Self parking feature is a joke
Discussion in 'Gen 3 Prius Technical Discussion' started by Pleasantp, Jun 20, 2010.
  1. Pleasantp
    Pleasantp New Member
    Denver CO
    I have the high-tech package which features a "self parking assist" mode. I bought the car new in December '10 new and spent many hours trying to use the self park. Finally took it back to the dealer and frankly, I was appalled at the lack of knowledge by the dealer's service personnel (one of the largest Toyota dealers in Denver). None of the sales personnel knew how it worked and the first "factory certified" mechanic spent over an hour with me and could not make the car park automatically. He said he would check with Toyota and I should bring it back in a week.
    Did that -- but the "expert" mechanic was not working. A second "expert" spent almost 2 hours reviewing the manual and trying to make the damn car park itself. He finally succeeded -- but had to very carefully position the car and proceed very sloooooowly to get any results. He finally admitted that this feature was not practical and I should probably have waited for the 2nd or 3rd generation.
    I would be interested in any comments from any other "gadget" minded drivers who have this feature. For my money, it's not even worth the braggin' rights since it requires hours of practice to make it work. This is my 3rd Prius and up to now -- I've been pretty happy.
  2. exbauer
    exbauer Active Member
    1,188
    102
    Washington
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Agreed. I haven't been even able to get a lock on a space using the button on the lower dash. I've spent hours practicing in the mostly empty lot at work and can get the parking assist to mostly work. All that practice has improved my unassisted parking skills but I am not about to let the computer park between 2 parked cars.
    Tideland's tutorial is helpful.
    It's a good demo when showing off & a useful training aid but as our European friends discovered long ago, not very practical.
  4. bisco
    52,396
    there is a ford ad showing there's working. i wonder if it's better, worse or the same?
  5. NovaStu
    NovaStu New Member
    102
    Fairfax, VA
    Re: Self parking feature is a joke but DRCC makes up for it!!
    I've found that, for me, the "wow" factor when I show this feature to friends is the only benefit. When parallel parking, it can only do its thing if it can get your car into a space in one "swoop". For anyone who is used to rocking their car into a tight spot, this feature is not particularly useful.
    On the other hand, the Dynamic Radar Cruise Control is worth every penny I paid for the AT package over and above the baseline V with a GPS. I find it uncanny how it tracks even the smallest speed changes of the car in front of me that I likely wouldn't even notice if I was driving without it. I hop onto I-66 in the morning and, unless the traffic slows to something less than 25, I never have to touch the brake or accellerator as I drive from Fairfax to Rosslyn. The Lane Keep Assist is subtle but does help a bit on long drives.
    MJKae and Pleasantp like this.
  6. Tideland Prius
    16,621
    First of all, this is the 3rd generation IPA/APGS.... It's already quite easy to use compared to the first two...
    The first debuted on the Gen 2 Prius back in 2003 in Japan (and in Europe in 2006). It had more annoying feedback than the current one (e.g. "the steering wheel will turn left. The steering wheel will turn right. The guidance is finished").
    The second debuted on the Gen 4 LS (the one everyone knows that can park itself).
    This 3rd generation makes available the Pre-Support function which makes IPA/APGS a breeze to operate. If done right, you don't have to adjust anything, just shift into the reverse, double check that the box is green and press OK.
    My guess is that your dealer was trying to use the "old fashioned" way... i.e. without Pre-Support like the old Prius and LS. This one requries correct positioning of the car and if you read the manual thoroughly, you should be able to do it. If you just position the car willy-nilly, it won't get the box right and you'll spend a minute trying to adjust the box (which has shortcuts too if you read the manual).
    While that may seem like a lot of work when you can park it easily yourself (remember the key word in the marketing name... ASSIST), you have to remember it's a computer - garbage in, garbage out.
    For stall parking, remember 1/2 to 1 turn of the steering wheel. For parallel parking, 3ft away from the car (otherwise the box will be too close to the curb)
    Edit: I forgot to mention. The car will remember the angle you last parked with so if you're fairly consistent, the system will work without the Pre-Support function once you get it right the first time.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I don't have a 3rd gen and thus don't have the feature but I posted my experience w/lack of dealer knowledge about IPA at http://priuschat.com/forums/gen-iii...lligent-park-assist-can-do-2.html#post1125416.
    I was able to get it to park after ignoring what the sales droid said.
    That said, I do feel that one has to pay WAY too much get IPA and the advanced technology package (needing to go model V + $4500 MSRP).
  8. NovaStu
    NovaStu New Member
    102
    Fairfax, VA
    The actual cost increment for the AT package (assuming one already has chosen the GPS and JBL Audio options at $2480) is an additional $2700, not $4500. (According to the Toyota web site, the MSRP for the GPS/JBL package is $2,480 and the AT package is $5,180.) Admittedly it brings the cost of the car well north of $35,000 but it's not quite accurate to view the AT package as being a $5,180 option.
    Having driven mine for slightly over a year, I remain more than satisfied with the DRCC. I have only used the parking assist once or twice when I was showing how it works. I've never used it "for real."
    Stu
  9. Thai
    Thai Prius Neophyte
    1,197
    89
    The IPA is easy to use...i used it without the owner's manual. I am not sure why you or your salesman/mechanic is having trouble with it. As noted above, the radar cruise and pre-collision is what made me buy ATP and the IPA is just a nice added bonus.
  10. Thai
    Thai Prius Neophyte
    1,197
    89
    BTW, here is Toyota's youtube video on IPA:
  11. Donk
    Donk New Member
    Houston
    I had no problem with mine the first time I tried it... no manual needed. However you do need a situation that closely resembles the diagram given when you hit the button.
    You can't get the car to parallel park between nothing or cars so far apart you could park a bus in the space. The computer needs to read something. Just like the LKA needs stripes on the road...
  12. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    The examples of the video are really cases where you don't need any assist at all - you are not getting a driver's license in EU if you cannot park by yourself in such huge spaces. IPA would be helpful if it could help you in parking the car in more extreme cases. Even back parking, I don't really understand what IPA is for.
    If I were older maybe it could help, but even in that case, if I cannot park in such big parking spaces, I better stay home or get the parking sensors installed - those are really useful, especially on the Prius, or the backing camera, to see something since rear view is not the best on the Prius.
    PS: nice blue Prius!
  13. AussieDave
    AussieDave New Member
    Melbourne Australia
    I spent a few hours practising with it when I first got the car but unless you use it regularly or practice regularly then it is not much use.
    On the Oz version we get the park assist lines on the screen, turned on by the touch buttons on the screen when you engage reverse. Cannot remember which setting as I turned it on 6 months ago and have never changed it since. Gives a box that moves with the steering wheel turns and another set of lines that indicate the "swing" you will go through. I find that so good, combined with front and rear sonar sensors, that I park so easily and without swivelling my head between side and centre mirrors. Screen does it all now.
    I have heard from some that the guidelines are not available in other countries. Starting to wonder how many variations of the software there are for the Prius.
    I would put the parking guides up there with the DCC, auto headlights and auto wipers. Also becoming rather partial to the seat heaters.
    David
  14. Seamaster
    Seamaster Member
    123
    70
    GB
    2019 Prius
    Excel
    An utterly spurious gimmick.
    If you can't reverse park a car, you shouldn't be behind the wheel of one.
  15. Tideland Prius
    16,621
    Yep... like the NA-spec cars. We don't have the boxes/guide lines. That would be nice... not necessary but definitely help for some.
  16. Thai
    Thai Prius Neophyte
    1,197
    89
    I enjoy using it whenever i get the chance. It is really not hard to use.
  17. NovaStu
    NovaStu New Member
    102
    Fairfax, VA
    I agree with your sentiment and have no trouble wiggling into the tightest parking space but you have no idea how many people simply can't parallel park unless the space is large enough for a limousine. And even then, they have no sense of "space" or "place" when they are attempting to maneuver into that large space. Unfortunately, and as far as I know, reverse parking is not part of the driver's license test anywhere in the U.S.A.
    Stu
  18. Tideland Prius
    16,621
    seriously?!? wow.
    Up here, everything is tested. Parallel parking is tested twice and reverse stall parking at the end of the test back at the DMV (in my location, that would be reversing to the driver's side and you cannot angle the vehicle since that is technically the proper technique)
  19. qbee42
    3,080
    It's a standard part of the test in Michigan. You have to do it in one pass. Pulling up to reposition costs you points.
  20. macman408
    1,179
    368
    Ditto that in Wisconsin. I managed to fail that part of the test when I first got my license, though. Some combination of nerves and not practicing it enough in the car I tested in, probably; my first try, I was more than a foot from the curb, so I tried again but overcorrected from before and bumped the curb on the way back. Still passed the test overall though, as I performed excellently on all the other parts of the test.
