Problems with paint chipping away
Discussion in 'Gen 3 Prius Main Forum' started by Moose49, Jul 5, 2010.
  1. Moose49
    Moose49 New Member
    Maryland
    We bought our 2010 Prius at the end of September and since then, we have accumulated a rash of little paint chips, mostly on our rear bumper but elsewhere, as well. It seems that every time our bumper comes into contact with the front of another car when parallel parking -- believe me, this is the slowest, gentlest contact there can be -- we get a little paint chip, usually from the screw holding in the other car's license plate. We are exceedingly careful drivers and on our previous car -- and 1994 Toyota Camry wagon -- this has never once happened.
    We also found paint chipping away on the edge of the hatch door where we attached a temporary bike rack. And the slightest scrape of the low-hanging front bumper on the lip of driveway also resulted in lost paint.
    I have used touch-up paint to cover every scrape, but it doesn't look good. In addition, we are making sure we never brush up against any object whenever possible, only parallel parking where there is excess room.
    Nevertheless, I was wondering: Have others experienced this problem? Did Toyota really chince on the paint on Priuses? Would others recommend some kind of protective coating? And, if so, what type?
    Our dealer tried to get us to buy all kinds of coatings and sealants when we purchased the car but I assumed it was the usual new car dealer scam. But maybe I was wrong...
  2. andino
    andino Senior Member
    746
    550
    San Jose, CA
    I had issues with rock chips on my front bumper of my Scion tC before moving to this car. It seems to be that Toyota has brittle paint so I had the front of my car (hood, mirrors, bumper, fender) clear bra'd to prevent rock chipping from freeway driving. I've never heard of paint chipping from a bike rack but it makes sense if you were bumping into another car even if its so slight.
  3. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    92
    Virginia
    Uhh, don't take this the wrong way, but while the formulation of the paint appears to be less robust then normal paint... in my opinion, if you scrape against something... what do you expect? The paint is not bulletproof. For example, it isn't going to hold up against someone keying your car any better/worse then normal paint. Perhaps learn how to park or avoid parallel parking? a 3000 lb vehicle touching another is going to do some damage. Especially if all that momentum/energy is focused in the area the size of a pencil eraser. That said, the only chips I have are on my hood, from rocks. And a license plate imprint where someone rear-ended me. But yeah, the dealer stuff is always a scam. Your right to avoid that stuff.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    The new eco friendly car paints are not as durable or scratch and chip resistant as older car paints were. It's not just Toyota, I just did a Google search and virtually every make of car has people reporting paint problems.
    I never use car washes anymore and I had Clear Shield (same as Clear Bra by a different company) put on the front the week I bought the car, so far so good.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    As I read your post, particularly the parts I highlighted in red below, I felt like I should check the calendar to make sure it wasn't April 1st.
    I can't imagine what issues you'd have if you weren't exceedingly careful drivers... :eek:
    cwerdna likes this.
  6. azgringo
    azgringo New Member
    109
    24
    Phoenix, AZ
    I had the same problem. I had a black 2010 that I ended up selling but the hood had tons of small chips from normal driving. In fact, I took it to two different paint/body shops and asked how much to buff out and was told at both locations that it was beyond that and that hood would have to be repainted. Of course, I didn't do this, but I was disappointed in the weak integrity of the paint on my Prius.
  7. theloop82
    theloop82 Member
    Spanaway, Wa
    Dont mean to flame here, but if you cant paralell park without using the braille method, you should drive a bit further and find a nose in parking spot. Where I learned to drive, its never okay to come in contact with any other cars while parking or while moving.
    Its because of bad parking of others that my 4 month old Prius has 2 dents in it already. What is slow, gentle contact to you can look alot like a hit and run to someone else.
    But yeah, the paint chips easily, ive noticed!
  8. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    I have decide to never visit Maryland with a car
    I though parking by sound was a urban myth :eek:
  9. Downrange
    Downrange Active Member
    360
    189
    2024 Prius Prime
    SE
    This thread is a hoot! Let's see: "it's hard to see out of the back of the Prius, so just go on back until you gently bump the car behind."
    That's a "collision," and if you bump someone's collectible car, then flee the scene, they can prosecute you for hit and run.
  10. Moose49
    Moose49 New Member
    Maryland
    All I can say is that in 16 years of owning a Camry wagon, we have had no paint chips or dents on our bumper, nor have we caused any chipping or dents on any other car (in both of our cars).
  11. Bob64
    1,540
    92
    Virginia
    Lets all just agree that the paint is more "brittle" when compared to previous paints, due to its more stringent environmental standards.
    I would like to suggest that if you don't like the paint, then perhaps you should get your bumper "contact areas" repainted with a more... abuse-tolerant paint variety?
    Personally, It is not OK to come into contact with another car - ever. If you can't drive/park without doing so, then you should have some backup cameras, proximity sensors, etc installed so you can mitigate the issue entirely.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    or buy one of these
    :cool:
    cwerdna and GrumpyCabbie like this.
  13. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    :eek:
    ...and you passed a driving test?
  14. sshaw10
    sshaw10 Member
    103
    West Los Angeles
    I've had mine for 6 months and notice a couple chips. I had a 1985 Cressida for 25 years and the paint was much better. I think it's the body material, plastics, that keep paint from binding as well but I really don't know. I just know that I'm doing the exact same driving and there's more chips in this car than I had in 15 years of my other. The paint and clearcoat just aren't as thick.
  15. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    The Prius is an eco-friendly automobile. It is just decomposing back to it's natural environmental state (dust). It starts with the paint chipping off.
    Don't you guys remember seeing the Prius TV commercials of the eco-friendly decomposing Prius?
    Keith
    2 people like this.
  16. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Sounds like you need to run a rubber belt around the car as found on NYC taxis. VentureShield film will help but cushioning is indicated.
  17. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I had the same experience with my 1997 Camry, but the paint on the 2010 Prius seems to chip very easily. I have a couple of chip marks on the left hand side toward the front, and frankly, I have *no* recollection of coming into contact with another vehicle or service. I know a very nice body shop which is very cooperative about painting the chips -- I'm not good with the touch-up paint myself -- but this is not pleasing me.
  18. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    A good driver's vehicle never comes into contact with anything...thats just the bottom line.
    I would not at all consider you "exeedingly careful" at all. There is no reason your vehicle should ever bump into the vehicle behind you when you are parallel parking. You should never scrape your bumper on a curb. Gently touch my bumper and I see you its going to cost you $500 for a bumper repaint.
    Whenever your vehicle comes into contact with something...it will be damaged.
  19. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    Hey everybody! Well, most every body. Back off the snides. The OP just asked if the paint was a problem.
  20. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    I had a 2002 Polo and it had all sorts of scratches and paint chips. The Prius is not better, but not even any worse.
    I have a paint chip on the engine hood due to a small stone flying off from a car preceding me on the highway. I had several of them on the Polo as well. After one tough winter I was actually surprised that the Prius still looks "new" (just washed it the other day - I cannot hand wash it, therefore I have to rely on the car wash - but since Germans are really careful on how their precious cars look, the quality of car washes here is really good).
    BTW: in parallel parking in Germany if you touch the car behind or in front of you it is considered an accident. You have to be *really* sure you made no visible damage whatsoever. Otherwise you need to call the police for checking it. If you leave the place without notifying the police, it is considered "hit & run". If you don't call or wait for the owner of the car to come back, he can call the police and trust me, they do find you again - Police here have nothing better to do than finding people who chip other people's cars when parking....
