Deciphering My Alignment
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TFT, Jul 10, 2010.
  1. TFT
    TFT Junior Member
    Sarasota, Florida
    Just bought a 2004 Prius and it needed new tires. Got the Ecopia EP100's. I also got a lifetime alignment. Here are the before and after printouts from the alignment machine. Are these acceptable values? The after settings look like they are not exact but are within spec, is this correct? Looks like I need a shim kit for the rear also. How bad will the tires ware on the back with the alignment off so much? Can I wait 5k-10k miles before I get the shim kit installed? I plan to install new shocks and struts in the fall and get the car realigned. It's just too hot to work outside here in Florida in the summer.
    Before
    After
    Ed
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yes, you will need to shim the LR to correct the toe. My car also had this issue, although the toe was .40 on the RR (max spec is .28 IIRC). I noticed weird handling at freeway speed as a result. I went about 8k before getting it fixed and did not see any strange wear pattern, but the OEM Goodyear tires had a tendency to wear on the outside edges no matter what the inflation pressure was set at.
  3. TFT
    TFT Junior Member
    Sarasota, Florida
    How do I go about shimming the rear to fix the excessive toe? Is it reasonable to expect the tire shop to do this work? Is this the shim I need?
    Shim
    Ed
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yes, to shim the rear wheel, the shim would be placed between the backing plate and the rear axle flange. There are 4 bolts that hold the hub and backing plate to the rear axle. The 4 bolts are loosened and the shim is inserted to move the backing plate and hub in the direction to correct the toe.
    A tire shop that also performs alignment or an alignment shop would be able to do this for you and then check to make sure that the toe has been corrected.
    The dealer will probably not do this for you because it is not the accepted repair per the Toyota service manual. The service manual says that if the rear alignment is not within spec, then the axle beam must be replaced. $$$$.
  5. TFT
    TFT Junior Member
    Sarasota, Florida
    I've also noticed that after the alignment, the car seem to wander a bit at freeway speeds. I have to correct with steering input more than usual. Is this related to the rear being out of adjustment or should I look at the suspension components?
    Ed
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    Unless you have a ton of miles (you didn't say), I think the wandering is related to the alignment because my car was much improved after the rear toe in was brought into spec.
  7. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    This is normal for a Gen 2 Prius and is because it has no toe-in. The previous owner may well have asked for some toe-in to be added to prevent the wander.
    The toe-in is specified as zero because toe-in wastes some energy. Fuel economy will be slightly lower, but I'd sacrifice some economy to have a more stable car.
    The Gen 3 Prius has a little bit of toe-in, about .25° as I recall.
    The lack of toe also causes the tyres not to heat up, which means - if they're standard summer tyres for the size - they often don't grip as well. Grip is a complex chemical reaction between the tyre surface and the road surface, and the tyre compound is designed to work at a certain temperature range.
    The OE tyre in the UK, Bridgestone's Turanza ER30, is also OE for BMW and Mercedes cars which run much higher levels of toe-in, and hence run a lot hotter. (We use the same size as the US Touring model, 195/55 R16.) I found that the tyre just tends to slide across the road and wear out quickly - down to 3mm tread after only 21,000 miles. I've replaced them with Nokian 'H' tyres that I'm hoping will grip better at cooler temperatures, being designed for a Finnish spring and autumn. Too early to tell but signs are good so far.
    Some US owners have reported good results with the Nokian i3, which is available in the 185/65 R15 size used by the base model Gen 2 Prius. It has a lower speed rating than the H but you really don't need a 130mph rating.
  8. TFT
    TFT Junior Member
    Sarasota, Florida
    Thank you for your responses. The car has 100k miles and is most likely in need of some new suspension components. It rides fine as far as shock absorption and cornering, but the 100k has me thinking it's time for new struts and shocks. I would like to install the Touring edition struts and shocks and see if that will make a difference I've also read in these forums of people installing larger sway bars and gaining more highway stability. I wonder if it would help in my case?
  9. TFT
    TFT Junior Member
    Sarasota, Florida
    Do you think changing the front toe to .10 or .15 on each side will help? I understand that the tires will ware more and my mpg's will go down but by how much?
  10. Patrick Wong
    18,210
    6,513
    I think that you should first try to get the left rear wheel toe shimmed so that it is within spec. You may then find that the car's handling is acceptable.
  11. a_gray_prius
    2,927
    783
    IL
    In case you don't want to set up the alignment yourself, you can also go to a local speed shop/garage that specializes in car modification and race prep, and get a 4-wheel alignment. For me it's $180 locally.
