Strange noise related to brakes?
Discussion in 'Gen 2 Prius Main Forum' started by jendbbay, Jul 16, 2010.
  1. jendbbay
    jendbbay Member
    223
    Mostly while negotiating in very crude camp ground roadways, we started to hear a new noise. This started before the incident I will be reporting in my third thread, so I do not attribute this noise to that incident. The noise seems to come from applying the brake when the car is already stopped or nearly stopped. Its a bit of a chirp, but it is a low-throated chirp. It think they come in twos, "chirp, chirp." Any ideas?
  2. jendbbay
    jendbbay Member
    223
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Maybe just the brake grabbing? I occasionally have this and have always thought it harmless. Maybe braking in neutral to remove rust will help. Good luck! :)
  4. richard schumacher
    7,666
    1,047
    United States
    As an aside be very careful offroad; better not to at all. The Prius has little ground clearance.
  5. sorka
    sorka Active Member
    1,030
    199
    Merced, CA
    2019 Prius
    I had the same thing happen to me in my 2009 several months ago after repeated moderate braking at high altitude. It was a chirp, but it sound electronic and it would occur when lightly depressing the brake pedal just as I would start to press down. I assume it was related to either altitude or heating.
  6. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    Could you be hearing the Hill Start Assist feature? Does the Gen2 have HSA?
