX
    I'm also getting a 'Malicious Script Blocked' warning from Avast, blocking 'bbbinvestigation.org/ks' on every instance of this forum I've visited. Disabling Javascript stops the warnings; enabling Javascript turns them back on. (Firefox 3.6.3)
    I've been searching the troubleshooting forums since about midday, and the warnings started appearing a couple of hours ago - in mid-search. Whatever was done to your forum might have been done recently. (Or Avast autoupdated while my back was turned.)
    (Edited for quote fail.)
  17. Pteryxx
    Pteryxx New Member
    TX
    Yep, just tested with a new window and Avast still blocks the same scripting attempt. Shall I wipe everything and retry?
  18. Pteryxx
    Pteryxx New Member
    TX
    Whoops, unnecessary post.
  19. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Still happening to me, too. Back to troubleshooting...
  20. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Here is what little I have found out so far:
    1) Google found it (or it found Google) around 5 June and told Microsoft
    2) Four days later Google let the rest of the world know.
    3) Microsoft bitched about letting the world know (Windows Help Vulnerability Disclosure - The Microsoft Security Response Center (MSRC) - Site Home - TechNet Blogs)
    4) There is no fix figured out yet, other than some really temporary and complicated registry hacking described by Microsoft (http://www.microsoft.com/technet/security/advisory/2219475.mspx)
    5) Turning off active scripting helps, but does not get rid of the problem. Unfortunately, you need to turn active scripting on to download windows updates. (That sucks.)
    6) Updating to Window Media player 10 or 11 is essential if you have this problem to prevent your computer from even worse damage.
    7) This virus has completely disabled my Symantec AntiVirus Corporate Edition from running a scan. So this Virus is very serious and looks to be around for a while.
