2008 air conditioning barely working, any tips?
Discussion in 'Gen 2 Prius Main Forum' started by ZHH, Jul 11, 2010.
  1. ZHH
    ZHH New Member
    I have a 2008 that I bought brand new, it now has about 60,000 miles on it and the air conditioning is not cutting it in the Chicago summer. Would it now be time to have it recharged? Is there modification to make it more powerful?
    We are going to have a baby soon and I don't want her to have to sit in a scalding hot car next summer, especially since its really hot in the back seat since there are no vents back there. Any help would be much appreciated!
  2. derkraut
    derkraut Member
    299
    28
    SAN
    There must be a problem with your A/C. I drive routinely between SAN-PHX, etc, in 100+ temps with my 2006. My A/C has plenty of oomph; in fact, I usually set it @ 76-78 degrees to avoid getting chilled. Maybe you have a leak, and are losing refrigerant? If your vehicle is still under warranty, I would take it to the dealer and have them check it out. The A/C never has to be "recharged" unless you have a leak.
  3. richard schumacher
    7,682
    1,063
    United States
    Quite right. The system is completely closed with no externally-exposed bearing seals, so if it's failing there is a puncture somewhere, or some other fault that needs repair.
    And do take it to a Toyota dealer. The system requires a non-conductive compressor oil that a non-Toyota shop may not know about.
  4. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    Hope its something minor, but for all those against extended warranties, here is a good example of a possible major expense for our friend should he not have invested in one.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Just an idea before you take it to the dealers, but is your cabin filter blocked or in need of replacement? A simple diy fix.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Welcome to Priuschat! As prev. noted you may have a puncture. Have you run over anything lately? Most common is damage to the front condenser which sits in front of the rad. Take a look under the fornt of the car and in fornt through the front vents.
    Also whats the ac screen on the mfd doing? Is the AC button light blinking on and off?
    Good Luck and hopefully its just a relay but your best bet is the dealer. Ouch....
  7. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    This is actually a rather stupid suggestion, but are you *absolutely* sure you have cooling on? Switch to the Airconditioning screen on the MFD and check that the A/C button in the lower left corner has a yellow bar glowing in it. If it doesn't, push it and switch it on. The A/C automatic icon on the dash still glows even if the cooling is switched off, so you would never notice.
  8. ZHH
    ZHH New Member
    Yea I am certain it is switched on.
    I actually did run over something recently, but it seems like it was bad even before that.
    If there is a puncture what do you think the damage will be cost wise? I have a friend that owns a Toyota dealer about an hour and a half from my house, if this is going to be a big job, I'll probably take it there and try to get a deal.
    Thank you for the advice everyone!
  9. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    Let us know what you find out. I have to say my air-conditioner is the best one I have ever had. My car starts feeling like a refrigerator if I am not careful.
  10. pdhenry
    pdhenry It's HEEERE!
    406
    PA
    If it's very hot you may need to ensure that the AC is on recirc.
  11. falcon3
    falcon3 New Member
    calif
    I bought my 2007 new and any time it gets above 90 the AC has to be on high rec to cool. It will not cool down the car that much and after a hour of running it still is very warm inside. Toyota says that the ac only will cool down to a maximum 20 degrees below outside temp. GREAT, when it is 100 I will be sweating in my 80 degree car. I have no problem when it is cool outside but when you need it the most the ac lets you down hard. Even my 92 camry cools way better then the prius. Toyota says it is to factory specs so I guess they can list any specs they want then it makes it easier to meet them. Another easy way out for the company. Any thoughts or comments??
  12. lenny15
    lenny15 Senior Member
    Melrose, Ma. 02176
    My Prius with 200 miles a/c works great!!
  13. lenny15
    Melrose, Ma. 02176
    Dealer can fix!!
  14. Patrick Wong
    18,210
    6,515
    Today I was driving around Tucson with my 2007, 21K miles. Ambient temp was 106 degrees F according to the MFD. It was nice & cold in the car, very comfortable.
    You should be able to expect more than a 20 degree F reduction. You can do a quick DIY check by finding the refrigerant sight glass on the passenger side of the engine compartment (look for the thin shiny metal plumbing that runs to the sight glass and the high-side pressure valve) and looking at it when the AC compressor is running. If you see bubbles that is evidence that the refrigerant level is low.
    In that case I suggest that you find another Toyota dealer and ask the service dept to verify whether the refrigerant charge is correct, and if not see whether they can determine where the leak is, fix it, and recharge the refrigerant.
  15. ursle
    ursle Gas miser
    1,049
    192
    NH
    As I understand it, if your trans-axel cooling pump goes kaput which is not necessarily uncommon, you also loose your air conditioning.
    Push start twice without a foot on the brake, check the cooling fluid reservoir and listen for a fish tank type pump behind the left headlight, if air is being blown into the reservoir the pump is not working, fairly inexpensive fix.
  16. Patrick Wong
    18,210
    6,515
    This is true, but in that case you should see the instrument panel light up: master warning red triangle and brake/ABS/VSC lights should come on, since the skid control ECU is very sensitive to a voltage drop on the 12V bus.
  17. Patrick Wong
    18,210
    6,515
    You know, this statement from your dealer service advisor is so wrong that I felt the need to provide photos to show you how ill-informed that guy is. I drove my 2007 today, with ambient temp of 95 degrees. The air coming out of the air ducts was at 34 degrees, almost freezing point. This represents a 60 degrees F difference between ambient and air duct temperature.
    I took the temp of the front passenger headrest, and it registered at around 65 degrees. The HVAC thermostat was set at 75 degrees, AUTO AC, and the fan speed was on the second position up from the slowest.
    If the AC can't make you uncomfortably cold even on a hot day, then it likely needs maintenance or repairs.
  18. richard schumacher
    7,682
    1,063
    United States
    Ditto Patrick.
    *Toyota* did not say that; some dealer who doesn't know what he's talking about said that. Take it to a competent Toyota dealer and get it fixed.
  19. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Bingo! I could use mine to store meat.
  20. mikeysaid
    mikeysaid Junior Member
    44
    Phoenix, Arizona
    for about a week mine seemed really weak. i pushed the A/C Auto button to make sure it was firing up but it was only cooling slightly...
    a lack of attention to detail caused me to forget that my wife sets the temperature in the car to 79 and when I realized all I had to do was hit the down button til it got to MAX COLD and in just a few minutes the car was nice 'n chilly.
    for your sake, I hope that's all it is, but I doubt you're as absent minded as I am.
