ECO Mode on the interstate?
Discussion in 'Gen 3 Prius Fuel Economy' started by vafoodie, Jul 3, 2010.
  1. vafoodie
    vafoodie Junior Member
    Yorktown, VA
    In reading the manual, I note that it says to use the ECO mode when you're doing a lot of stop and start driving. Does that mean I should NOT use it on the interstate? My daily commute consists of 11 minutes start and stop to interstate, 11 minutes on interstate, and another 11 minutes of start and stop. My Prius is not quite a month old, so i am still learning.
  2. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    You can use Eco mode when ever and where ever you want. Mine is in eco mode 99.5% of the time.
  3. AkustaVirtaa
    AkustaVirtaa Sähköistäjä
    198
    Finland EU
    Remember that ECO mode also affects to AC in auto mode.
    Only time when I switch ECO mode off (and put power mode on) is when I have to join in tight cap in traffic. It does not give more “force” but it’s easier to handle when I don’t have to press pedal so much.
    Also, if you have snow on winter, then you might have to take ECO mode off (normal mode) to get more grip.
  4. espressoTrae
    espressoTrae New Member
    L A County, California
    Sure you can. I use mine on the freeway frequently. When I'm entering a freeway, actually, is about the only time I don't use ECO mode -- I just switch to PWR while accelerating to freeway speed [it is possible in ECO mode, but as mentioned above, I like not having to depress the pedal all the way] and then back to ECO once I've merged in, and I leave it in ECO all the way ^_^
    It'd be cool if there were like a temporary ECO pedal mapping override button on the steering wheel -- one that could be depressed to switch to PWR mode mapping for a quick acceleration until it was detected that the driver had stopped accelerating and was maintaining a constant speed or after a preset amount of time during which no significant acceleration occurred, especially if it didn't override the air conditioning ECO mode.
  5. PriusG3IV
    PriusG3IV New Member
    37
    Kentucky
    I currently drive a non Prius Toyota Hybrid (Prius is due in August) - and I never take it out of ECO mode. If I need the extra punch to merge into traffic or pass a slower vehicle, pressing the pedal harder provides the reaction that I need.
    The total available power band does not change - only what is available to your foot at the particular pedal position.
    ECO mode just "dulls" the first 50% (someone can correct me if my percentage is off) of the pedal travel. Where "Linear response" (pedal position and throttle response = equal) in "normal mode" to a non-linear - or "Exponential" - response in ECO (and power) mode.
  6. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    I used Eco mode on a 600+ mile trip on 85% highway. Once you get used to it it just becomes normal. Like everyone else said its all pedal mapping. If you put your foot to the floor its the same power as in any mode.
  7. OldArmy94
    OldArmy94 Crazy Prius Man
    Arkansas
    I like ECO mode all the time except for merging into traffic on freeways. I know that PWR mode is really more "in my head", but the way it feels makes me a more confident driver in that situation.
  8. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
  9. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Never used anything but power mode. Never will.
  10. almypal26
    almypal26 Member
    101
    So Cal
    What kind of MPGs r u getting on PWR mode only?
  11. Ninjawife
    Ninjawife Junior Member
    60
    22
    I just bought mine last month and keep it in ECO all the time! I drive 140 miles a day on the interstate. I'm also wondering what kind of MPG's PWR only gets.
  12. pikesfish
    pikesfish Junior Member
    53
    White Plains MD
    Eco mode here probably 90% of the time...but if I need some power to get up the hill then I am not afraid to switch her over and kick it into high gear. I will have to try that pressing all the way to the floor. It is not something that I do instinctively after the last car. ;)
  13. cycle11111
    cycle11111 New Member
    145
    McKinney, Texas
    ECO 99% of the time - highway or surface streets no biggy
  14. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I can't think of one time I've used PWR mode other than trying it out when I first got the car. 12000 miles 99.9 ECO mode city and hiway. No problems with the car's performance. I do stay in the right lane unless I have a genuine poke in front of me. Avg. MPGs for life of vehicle about 53 calculated, that's with upper 40s(MPG) in the winter and mid to upper 60s(MPG) in the summer. No hypermiling.
    Tony Renier
  15. Chad's Dad
    Chad's Dad Junior Member
    35
    Austintown, OH
    If you take similar routes every day, set your display screen to one minute fuel consumption. That way you can experiment with power and eco, A/C non-A/C, etc.
  16. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Toyota just emphasize the use of ECO for city start stop because it's there where the biggest benefit lies since it makes it much easier to avoid excessive acceleration at low speed.
  17. Downrange
    Downrange Active Member
    372
    209
    2024 Prius Prime
    SE
    My understanding is that, aside from some changes to how the AC works, it's just throttle mapping.
    I just leave the car in ECO, and if I need the go-pedal, I depress my right foot. I can't imagine a situation where I would need to ever push the little "power" button. My foot works fine.
    The ECO throttle mapping "spreads out" the accelerator enabling finer control. Why would I ever turn it off?
