What was your most expensive Prius repair?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jstanle12001, Mar 6, 2009.
  1. richard schumacher
    7,664
    1,046
    United States
    Now, if you'd had an extended warranty you'd be as little as $180 in the hole :_>
  2. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    My most expensive repair to date has been to buy a used Goodyear Integrity tire for $25, then have it mounted and balanced for $12. I had a nail in one of my tires near the edge and it couldn't be patched, so I had to get a different (used) tire. Other than oil changes (about $32 every 5,000 miles) nothing else. My 2006 Prius is wonderful and I hope I don't jinx myself by writing this. I currently have 31,800 miles on it.
    Now that I'm thinking about it, I did have to have one rear quarter panel repainted (but I didn't pay for it). A crazy ex-wife of one of my friends keyed my car because she thought it was a car of someone he is dating. Talk about crazy!
  3. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Just the 12v battery on my 05, $200.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I went looking for information on CV joints and found this thread. I have something to add, so I'm going to revive it.
    My last 'most expensive repair' has been blown out of the water by a $2,000 bill for two front axles with cv joints. I had complained about a ticking-noise-while-turning to the local dealer over a year ago, but they trimmed a piece of plastic and sent me on my way. For that and other reasons, I'm now having my car serviced elsewhere. I seem to remember asking another dealer about the noise even earlier, but they couldn't hear anything and said it was fine. I will have to check my records to see if that was documented.
    I've been a Prius fanboy for a long time, but I think that may be changing.
  5. colonel570
    colonel570 New Member
    48
    Elon, NC
    2001 Prius
    $2746.28 for a new Traction battery.
    $2289.56 for a new Catalytic converter
    $558.77 for a new gas tank
  6. jreed
    jreed Member
    84
    71
    North Carolina
    For a 2006 base Prius with 98K miles:
    Except for tires, battery and normal routine maintenance items for things that wear out (oil filter, air filter, coolant changes, wiper blades etc) I haven't had any repairs. This is my first Toyota and I'm loving it! :)
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    How much of that was labor? :(
    My most expensive repair was a burned out tailight bulb which hit me for $.89.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Just like the skeptics said, all my repairs have been battery related:
    Fob battery in year 4 of ownership: About $2
    12v battery in year 4 ownership: About $180
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    You're so bad. :p
  10. kearsarge
    kearsarge Member
    34
    Northeast
    ouch
  11. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Most expensive repair?
    The 1000$ (Canada) G2 extended warranty, 4 yrs
    The 1500$ (Canada) G3 extended warranty, 5 yrs
    Then finding out the cabin air filter is NOT covered !!!!! WTH GRRR
  12. Patrick Wong
    18,210
    6,511
    That might illustrate an example when it is better to tow the car to the junkyard than to fix it if you have to pay dealer repair prices.
  13. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Resurface front rotors ($110) because they were rusted and pitted from lack of use.
  14. richard schumacher
    7,664
    1,046
    United States
    $85 for the replacement visor. Two screws and one connector handled while replacing it.
    Eh... if we're counting battery replacement as a repair, then $160 for an Optima.
  15. richard schumacher
    7,664
    1,046
    United States
    Yeesh! What happened?
  16. guinness_fr
    guinness_fr Junior Member
    68
    france
    Was ethanol use part of the reason of those repairs?
  17. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    158,000 miles in 4-1/2 yrs. Nothing. .... not caused by outside forces like deer, stones and other drivers. Yes like others I have replaced all the normal wear items several times but I consider the fob battery ( $2 ) and the 12v battery ( $150 ) to be wear items.
    I'm due for a major maintenance now since I haven't replaced the plugs yet and I think that the strut caps are chattering.
  18. nfschlaack
    nfschlaack Junior Member
    95
    Just recent. $525 for inverter pump. Outside of tires, nothing else.
  19. bac
    bac Active Member
    863
    52
    Pennsylvania
    2.5 years = Most Expensive Repair = $0
    /I'm sure I'm not alone :)
  20. mlbumiller
    mlbumiller Junior Member
    sage cali (near temecula)
    have just been told my rack & pinion steering needs to be replaced do the mud that keeps getting on to it. $1,700 plus labor
    2005 192,000miles
