New 'OEM look' Chinese HUs (Coagent CA3692/Flyaudio E7572NAVI)
Discussion in 'Gen 3 Prius Audio and Electronics' started by rrolff, Jul 5, 2010.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    TX2TH posted about a FLYAUDIO.net HU. Looks like the exact same one sold by Coagent.
    A few calls shows it is now available in samples, product will be around end of the month... Cost is around $1000 US, more in Canada (and likely more still in the UK).
    It definitely looks good - and will likely come with all the strengths and all the weaknesses defined in the Chinese HU threads...
    I think they are trying to hold up margins - but it is hard to believe people will generally buy a product that is more than a premium highend HU, and not crazy much more than a used factory nav (heck - new I think they are $2K)...
    Interesting though!
  2. MJ225
    MJ225 New Member
    39
    The Flyaudio unit caught my eye on some Russian site for 36,000 rubles. That's roughly 1,150 dollars.
  3. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    the coagent pricing is a little bit crazy. I waited a long time for their distribution, but when I found some proces on german site for other models I reallize to go a chinese path.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Oh, it comes with the face plate.
  5. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    if anyone is interested in the FLYAUDIO...I can get these units for $899 thru a contact I have.
  6. SamelCamel
    SamelCamel New Member
    60
    Kansas
    You have any specs on this or maybe a manual?
    -Sam
  7. n24005
    n24005 New Member
    West Milford, NJ
    Interesting...
    One big difference I notice from the Rosen is that the FlyAudio does not seem to have SD card readers on the front.... Also more buttons. The Rosen is supposed to also be built from the CASKA 3692..
    Is there good support with FlyAudio?
    The Rosen MSRP is like $1700, but it looks like we will be able to get them for around $1000...
    What to do??!??
    Thanks,
    Jeff
  8. prius2010II
    prius2010II Member
    269
    us
    People buying a Chinese HU (generic or Rosen) might research:
    1. Availability (and pricing) of SAT adapter that's controlled by and displayed by the HU
    2. Same with HD radio
    3. Availability of traffic. Cost of any required hardware. Subscriptions
    4. Maps. What's included. OEM? Time limited? Trial version? Quality? Cost of upgrading to better maps. Cost to upgrade to next years maps.
    European posters report paying 1/3 the cost of an aftermarket radio.
    People in the US can purchase the Kenwood 6160 for $740, the Pioneer AVIC X920B for $895 or the JVC KWNT1 for 732. Probably for less if you shop ebay sellers. You can buy the dash kit, wiring harness and steering wheel adapter for under $100.
    I don't see any price savings. People have to weigh the OEM look against the features and better support that come with an aftermarket brand.
  9. bagwell
    592
    49
    the woodlands, tx
    UPDATE: looks like the price will be around $850-900...I was just on the phone with my contact...I haven't bought one yet because this unit has no pre-amp outputs for a subwoofer I definitely need to install...he'll let me know more details about this tomorrow.
    also - he's based in California and the unit comes with a 1 year warranty - any issues, send it back to him.
    the only info I have on the unit is on flyaudio.com ; I believe there is a generic PDF for the manual on the site.
    personally I think these units look waaay better than standard double din....too much wasted space.
  10. bagwell
    592
    49
    the woodlands, tx
    he following is system parameters [​IMG]
    Display Parts​
    Screen Dimension: 7.0inch Display Area: 152.4*91.44
    Definition:​
    800*480​
    Pels:​
    2.65million​
    Type:​
    Tft(Thin Film Transistor) Active Matrix,Light Penetration​
    Edge Illume:​
    Cold Cathode Light​
    Colors System:​
    Ntsc/Pal Compatible​
    Temperature Range:​
    -10°C~~+50°C Centigrade​
    Save Temperature Range:​
    -20°C~~+80°C Centigrade​
    Touch Screen:​
    Resistance& Press Simulate(Film+ Glass)​
    Gps​
    Manner:​
    L1,C/A Code Gps Sps Standard Localizer Service​
    Receive Manner:​
    12channel​
    Receive Frequency:​
    1575.42mhz​
    Sensitive:​
    -130dbm​
    Test Renovate Time:​
    Once Each Second​
    General Parameters​
    Max Consume Current:​
    10.0a​
    Pressure:​
    Dc12v(11v~16v)​
    Grounding Manner:​
    Cathode Grounding Manner​
    External Image Input Level:​
    1v P-P/75 Ohm​
    The Max Input Level Of External Sound:​
    1.5v/22 K-Ohm​
    Image Output Level:​
    1v P-P/75 Ohm(White 100% Output /When Displaying Dvd) ​
    Amplifier, Audio Part​
    The Max Output Of Power :​
    45 W*4​
    Load Impedance:​
    4 Ohm​
    The Max Output Level /Resistance Prefix:​
    2.0 V/100 Ohm​
    Equal Loudness Curve:​
    6db,(10khz)​
    Equalizer:​
    100hz-14~+6db,10khz±10db​
    Dvd Display Parts​
    Disk Format Supported:​
    Dvd-Rom,Dvd-Video, Dvd-R(Video Mode) /Rw (Video Mode),Cd-Rom,Cd-Da,Cd-R/Rw​
    Zone Number:​
    6​
    Signal Format(Sampling Frequency):​
    (Dvd):48/96 Khz
    (Cd):44.1 Khz ​
    Signal Format(Quantum B It):​
    (Dvd):16/20/24b It Beeline
    (Cd):16b It Beeline​
    Frequency Feature:​
    (Dvd):8hz ~44khz(± 1db)
    (Cd):20hz~20khz(± 0.1/-0.3db)
    S/N(Dvd):97db(1khz )
    (Ihf-A Network)
    (Cd):96db(1khz )
    (Ihf-A Network)​
    Dynamic Bound:​
    (Dvd):95db(1khz )
    (Iec-A Curve/20khz Lpf)
    (Cd):94db(1khz)
    (Iec-A Curve/20khz Lpf)​
    Harmonic Distortion Rate:​
    0.008%(1khz )​
    Channel :​
    2(Dimensional Sound)​
    Fm/ Tune Parts​
    Receive Frequency Wave Band:​
    (87.5mhz~108mhz)​
    Sensitive Degree:​
    9dbf(0.7µv/75ohm Single Channel S/N30db)​
    50db Sensitive Degree:​
    14dbf​
    S/N:​
    50dbMore than(Ihf-A Web)​
    0.3%(At 65dbf,1khz,Ster-Eo)
    0.1%(At 65dbf,1khz,Mono)​
    Frequency Feature:​
    30hz~15000hz(±3db)​
    Dimensional Sound Distinguish:​
    45dbMore than(65dbf Input,1khz)​
    Am/Tune Parts​
    531khz ~1602khz (9khz )
    530khz ~1604khz (10khz )​
    sensitive Degree:​
    18µv(S/N 20db)​
    Perform Selection:​
    65 Db(Ihf-A Network)​
    Gps Antenna​
    Antenna:​
    Microwave Transmission, And Plane Antenna/ Right-Hand Circularly Polarized Wave​
    Antenna Length :​
    5.0m​
    Product Size​
    178(W)*100(H)*165 (D)Mm​
    Gps Antenna Magnetic Base:​
    39(W)*15.5(H)*48.5 (D)Mm​
    Total Weight​
    Weight:​
    2.5kg​
  11. sdetweil
    sdetweil New Member
    84
    texas
    I'm interested.. the Rosen unit with Ipod & camera harnesses, and shipping is $1200, and THREE year warranty..
    but I like the look so much better than the 2Din setup..
    I ordered the Toyota shell and spacers for a 2 din, but would like something else.. but, it has to WORK reliably.. wife driving car..
    can't tell if this does bluetooth contact download.
    also, the pioneer has voice dial and nav..
    Sam
  12. bagwell
    592
    49
    the woodlands, tx
    I'm kind of in the same boat...ordered the schosche faceplate for a Pioneer and actually ordered a Pioneer HU....but I think the rosen/flyaudio setup look way better, cleaner.
  13. prius2010II
    prius2010II Member
    269
    us
    Flyaudio has a new series of units (Golden-8000 series). A prius model isn't available. I don't know when or if such a unit will be available.
    Flyaudio Golden Collection
    It looks like this series has the sub out a previous poster is looking for.
    They also have a platinum (9000) series but I have no idea what features that unit offers.
    A couple of posters have a contact with a flyaudio distributor/dealer. Maybe they can shed some light on the new models.
    I agree the flyaudio and Rosen look better then double din units. However Rosen and Flyaudio are missing features some of us are looking for.
