How much do you use Power Mode?
Discussion in 'Gen 3 Prius Main Forum' started by Eoin, Jun 7, 2010.
  1. Tideland Prius
    16,623
    Yes but power is not the default mode. normal is. PWR can make for a quicker 50-70mph pass because the remapped throttle tells the engine to rev faster (spool up faster) than in ECO mode. Making PWR mode more lively means something has to accompany that throttle mapping, right? (just picture that curve that's been floating around the site).
  2. fed123
    fed123 Member
    120
    New Jersey
    2024 Prius Prime
    Used power mode for the first time this week driving on 1-84 between Bethel, Connecticut and Hartford. It felt like having a third gear when going up steep hills. Worked great and was quite a pleasant discovery.
  3. skamar
    skamar Junior Member
    Greece
    Not very often. Only when i want to bypass someone.
  4. Fstr911
    Fstr911 Member
    235
    55
    I use it almost 100% of the time. I wish the car would default to the Power Mode
  5. StrongDoc
    StrongDoc Junior Member
    36
    Arizona
    power mode rules
