Converting MPG into liters per 100 km
Discussion in 'Gen 2 Prius Fuel Economy' started by ckbarnard, May 2, 2006.
  1. mchaconcr
    mchaconcr New Member
    17
    <div class='quotetop'>QUOTE(patsparks @ Oct 14 2007, 06:01 AM) [snapback]525395[/snapback]</div>
    :eek: That tells me I'm not driving my prius correctly, or you live in a very flat place.... Because going uphill for more than 5 minutes definitively gives me a bar higher than 10k/100l (23.5 MPG). Also the first ten minutes with the A/C on normally give me a bar off the chart... And the right bar (the inmediate consumption at some times is showing only 10, when the numbers say that the actual consumption is over 25l/100k (9mpg).
    Also... another disadvantage.... when the ICE is on, but your car is stopped (eg. when the battery is to low, at a red light, with A/C on). an "Imperial" Prius will show: 0 MPG.... mine shows 99.9l/km
    I haven't even completed a tank on my Prius.... I've been around with it for only 600km (Still smells new), but so far the average consumption is 35.1 mpg... Is that bad? :huh:
  2. Shieldsy
    Shieldsy Prius Fruitcake
    32
    Sydney, Australia
    I have had my 2007 Prius for almost 1 year and have currently travelled 27000 km. To give you an idea of what to expect I have attached my fuel summary.
    Also, it is very inefficient by design during the 1st 10 minutes. When the computer is cycling through the modes. It even idles at lights. I avoid this by turning on the car and then selecting EV (provided battery is good) and this prevents the warm-up mode until I get through the first set of lights. I then let the car do it's thing for the rest of my 40km daily commute and it seams to prevent the higher consumption in that first few minutes.
  3. doktorboogie
    doktorboogie New Member
    Phoenix, AZ
    Dood! There is a button on your Prius that will switch between miles or kilometers. I'm in front of my computer, but I believe its a tiny square button near the clock.
    I'm a mathematician myself and love math, but if its as simple as pressing a button, why not just do that?
  4. The Tramp
    The Tramp Italian Prius Expert
    357
    34
    Turin, Italy
    2020 Prius PHV
    May I disagree with you? :) l*100 km shows the graphic in bars - the smaller the less you consume. On the other hand, on a US prius you will not see more than 99 mpg (2.4 l*100 km) while we can go into a much finer detail.
    If I can choose I'd choose l*100 km.
  5. The Tramp
    357
    34
    Turin, Italy
    2020 Prius PHV
    Dood! Not all Prii have that button. I don't... :D
    The Prii for the EU have a button to adjust the luminosity of the display.
  6. cleanspeed
    cleanspeed New Member
    Los Angeles
    I'm happy you pointed out the advantage of l/100km (or really any form of unit volume/distance travelled). Before I read your post, I registered here just to make this point, which I am trying to argue everywhere I can.
    Here are a couple of examples of why this 1/100km (or even US gallons/mile) is a more useful measure:
    Example 1: I've seen people express disappointment that a Prius 'only' manages 45 mpg or so, and won't it be great if a plug-in hybrid can go 100 mpg or better. I think someone thinking along those lines might be surprised to learn that an improvement from 45 mpg to 100 mpg saves the same amount of gas as an improvement from 20 mpg to 26.5 mpg. This is not a trick...it's apparent as soon as you flip mpg on its head and look at volume/distance.
    Example 2: Improving mileage from 20 mpg to 30 mpg (an improvement of 10 mpg) saves the same amount of gas as improving mileage from 30 mpg to 60 mpg (an improvement of 30 mpg)!
    To calculate this 'improvement factor', just plug mpg numbers in here:
    gallons saved = miles travelled x (higher mpg - lower mpg)/(higher mpg x lower mpg)
    I don't mean to discourage efforts to achieve 100 mpg (or higher). But if the U.S. is to make rational decisions about where to improve first, it's absolutely critical to look not at mpg, but its inverse (in whatever units you favor). Looked at this way, it becomes even more apparent that vehicles getting less than 20 mpg are awfully tough to justify.
    If this doesn't impress, it means I haven't made the point very well...I'll keep working on it!
    Thanks again for your post and for this forum.
    Cleanspeed!
  7. priusuk2008
    priusuk2008 New Member
    289
    CAMBRIDGESHIRE
    I believe metric measurements are superior to mpg measurements, they're just not as widely known or followed in USA or Britain.
    My key measure was the inverse, litres per 100 kilometres, the lower the better and I used this in South Africa all the time. Now, however, living in England mpg is the measure, same as USA, except that the volume of a gallon is different.... whereas a litre globally is still the same measure !
    My Green Hybrid signature below shows mpg based on US gallons and to me it LOOKS poor, but in imperial terms it is about 20% better, which is very ok with me, compared to other UK cars.
    However the litre / 100km value would be just under 6l / 100km (at time of post and still lots to learn) and while I know that is good compared to other normal cars, I know that 5 would be so much better
  8. The Tramp
    357
    34
    Turin, Italy
    2020 Prius PHV
    Abandon Green Hybrid and adopt spritmonitor.de as they are Europeans and allow the user to choose l*100km, km/l, UK MPG and US MPG. What's more, you can record many other car related things@ To see an example, click on my 4.6 below.
  9. priusuk2008
    289
    CAMBRIDGESHIRE
    Thanks Tramp, I'll have a browse on there later and maybe use it too. Watch my signature
  10. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Google Calculator is also useful if you want to relate US gas prices to those in other countries. For example, "160 ISK/liter in USD/gallon" returns "160 (Iceland kronur / liter) = 8.20435008 U.S. dollars / US gallon".
    Drafty01 likes this.
  11. dehati
    dehati New Member
  12. cleanspeed
    Los Angeles
  13. greg256
    greg256 New Member
    Christchurch, NZ
    At a risk of reviving a dead thread, I'll make the first post here in two years :)
    One add-on that makes Firefox so good is "SearchWith": https: //addons.mozilla.org/en-US/firefox/addon/2194/
    After adding it, you can highlight a word or phrase, right click and choose "Search With" from the context menu to search for that phrase in Google, YouTube, Wikipedia, or whatever, but you can also create your own queries. I've set up two "services", called "L/100 km to MPG" and "MPG to L/100 km". I've linked each to "engines" which run Google calculator queries for the conversion. In each "engine", enter the address (without the spaces!) as http:/ / www . google. com/search?hl=en&q=
    And the options as either: +litres+per+100+km+in+miles+per+gallon
    or: +miles+per+gallon+in+litres+per+100+km
    I use the add-on all the time for other things, but as I have to do the conversions so often when reading these forums this solution has saved me a heap of time. For example, if I see 45 MPG, I highlight the 45 -> right-click -> Search With -> MPG to L/100 km, and the metric answer appears in a Google window (5.23 L/100 km, if you're interested!). Excellent
  14. hektorr
    hektorr New Member
    LONDON
    calculator-converter.com/l_100km_mpg_convert_mpg_to_l_per_100_km.php]L/100 km to MPG or MPG to L/100 km Fuel / Gas Efficiency / Consumption Conversion Chart / Table (Miles per US gallon to liters per 100 kilometers )
    best graph so far ;)
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Google is a pretty good unit converter. For example, just put in "45 mpg in km per liter".
  16. ambanmba
    ambanmba New Member
    Sydney, Australia
    I created a table that I have printed out and keep in the car to allow instant conversion by eyeball. :)
    If you want to modify the table (change the ranges) or use it as a template for some other types of conversions, I've also supplied the underlying spreadsheet.
    I tried to put a direct link to the table, but the system won't let me put a URL in my first post on this forum. Hopefully the moderators will let this through. I've tried to put the link below.
    blog.ambor.com/2011/12/fuel-economy-conversion-table-mpg.html
    Cheers,
    ambanmba
