Techniques for best highway fuel economy?
Discussion in 'Gen 2 Prius Fuel Economy' started by xp9876, May 28, 2010.
  1. xp9876
    xp9876 New Member
    Connecticut
    Hello everybody!
    I just recently bought a 2008 Prius with 48,000 miles on it. My friend told me about this site and I decided to check it out.
    I just had a question about different techniques to get better fuel economy on the highway. I read about Pulse&Glide, but that doesn't seem feasible on highways.
    At the moment, I just set my cruise control to 65 and cruise all the way to work, and I get about 45-50 on average.
    Is there anything to get this higher?
    Any help would be appreciated, thanks!
  2. sakai
    sakai New Member
    39
    Charleston, SC
    Welcome to the club!
    Dive right in, as there is a ton of helpful information and friendly people here to help you. As far as maximizing your mileage, tell us about your highway miles - a long commute, just on/off the highway, etc.
    The simplest things to do you will see all over this site - properly maintain your car, setting your tire air pressure higher than recommended by Toyota (but NOT higher than listed on the tire), investing in some low rolling resistance tires. My biggest advice, though, is to slow down. You may extend your commute time a little, but ever few mph you can slow down really does help. Just find the slowest speed you are comfortable with (and is legal) and set that cruise control. Yes, you will have to endure a long line of impatient truckers who don't want to pass you (what, we're supposed to drive off the road to let you stay in lane at 80mph?) and people on cell phones that can't believe that someone actually doesn't drive OVER the speed limit - but ignore them. I personally kill them with kindness and a friendly smile-n-wave when they act all angry.
  3. qbee42
    3,081
    For highway mileage there are a few things that make a big difference: low rolling resistance tires, proper tire pressure, and most importantly, slow down. Aerodynamic drag goes up by the square of speed, so you pay dearly for that extra five mph. If you can safely slow down without impeding traffic, that is your best bet for highway mileage.
  4. jhlcomp
    jhlcomp New Member
    weston, FL
    You are getting excellent mileage - certainly better than I am getting with my 2007. I find that cruise control is not the best option - ideally, not using one's a/c is helpful. Also, gauging your speed and coasting will also add to your mileage besides the right tires, tire pressure, etc. Enjoy!
  5. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    There are many here who would disagree with that statement.
    The main battery works most efficiently at temperatures where humans are comfortable. Turning off the climate control system is a false economy.
  6. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    I would also add that if you are on the highway, your trip probaly takes some time. If so, the A/C burden will mostly be in the first minutes, then it will throttle down - Prius has a variable speed compressor (unheard of before on cars if I'm not mistaken) - making its global impact on your trip not so significant.
    Also, opening the windows on the highway will create some aerodynamic drag on the car (5-10% from what I read).
  7. xp9876
    xp9876 New Member
    Connecticut
    Thanks for the welcome and helpful tips!
  8. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    Drive 55-65mph, terrain and traffic conditions permitting, and you will see some really outstanding mpgs. Anything above 65 mph and I always seem to get a precipitous decline in Fuel Economy
  9. Legionnaire O
    Legionnaire O Junior Member
    Huntington Beach, California
    I noticed driving around 60mph i get about 50mpg too, but driving around 60mph behind an 18-wheeler i got 70+mpg. At a safe distance, of course, but i remember from a Myth-busters episode that the closer you get, the better for fuel efficiency. And driving 45-50miles, you'll probably find a truck going the speed you want, or just follow the fastest one you find.
  10. thymara
    thymara Junior Member
    59
    Edmonton, Alberta
    2020 Prius Prime
    I have to wonder about safety issues and low-resistence tires.
    • how easily do they hydroplane
    • moisture and near freezing temperatures
    once upon a time I had a bicycle with low-resistence tires and the first rain on a downhill corner was all it took to change to something with some traction.
    maximizing fuel economy while risking life isn't a smart trade-off
  11. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    So your 2013 V doesn't have low resistance tires? If it does, you might want to trade them in, as Toyota doesn't know anything about safety on their vehicles.
  12. thymara
    59
    Edmonton, Alberta
    2020 Prius Prime
    Toyo Proxes A20, I have no idea if these are low resistance or not
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
    That's because low resistance bicycle tires typically consist of ultra narrow "slicks" with little to no tread. None of this carries over to LRR car tires, which are available in the same width and with the same or similar tread as normal tires. They are indeed normal tires.
    Everything that's true on a bicycle doesn't automatically carry over to a car. Perhaps you also noticed that after you oiled the chain on your bicycle you sometimes got a large black stain on the bottom of your right hand trouser leg. Maybe you shouldn't run any oil in your prius for fear that the same thing will happen. (just joking :ROFLMAO: )
  14. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    I find that I get the best highway fuel economy by letting my speed drop a bit on inclines and to rise on declines. How much you allow it to sweep should be determined by traffic. I often sweep between 5 MPH under and the same over the posted limit.
  15. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    On my 08, pulse and glide never worked for me on the highway unless I was driving over rolling hills. Use P & G if there are hills, otherwise use cruise control and don't go over 60 mph. For me there was a big difference in fuel economy between 60 and 70 mph so slow down a bit. Wind was the real mpg killer for me though.
    Ojibirish likes this.
