CB radio whine
Discussion in 'Gen 2 Prius Audio and Electronics' started by BassMasterCHS, Jun 27, 2010.
  1. BassMasterCHS
    BassMasterCHS New Member
    Swamps
    I get a whining noise through my CB radio whenever i accelerate.. What's wrong?
  2. freesky
    freesky Junior Member
    My owners manual said cb radios may not work.
  3. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Whats powering your CB radio? And is it hooked up to the stereo system?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    People are whining that they are being passed by your Prius, it is normal.
  5. snijd
    snijd DIY or die
    243
    52
    PNW
    Without intending to be at all flippant, the problem is having bought a Prius. Especially with the Gen II, there's a lot of noise from the inverter and motor-generators. Here's a visual look at some of the electrical noise generated by both the Gen II and the Gen III.
    You may get some improvement by adding an rf choke to your power lead and speaker wires, and by positioning your antenna near the aft-center of your roof. It's unlikely you'll cure the problem, though.
  6. flash
    flash Long time lurker
    Danville, California
    I have a UHF/VHF ham radio in my gen II and don't have any issues at all. The rf chokes are a good idea...do you have your cb running directly off of the battery? And where is your antenna? Mine is on the roof.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    A- UHF/VHF is FM. LESS suscptible to ignition noise, alternator whine, and other forms of EMI.
    B- CB is AM. ALL bets are off!!! AM is going to pick up every static crash, electronics EMI noise, etc. It's the nature of the beast. All you can do is turn the squelch way up to block it out, use the noise blanker function if the CB has one, or get a Amateur license and use FM. Simple test, 7 bucks, better situation.
    C- All transmitters, CB or otherwise should ALWAYS be directly hooked up the battery, BOTH Positive and Negative leads. Proper grounding is a must, and antenna placement is important!
  8. flash
    Thanks Pat...I've heard people say VHF/UHF wouldn't work in gen II and just pointing out that mine works and as to battery yes, you're right which is why I asked the OP.
    Curt
    W6FQ
  9. qbee42
    3,081
    I thought whining was what you normally heard on CB?
  10. KK6PD
    4,003
    946
    118
    I used to date a Jewish Princess,...
    her favorite whine was, "When are we going to Plam Springs again?" WAH!!!
  11. Bob64
    1,540
    93
    Virginia
    IF your plugging the CB into the prius AUX jack and powering the CB with the prius, you may need to get a ground loop isolator.
  12. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    What's a CB?
  13. fwbrc51
    fwbrc51 Junior Member
    61
    Fort Walton Beach / NW Florida
    crappy broadcasting
